BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
      03-30-2023, 09:16 AM   #243
shawnsheridan
shawnsheridan's Avatar
Originally Posted by canufeelit View Post
Hey Shawn,
I am looking for the 9C FSC code. Are you able to help me out, please?
Thanks!
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      04-03-2023, 08:43 AM   #244
shawnsheridan
Originally Posted by Junior2101 View Post
Hey Shawn!
Do you have any advice for me for the bmw apps on my NBT system? Is there any way to activate those knowing that my BMW Connected is no longer subscribed
Thanks alot!
PM sent.
      04-11-2023, 01:39 AM   #245
BimmerLubuskie
BimmerLubuskie's Avatar
Poland
Drives: BMW F30
Can i get info about CHAMP2? Latest iStep firmware, BMW F30 07/2012.
Voice Control - change language from DE to EN/PL.
Apps/Live/Online/ConnectedDrive Activation?
Use INTERNET from Tehering Phone?
Custom system like CIC Portal?
Change/Modify internal system SDcard?
Anything more can be done?
      04-11-2023, 08:39 AM   #246
Luigi_S
Luigi_S's Avatar
Drives: 330d M sport Plus
Just came across this thread. I am a little confused, my car came with apps from factory on unlimited subscription but I cannot find any apps on the system. All I want is to access Spotify on my 2014 with Pro nav using my Android. What do I need to do to do this?
      04-11-2023, 10:14 AM   #247
shawnsheridan
I have no experience with CHAMP2 Head Unit.
      04-11-2023, 10:18 AM   #248
shawnsheridan
Spotify is not supported on ConnectedDrive anymore. This happened after their Jul 21 update, in 8.5.68.904. Uninstall the updated version from phone then downloaded and install version 8.5.66.1002.
      04-11-2023, 01:32 PM   #249
Luigi_S
Luigi_S's Avatar
Thanks, but the problem I am having is that when I connect my phone and go to connection assistant, it keeps telling me to install the BMW connected App which apparently no longer exists so cannot get past that on the I drive.
      04-11-2023, 02:47 PM   #250
BimmerLubuskie
Poland
Drives: BMW F30
Thanks for respond boss.
      04-12-2023, 09:42 AM   #251
Luigi_S
Luigi_S's Avatar
shawnsheridan Any idea how to access apps on my car? I get to this screen and can go no further. I have the My BMW app installed, but it doesn't seem to do anything.
      04-12-2023, 12:14 PM   #252
shawnsheridan
PM sent.
      07-02-2023, 10:05 AM   #253
mahosa
Drives: E91 2011
Hi Shawn,
Can you please send me the instructions on how to activate 6NR Apps on my 2011 e91 with CIC?
Thanks
      07-02-2023, 10:07 AM   #254
shawnsheridan
Originally Posted by mahosa View Post
Hi Shawn,
Thanks
PM sent.
      08-18-2023, 03:38 AM   #255
mavericknik
Drives: None
HI Guys! I'm pretty new to BMW coding and wanted to get the BMW Apps option in my 2018 440i GC with NBT EVO ID6. I've been reading up around here and there's just so much info to parse through, I am a little confused. shawnsheridan Would appreciate some help if possible!
I purchased a set of fake fsc codes since I have the EVO and the seller told me he enabled the apps option as well. I installed the fsc codes using featureinstaller and am able to update maps to latest so that worked but didnt see apps. Is there some way to verify that the codes he gave me have the apps option?
Also, I understand I will need to update the VO of my car to have the 6NR option. To do this, should I:
Revert to stock FSC using featureinstaller backup --> load VO in esys --> add 6NR to VO --> Code HU_NBT2 --> reinstall fake FSC using featureinstaller --> DONE!
Or can I take a shortcut since the fsc are already installed and do:
Load VO in esys --> add 6NR to VO --> Code HU_NBT2 --> DONE!
After I add 6NR to the VO and activate the FSC code is there anything else I will need to do?
Also, if I am jsut reading the VO, adding 6NR and then pressing code on the HU_NBT2 ECU, will I need a launcher or can I just use plain esys?
      08-18-2023, 09:40 AM   #256
shawnsheridan
You don't need to do a restore. You can add 6NR to FAC and VO Code HU_NBT2.
BMW Apps requires discontinued ConnectedDrive App though. It wont work with nw MyBMW App. And this is for Android devices only, not Apple.
      08-18-2023, 10:11 AM   #257
mavericknik
Drives: None
Great, I'll try to do the coding and report back.
So is there no way to tell what the contents of my fsc code are and I just have to trust the seller when he said he enabled apps?
I'm doing this to try to get AAIdrive to work, which I understand requires the apps option. Trying to see if I can get by without android auto. Thanks for the help!
      08-18-2023, 10:15 AM   #258
shawnsheridan
You can VO Code with 6NR and revert by removing 6NR and VO Coding it again.
You can check FSC Code Status and see if 9C FSC Code is Status = Accepted.
      08-18-2023, 04:28 PM   #259
mavericknik
Drives: None
I'm a little confused now, I checked the FSC and I do see that the 9C fsc code is enabled:
Code:
AppID 156(0x9C)
UpgradeIndex 1(0x01)
SWTType SWTclassic light
FSCStatus accepted
FSCCertStatus not available
After I installed the fake FSC a couple days ago, I did not see any apps option. However, today when I get into the car, AAIDrive connected and now I am able to see a check box with "Apps" under my phone connection. AAIdrive also shows connected to the car (it shows NBTevo_ID5 for some reason, I think i have ID6), so all well and good. But I thought let me just connect esys and check what my VO has, and here I see no mention of 6NR! This is what I have in my VO:
From what I can see, maybe this is giving me the apps option from my VO?
S6AKA - ConnectedDrive services
S6NHA Hands-free Bluetooth and USB audio connection
Is there some place I can compare 6AK/6NH vs 6NR? I'm wondering if adding 6NR to VO has any benefits. I don't see any mention of 6NR in the 2018 ordering guide here:
https://f30.bimmerpost.com/forums/sh....php?t=1393556
      08-18-2023, 04:31 PM   #260
shawnsheridan
Code:
AppID 156(0x9C)
FSCStatus accepted
6NR was replaced by 6AK. You have what you need.
6NH has nothing to do with ConnectedDrive / BMW Apps, although you should replace it with 6NS for Enhanced Bluetooth.
      09-17-2023, 10:23 AM   #261
Blekota
Drives: BMW F11
Hello Shawn,
Can you please check if possible activate 6NR Apps to VIN: C764852? Understand need 9C FSC, but u writing BMW Apps discontinued ConnectedDrive App though, can use AAIDrive with Android prone at CIC_HU (609). And add 6NF - smartphone integration needs FSC. Thank you for help
      09-17-2023, 10:31 AM   #262
shawnsheridan
Originally Posted by Blekota View Post
Hello Shawn,
Car has both 609 CIC and 6VC Combox, so 9C FSC Code and 6NR BMW Apps Coding i supported.
      09-18-2023, 07:31 AM   #263
Blekota
Drives: BMW F11
Thank you Shawn for your quick reply. Can you please send me instructions on how to get 9C FSC and add, load to esys (hope understand all previous instructions steps to add 6NR and code) Thank you
      09-18-2023, 09:27 AM   #264
shawnsheridan
PM sent.
