10-18-2020, 07:40 PM | #1 |
Rep 31
2015 BMW 435 xdrive Axle issues
So i have seen two posts regarding the axles on the f30 and f32 chassis cars but recently i have broken my front passenger axle where the CV joints and failed tearing the boot and coming apart in half. The car has around 46k miles on it and inst stock have bolt ons and stage 2 bm3 tune I do have KW V1 coil overs as well but nothing that others aren't running and one day i did a roll at around 20mph and bam there went my axle and being stupid not wanting to spend 1.3k on a new one i bought a used one with 70k miles on it and last week that one had the same failure so I bought a brand new to hopefully have a functional car but I am wondering does anyone know the reason why these are failing??
10-18-2020, 08:07 PM | #2 | |
1296
Rep 3,532
10-18-2020, 08:34 PM | #3 |
Rep 31
Well when my axel broke the first time I was on Airlift 3P I figured the constant up and down action of daily use is the reason they went bad so I switched bag to coils then it broke again I dont know if it is just because I bought a crappy used axel or even the car is still to low.
10-18-2020, 08:39 PM | #4 |
Rep 965
Drives: 2016 F36 435x MSport
curious, but how low is the car? Been running my xdrive for about 20k miles now with ACS springs on stock dampers without issues. Wondering if its how much of a drop you have with the coilovers ?
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
10-18-2020, 08:52 PM | #5 |
Rep 31
The rear is as low as the springs go and on the front struts i have a good inch and a half maybe two inches more I could go. I would just show pictures of the car but my front lip is thicker than most so it makes the car a lot lower than it really is strut wise.
10-19-2020, 02:06 AM | #6 | |
Rep 1,934
10-19-2020, 09:28 AM | #7 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
10-19-2020, 11:18 AM | #8 |
Rep 5,369
Low and xdrive don't mix with the front axles. Once you go beyond a 1.5" drop you'll have constant problems because the axles can't handle steering angles with a big drop. You need to get a rwd car if you want a severe drop.
10-19-2020, 05:39 PM | #9 |
147
Rep 491
True Dat!
10-19-2020, 10:37 PM | #10 |
Rep 31
measuring from the wheel arc to the bottom of the center wheel cap is 14 inches and 1/8th strange thing is i have ran the car on this ride height for around a year and I am just now having problems.
10-19-2020, 10:39 PM | #11 |
Rep 31
10-20-2020, 11:20 AM | #13 |
147
Rep 491
Did you read my thread https://f30.bimmerpost.com/forums/sh....php?t=1514736
I was looking into custom longer axles so I could go lower but I need to spend more time investigatin' and calculatin' I did have a different issue causing my axle to blow out like that but the result is the same with the inner CV joint too low so the angle to the wheel is such that the inner tripod bearing can pop out.
10-20-2020, 12:10 PM | #14 | |
Rep 31
