BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Anyone with the Active Auto Flash tune dyno there car yet?
      03-29-2018, 11:45 AM   #23
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
2023 BMW G80 M3  [0.00]
2020 BMW X4MC  [0.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [0.00]
Originally Posted by raichean View Post
Any last minute advice before Saturday? I think I have my logs all setup with the suggested values. I have also slightly brushed off the rest on my excel skills on my test log, so I can graph out multi-axis values and actually show them simultaneously.
Also, I *assume* the pulls should be in 4th gear (6MT)? Thought I would double check.. my stock pulls a year ago were on the suggestion of the shop then. My last runs were one in 3rd, and 2 in 4th.
I am going to run logs, plus interior and exterior video just for fun and will compile the video and share that and the logs and dyno graphs here.
4th gear all runs if stock FMIC
5th gear all runs if FMIC/DP
Have Dyno operator start progressively at 2000 rpm and logging the dyno run until 6900rpm no less no more
Last but not least, bring a usb thumb drive so you can put your Dyno files in there
Originally Posted by F30_SixSpeed View Post
5th gear will yield the most accurate (and usually higher) numbers. It is the 1:1 gear ratio on the 6MT. I would do them in 5th.
Only downfall is if on stock intercooler, car will heatsoak a bit more up top and if the speed limiter is not removed (assuming yours is) it will hit the speed limiter.
100% i would dyno in 4th gear if on stock IC for sure
You gotta turn off DSC Off ? since car will prob cut or spin on rollers in Sport+ right?
A few things he can manipulate
- Letting car cool off with hood open
- Cool temps at Dyno or and good air-flow will help
- Leave hood open on Dyno
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce
IG: @bmwF9XG80
ceedawg467.50
SeanWRT3179.00
      03-29-2018, 11:55 AM   #24
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Yeah.. AA FMIC but still stock DP, so still 5th? Ambient temps should be ok as still cool here in the PacNW, plus 10am dyno time. Their fans look pretty good and definitely run with hood up.
Great info on RPM, thank you.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
FSociety3812.50
      03-29-2018, 12:22 PM   #25
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
USB stick to transfer your Dyno runs / dyno files
If Dynojet, get the winpep DRF file is called
IG: @bmwF9XG80
      03-29-2018, 12:32 PM   #26
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Yeah.. they were kind enough to email me the files last time, and will make sure to do the same.
Here is what I just got from AA regarding the dyno run and speed limiter:
"We always run them in 4th, the speed limiter is set to 320mph (512kph)… I think you’ll be ok. Unless the dyno facility has a fan capable of simulating 100+mph winds, I wouldn’t run it in 5th."
FSociety3812.50
ceedawg467.50
      03-29-2018, 12:42 PM   #27
FSociety
IG @bmwF9xG80
FSociety's Avatar
3813
I would take their advice
IG: @bmwF9XG80
ceedawg467.50
      03-29-2018, 12:59 PM   #28
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Are you guys also at sea level? Make sure they plot AFR/Lamda and psi also!!!!!
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      03-29-2018, 01:04 PM   #29
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I am not quite sea level, but I am sure less than 250 feet, on where I will be.
Current log set is:
AFR commanded
AFR measured
Ambient Air temp
Engine load absolute
Engine RPM
Fuel Rail Pressure
Fuel trim bank 1 short term
Fuel trim bank 2 short term
IAT
MAF rate
Speed (obd)
Timing Advance
Turbo boost and vacuum gauge
      03-29-2018, 01:10 PM   #30
ceedawg
ceedawg's Avatar
468
Current log set is:
AFR commanded
AFR measured
Ambient Air temp
Engine RPM
Fuel Rail Pressure
IAT
MAF rate
Speed (obd)
Timing Advance
I would imagine that they will be logging too so that's cool what you have there as well.
What is that you are using to log?
      03-29-2018, 01:17 PM   #31
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I am running Torque Pro via the OBD
      03-29-2018, 01:24 PM   #32
ceedawg
ceedawg's Avatar
468
Interesting! I don't have a JB4 but maybe for the time being I can use that. Is it a kit or an app?
      03-29-2018, 01:26 PM   #33
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
The Torque Pro app is available from the Play store and I use it all the time to look up codes, reset stuff etc. Then I just have a simple Bluetooth OBD adapter.
      03-29-2018, 01:51 PM   #34
ceedawg
ceedawg's Avatar
468
Please post a link for the adpt if you can ,much appreciated
Still kinda waiting for a complete commentary on how the BEAST feels in general with the AA SW especially in comparison after using the former Active 8 piggy. Maybe that will come after your dyno
      03-29-2018, 02:20 PM   #35
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
You can get the adapter from like 1,000 places, I got mine from Avin when I ordered the deck for my E46 a couple of years ago.
