08-23-2021, 08:28 AM | #1 |
Rep 117
Headlight adapters.
Can anyone help me please. If I was to fit some h7 leds in my car can anyone tell me which adapters I would need please.
Mine is a f30 lci 2016. I've looked and there are quite a few and I'm just not sure. Thanks for the help Stu |
08-23-2021, 09:14 AM | #2 |
Rep 573
Putting LED's in a reflector style lens is going to just blind oncoming traffic and you'll just get sick off been flashed.
If you want to improve the light output I would suggest you swap out the headlights for an aftermarket option with projector type lens. This will give you the sharp cut off line you need with LED/Xenon bulbs to avoid blinding oncoming traffic. The other issue with LED's is the varying ways the chips are mounted on the bulb. Even with projector style lens it can still throw the beam out. I fitted some LED's to the Qashqai (projector lens). I bought LED bulbs that you can rotate to 'focus' the beam to get the cut off line required. Without this feature even in the projector lens it would've been a no go. |
08-23-2021, 08:06 PM | #4 |
Rep 117
Ok thank you both. I just saw a video on YouTube that showed led bulbs fitted in my car and the beam pattern was pretty much the same.
I'll knock the idea on the head. Thanks again for the replies I appreciate it Stu |
