BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > MG flasher - mobile App for B58 Fxx/Gxx tuning -- NOW LIVE!!!
      04-13-2019, 02:39 PM   #265
Bavarian MW
lurker
24
Drives: 16 s1000r 17 M240i 18 340i
Originally Posted by pgadv View Post
MG Flasher states....
"Rest assured, our JR Auto Performance software is designed to keep your CVN (Checksum Verification Number) and flash counter untouched. This means our software will be virtually invisible to dealer level diagnostic tools."
Should the vehicle require a remote session with BMW Techs (such as my situation after dealer firmware update did not complete) - will their software detect that a flash was done?
This is important for those who are concerned about potential issue with warranty after a Flash - you should be 100% transparent about whether Flash is detectable at any level of diagnosis, not just Dealer-level.
It's not my intent to be accusatory, I believe there should be full disclosure so we understand whether they may be a risk if BMW itself has to do a diagnostic.
Jarek, looking forward to your reply.
We cannot ever be 100% when it comes to the questions you ask, and with ANY tune. I and many people have accepted that as fact, still have installed the MG Flash and others, and are enjoying them greatly. If you want 100%, got to give up that enjoyment.
Historically speaking most people have good luck running flash tunes and getting warranty coverage, not 100% though. There is always that thread that pops up about BMW denied this or that etc.. Extra security is just that, extra security. --MW
David0ff1059.00
      04-13-2019, 03:03 PM   #266
BLACK HAWK DOWN
BLACK HAWK DOWN's Avatar
Drives: 16' AW 340i xDrive
If you want a 100% guarantee that your warranty will be unaffected, simply do not modify your car.
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
David0ff1059.00
      04-13-2019, 03:47 PM   #267
bmw22915
Drives: 440xi GC
You're missing the point of his post...
      04-13-2019, 06:15 PM   #268
pgadv
Drives: 2018 340 xDrive M Sport MPPSK
Thanks for the feedback
I really only meant whether BMW LEVEL scan could still see the flash was applied
It appears the answer is yes based on the responses
Obviously we need to take responsibility for our choices 😀
      04-14-2019, 12:25 PM   #269
pgadv
So, I will simplify my question for Jerek:
Is MG Flasher detectable by BMW-level diagnostics?
Thanks
      04-14-2019, 01:38 PM   #270
G.Newt
Drives: CT4-V Blackwing 6MT
Thanks
Hi, I see you're new here. This question has been asked and answered a few times.
If you break your engine BMW will find out.
Are they deep diving investigation during an oil change? Probably not.
If you break something, a PUMA case will be opened and they will find out.
      04-14-2019, 01:52 PM   #271
pgadv
Thanks GNewt
My post is not about BMW doing a deep dive due to damage
I stated that BMW TECHS had to do a firmware update remotely because the dealer couldn’t complete it
My question is whether that routine process would detect the flash - seeing as BMW is doing it and not as the dealer?
That is the real point of my post
Cheers 😀
      04-14-2019, 02:18 PM   #272
G.Newt
Thanks GNewt
Cheers 😀
Ah gotcha. In that case, it's recommended to return to stock and relock the DME before bringing it in for service. Just in case to not set any red flags. It's really up to the dealer/service advisor IF they did notice it and whether or not to mark your car.
      04-14-2019, 02:23 PM   #273
pgadv
Right....
Soooi, now to my question
When it’s returned to stock, can BMW TECHS determine it was previously flashed? The reason I bring this up is because MG’s reference to flash being undetectable is in reference to Dealer service only?
Hence my requesting Jarek’s clarification
      04-14-2019, 02:40 PM   #274
G.Newt
Right....
Apologies for my slowness. Don't do dabs and forum.
That's generally true, even across most of the flash tunes. Dealer-level diagnostics will be mostly blind to legit flash tunes. They're all doing similar things to mask so it makes sense their behavior is the same: dealer-level is okay, BMW-level is bad news lol.
Beek707.00
      04-14-2019, 02:42 PM   #275
pgadv
Thank you
      04-14-2019, 09:12 PM   #276
Beek
Beek's Avatar
Drives: Most folks crazy.
[QUOTE=G.Newt;24653962]Apologies for my slowness. Don't do dabs and forum.
Rocky Mountain high?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter.
G.Newt810.00
      04-15-2019, 01:44 PM   #277
Jarek@JRAuto
Jarek@JRAuto's Avatar
Drives: G20 340i
Is the flash undetectable by the dealer?
There is no tune on the market which is undetectable.
We can only guarantee with MG Flasher that CVN number (Checksum Verification Number) along with flashing counter stays untouched and we advise to flash to stock (short flash) every time before visiting the service to keep all parameters stock and avoid visual suspected signs of altering the software such as gauges calibration, cold start delete. You don’t need re-lock your ECU.
BMW ECU stores historical data values/logs called Fasta Data which can be read by dealer level tools – but it may only be reviewed in specific situation to qualify warranty repairs (blown turbo, engine damage etc).
