BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > fitting Bilstein B8s and coding out EDC
      08-21-2021, 10:54 AM   #1
KevM3UK
Drives: E92 m3
thinking of buying a 14 435i after a owning a few M cars I'd like to sharpen up the handling, looking at fitting some Bilstein B8 shocks, and lose the EDC or what ever you call the electronic shocks, is it easy to code out and have fixed shocks?
      08-21-2021, 12:46 PM   #2
Tengocity
Tengocity's Avatar
Scotland
8566
Yes. You can do it two way- hardware via EDC delete modules, or coding. I used Zed coding to do my 340i. Have used him a few times and would highly recommend.
McBeemer261.00
      08-22-2021, 04:36 PM   #3
dizzy619
Drives: F31 340i
What Tengo said...
      08-22-2021, 04:41 PM   #4
cfm56d7b
How many miles does your car have?
B8 shocks are typically used with lowering springs. The expense of shocks + springs approaches coilover territory. Worth considering.
      08-23-2021, 06:18 AM   #5
KevM3UK
Drives: E92 m3
cars done 80000 miles, ill be pairing them with h&r springs along with refreshing the front bushes
sspade2464.50
      08-23-2021, 12:23 PM   #6
johnung
B8's with H&R springs is going to be pretty stiff. An alternative to consider that is also designed to drop is Koni Sport Yellows which are adjustable for comfort, along with Eibach Springs. B8's are just set stiff at factory. No adjustments. Eibach springs are about 10% stiffer than stock while H&R's are more teeth rattling at about 30% stiffer.
      08-23-2021, 01:43 PM   #7
KevM3UK
Drives: E92 m3
That’s all right, I’ve had for E92 M3s with pretty stiff suspension in sport edc, along with an e46 m3 with countless suspension setups over the years I owned it, had to step away from M cars at the mo , work dictates, so looking at a 435i
johnung4528.00