For the review, happy to describe what is the butt-dyno differences. The active 8 is absolutely a great product, and felt smoother than the JB4 though my sample time with that was shorter, and never got beyond map 1 or 5. A8 was a smooth ramp with a big surge around 2600 RPM that really was a kick in the pants as you crossed that line. With my other bolt ons, I was roughly 330rwp/330 torque with the A8.
The new ECU tune is a different monster and for understandable reasons. Setting aside the ability to change the sport gauges and the like, it is absolutely a more specific and I suspect more aggressive tune. The car feels MUCH stronger than before, and in what feels like a linear curve than a surge like before. If I am coming hard out of 2nd or 3rd, especially 2nd, I feel like I get some back end wiggle that I never had before stock or with the A8. With the M4 sport gauges code in place, I can easily put both needles around 370ish without any trouble, though we all know those gauges are a SWAG at best. The real test will be full dyno and logs this weekend, plus I will provide all of that back to AA for review, and any further possible modifications based on that data. In addition, I will have the AA DP as soon as they ship me one, and will dyno yet again.
I have ZERO desire to push my motor, turbo or components to the breaking point, but its clear there is a lot of ceiling room on these motors and I want to get closer to that.
ceedawg467.50
      03-29-2018, 02:42 PM   #36
XutvJet
Drives: 2011 Cayman Base, 2016 M235
You'll get higher numbers running in 5th (assuming you're not heat soaking), BUT it's a lot harder on the motor, especially in the lower rpms because you're creating a very high load situation going full throttle and 2,000rpms (i.e., low rpm, heavy boost). High load can create over-boosting at boost onset and worse, severe detonation. The 5th gear run will generate a more heat as well because......it's a much longer run. I would strongly suggest running in 4th. It's just better for the motor and you should still get very solid and usable data. If you want to know what the 5th gear numbers are, simply multiply by 1.5% and that will give you a general idea.
If it's available, run 93 octane. Put the biggest fan(s) you can in the front the IC and radiator.
FSociety3812.50
ceedawg467.50
      03-29-2018, 02:44 PM   #37
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Originally Posted by XutvJet View Post
You'll get higher numbers running in 5th (assuming you're not heat soaking), BUT it's a lot harder on the motor, especially in the lower rpms because you're creating a very low load situation (i.e., low rpm, heavy boost). High load can create over-boosting at boost onset and worse, severe detonation. The 5th gear run will generate a more heat as well because......it's a much longer run. I would strongly suggest running in 4th. It's just better for the motor and you should still get very solid and usable data. If you want to know what the 5th gear numbers are, simply multiply by 1.5% and that will give you a general idea.
If it's available, run 93 octane. Put the biggest fan you can in the front the IC and radiator.
Thanks man, I appreciate all of the info.. I will make sure they have all possible fans on (they have a bunch) and sadly its 92 octane here in WA. At least its not 91 like CA.
      03-29-2018, 03:09 PM   #38
ceedawg
ceedawg's Avatar
468
Great advice! Think FSociety mentioned that too.
      03-29-2018, 03:10 PM   #39
jh_f30
jh_f30's Avatar
1306
Just a heads up in case it applies, the Torque app is Android only. I've been running OBD Fusion on iPhone for some data logs. Not sure if it reads all the same PIDs, but without a JB4 or other tune-specific logging capabilities, it's better than nothing. Also, idk if it's just me, but I have both a Bluetooth BLE and a WiFi adapter and they seem to read slightly different sets of PIDs through the same app (OBD Fusion).
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
ceedawg467.50
      03-29-2018, 03:12 PM   #40
ceedawg
ceedawg's Avatar
468
Certainly looking forward! Great review and yes you want to run as safe a situation as possible not to hurt the motor.
      03-29-2018, 05:13 PM   #41
matty088
Drives: 335i
Shall we make a pool on what his number is? I say 325 if xdrive and 338 if not
      03-29-2018, 05:36 PM   #42
jh_f30
jh_f30's Avatar
1306
These would be whp figures right? So just to see if my math is right, if we assume 15% drivetrain loss (as Dinan calculates), 338whp would translate to around 398bhp?
Algebra was a long time ago, but I calculated:
338whp = bhp(.85) -> 85% being bhp minus 15%
338/.85 = bhp -> divide both sides by .85
397.65 = bhp right? or am I off my rocker?
      03-29-2018, 05:43 PM   #43
the dope steez
Drives: F30 335i M-Sport
You think he's losing power by going to a flash?
I'll throw a dart - 365 whp and 390 wtq
      03-29-2018, 05:56 PM   #44
Mouse
Drives: 2013F30 335i
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