Normal, everyday service procedures including software update are done without deep investigation – dealer operates as every work shop – repair, warranty, recall, has to be done on time so technically you don't have to worry about servicing.
If you are not comfortable to do modifications to your car and you want 100% guarantee simply avoid software modification or any hardware mods - wait until warranty expires.
      04-15-2019, 01:52 PM   #278
Jarek@JRAuto
Drives: G20 340i
MG Flasher - some important facts
In response to many questions and some false information posted by various individuals across multiple forums we would like to clarify some things.
MG Flasher does not flash over your original, specific, dedicated software for your car with another general (SWFK) data calibration version.
CVN number (Checksum Verification Number) along with flashing counter stays untouched.
We built the application logic, lookup functions and tables in our internal database along with the scripts to identify all differences between different SWFK (data area) versions and only apply proper changes, updates and corrections to the same calibration stored originally in the car without altering or ignoring changes between your chassis and its original calibration.
Upon first connection to your vehicle MG Flasher runs a process labeled “Check for Support” and on each flash attempt performs a sanity check which verifies all pertinent data including the bootloader, internal code section and the map data area. With all this information it is virtually impossible that your ECU will be flashed with wrong calibration.
Our database contains almost 400 original and updated calibration versions (only B58 Fxx) for all markets: EU6, EU5, USA, JPN, CHN, ECE and different models such as F20, F22, F30, F31, F33, F34
Flashing the same data - general calibration to all B58 equipped Fxx chassis is not exactly possible since there are too many differences between calibrations i.e. country designations, driveline configuration, transmission type, software type etc, so if car is flashed with a different software you will be able immediately find out after the first test drive if your car is having some issues and is not driving properly.
We stand by our product and ensure that each and every one of our clients will be taken care of in terms of support for any issue related with flashing.
G.Newt810.00
David0ff1059.00
BackBlue107.00
      04-16-2019, 03:26 PM   #279
pgadv
Jarek
Thank you for your detailed explanation and clarification of my question.
I really appreciate it and can now make an informed decision.
I know first time “flashers” (pun intended) will appreciate it as well.
      04-16-2019, 03:31 PM   #280
henkherrie
Netherlands
19
Drives: 2016 M140i
Thanks for the update on the app Jarek.
Maybe got an updated version of the custom ST2 map also?
      04-16-2019, 07:49 PM   #281
bmc340
Drives: 2016 340i xDrive
I really want to go Stage 2 and wondering where I can get a good trans (TCU) flash from to handle the additional torque. Anyone have any tuner suggestions?
      04-17-2019, 01:56 AM   #282
x5mad
x5mad's Avatar
Drives: iX 40
bmw  [0.00]
i just bought the logger app and did 5 runs with it. However, I have never logged before and really don't know what i am looking at. I flashed stage 2 93 octane map.
Could someone be kind enough to have a look and see what they think?
Also, I do want to learn so if there is a basic 101 on how to read logs as well as which parameters are important to log then im keen to read and learn.
On the power and torque screen I am only getting up to about 400-420 bhp and 550NM. Ive seen others going all the way up to 460/640. There is no definitive answer as to whether its just for show or whether it is a function of x y z to determine approx numbers. Its all speculative at present so lets not get into that. But I do believe there is some truth to it as I have in the past seen lower numbers and indeed it was the wrong tune, which I could see and feel.
Again I do feel like the car is stronger but not as strong as it should be. It does feel around 410hp and 550Nm torque as per the dials.
The point though is not to argue the dials (that's a whole other huge argument not for here), just whether someone could look at the logs and see if there are any reasons for the suspected lower power and torque im feeling. Thanks!
Note the files are uploaded as txt but needs to be changed to xlsx as it wont let me upload as xlsx
I tried to include the parameters which I thought were important and did a few different runs.
      04-17-2019, 12:18 PM   #283
Jarek@JRAuto
Drives: G20 340i
Please send all logs in original *.csv format to support@mgflasher.com. I will be happy to explain how to read and understand basic.
      04-17-2019, 07:16 PM   #284
TreDirtyFive
Drives: X3 M40i
Middle-Upper RPMs pulling throttle...bad gas?
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      04-17-2019, 08:03 PM   #285
Jarek@JRAuto
Drives: G20 340i
@x5mad The problem is that you are hitting transmission protection limiter (Getriebeschutz).
You can't use ST2 with stock 8HP software - you need to program your 8HP or use our ST2 custom stage see post #196
Feel free to flash ST1 and perform all logs again in proper format I sent to your email please.
I'm going to create new - separate thread or MG Flasher users group for logs and deeper technical discussions.
      04-18-2019, 05:41 AM   #286
BackBlue
BackBlue's Avatar
Drives: E46, '13 E70 N63, '19 F33 440
You can't use ST2 with stock 8HP software - you need to program your 8HP.
Jarek@JRAuto You have stated right here in this thread that you have a custom tune that address this specific issue with our auto trans. Now the only option is ST2 ? What gives??? Is it no longer available or did it not work as intended?
Update us please!
