02-13-2014, 09:29 PM | #419 | |
Rep 1,976
Drives: 2020 G20 320i M Sport
02-14-2014, 01:46 AM | #420 |
Rep 458
No I haven't flash it and I have no idea what version it is currently on. Not sure I can find a way to tell.
I didn't have to FDL code the NBT because my MFG date means the car with 609 would have come with the ZBE3 as standard. VO coding was enough. |
02-15-2014, 11:33 AM | #421 |
Rep 48
I am about to do this retrofit for a friend of mine whose car is 2013/09 3GT. The car has HU_Entry, 6NS(has 6FL and bluetooth), and Hi Fi Amp.
Read this whole thread several times but there are something I am still not clear and please help me out 1. Do I have to disconnect the 16 pin connector from the combox? If I have to do this, will I lose the telephone bluetooth? 2. at step 12 of this write up, it says I need to disconnect the USB connector from the armrest and move it to the back vent. I am confused about doing this. Helps. 3. I have to reroute USB/AUX connectors from the trunk to the head unit for this retrofit. In the future if I have to bring the car back to the dealer for programming, how do I recover it back? Or just leave it alone? |
02-16-2014, 02:37 AM | #422 | |
Rep 1,894
The cheapest way to is to move the cables from the combox to the NBT. However it will make returning to original configuration a bit of a nightmare. 1. You can buy a BT antenna with FAKRA connector (this will plug straight into the NBT), since NBT has the combox built in. 2. I'm looking to buying the USB HSD cable replacement (I not 100% if this the correct part), and run this from the armrest to the NBT, thus leaving the original cables in place. However there is some uncertainty where the wiring for the mic/aux goes. I am watching this thread for some answers. If your car has no combox then it means everything is routing back to HU_ENTRY, which means it'll be a straight out swap. Hope this helps |
02-16-2014, 08:37 AM | #423 | |
Rep 48
Thanks mate.
I have the BT GPS antenna. I have combox and this would be difficult for me to reroute the USB to the new head unit. Still uncertain about the 16 pin connector on the combox. Need to remove it or not? Quote:
02-16-2014, 09:42 AM | #424 | |
Rep 1,976
As for the 16 Pin connector on the combox, only 7 of them are used and that's for AUX and the mic. We're still trying to figure out how to run those and I have Vithy's help as he's helping me build a harness to transfer those wires to the head unit. I'm still waiting to get my car updated for a recall from the dealer so it will be another few weeks until I can reinstall NBT to my car but we'll keep you all posted.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
02-16-2014, 09:49 AM | #425 | |
Rep 1,976
The baseplate seems to have a female HSD connection so if I just connect a male HSD to it and the other end to the curry connector on the NBT, it should work. I guess I'll try to connect my HSD cable to the curry again and see if it plays video. If it does, we can just ignore the antenna portion and just use this for media sync. http://www.etk.cc/bmw/EN/parts/info/...e/84109220652/ http://www.etk.cc/bmw/EN/parts/info/...a/84212287607/
02-16-2014, 10:20 PM | #427 | |
Rep 48
The vendor suggests to use an OEM Mic, that will be easier.
I have no USB in the glovebox. The vendor suggests to use additional USB wire from the head unit to the USB port in armrest. Quote:
02-16-2014, 10:22 PM | #428 |
Rep 48
02-19-2014, 12:41 AM | #429 |
Rep 1,976
Hey steddyman,
When you installed the non-touch iDrive controller, did the back light turn on? I just received my touch controller today and I know it's not going to work but I connected it to the 4 pin connector to see if it at least powers on and it doesn't. Was it the same for you? I think the pinouts for the power might be different or it needs a connection to KCAN2 to trigger the back light. I just hope I didn't receive a dud.
02-19-2014, 02:48 PM | #430 |
Rep 34
Hello guys,
I have 6,5 screen without navi (only radio), yesterday I install an NBT inside my F30 316d. But I have a problem: the NBT isn't connect with the speedodometer. Istallator says I need extended function panel (now I have the simple one). Someone can help me? Can I install a camera? Thank you so much |
02-19-2014, 02:54 PM | #431 | |
Rep 1,976
02-19-2014, 03:00 PM | #433 | |
Rep 40,756
He needs to FDL Code the following: HU_NBT => KOMBI_CIC = kombi_low
02-19-2014, 03:05 PM | #434 |
Rep 34
Ok.
So I only say to him "You need to FDL code KOMBI_HIGH to KOMBI_LOW. It's somewhere in HU_NBT". Ho should understand me... Your information is good for NBT? Why when I use reverse I see 3 series GT and no sedan car? |
02-19-2014, 03:09 PM | #435 | |
Rep 40,756
He should know what this means so long as he uses E-Sys. If he uses ISTA/P only, then he both won't know what it means, nor will he be able to fix it.
02-19-2014, 04:46 PM | #436 |
Rep 34
I contact my installator and he says that he know your process but in my case in isn't workable because my browser has been updated with the latest updates and then the normal bmw esys is not able to encode.
I must wait new Esys. |
02-19-2014, 05:06 PM | #437 |
Rep 40,756
I seriously doubt this. Ask him what version of ISTA/P was used to program NBT.
In any event, you don't need a new Kombi as originally claimed. You only need the correct E-Sys and PSdZData versions to FDL Code NBT correctly.
02-19-2014, 05:26 PM | #438 |
Rep 1,976
I have a feeling the guy just wants him to retrofit a 6WA so he can rack in the big bucks.
02-19-2014, 05:57 PM | #439 | |
Rep 458
02-19-2014, 09:48 PM | #440 | |
Rep 1,976
