10-25-2017, 08:57 AM | #1 |
Rep 8
Turbo upgrade for n47
What is available as an upgrade from my twin scroll.
I want to be around 400hp but I'll have get a better turbo and get cams or cam. I know it's going to be alot of work but this is my project car |
10-25-2017, 12:46 PM | #2 |
Rep 3,216
400 hp out of a 2.0 diesel ?
Engine and gearbox will have virtually zero life expectancy. The entire engine is wrong for what you're trying to do. The engine was designed for large amounts of torque, moderate amounts of HP - because that's where a diesel like that is fuel-efficient, which was the other big design criteria. Put that amount of hp through it, and you'll destroy the clutch and DMF - and if you swap the DMF for a single flywheel, then you'll push all that power and torque through to the gerbox, and break that. |
11-01-2017, 04:52 PM | #3 |
Rep 91
Drives: 2022 BMW M5 Comp
Honestly, I think this is the wrong car to go for a project like that. You'd be better off starting with an E90 335d. Two extra cylinders plus an extra liter of displacement would help achieve your goal. That's if you want to stick with a diesel.
Otherwise a 335i or 340i will get you to those power levels with much less money and work. Just my 2 cents...
2022 M5: MBB/Aragon Ext Leather/ZCP/ZEC/789M' Wheels/Alu Carbon Struct Dark Trim/Red Calipers
2021 X5 sDr40i: Jet Black/Ivory White Ext Merino Leather/ZP2/ZPK/20'' Wheels (738)/Multi-Contour seats, Htd seats/armrests/steering wheel |
01-31-2018, 05:38 PM | #4 |
Rep 37
Impossible. With a turbo, intercooler, injectors, DPF off and EGR off you can make 300hp max.
04-07-2018, 10:51 AM | #6 |
Rep 3,535
I wonder how much more boost you'd be looking for in a turbo since the stock one does 26PSI (28 with stage 2 tunes). I'd want a turbo with less lag since ours is only a single scroll.
04-11-2018, 12:22 PM | #7 |
Rep 308
I was able to peak 29psi when breaking in my car. Now I have 45XXXKM and never see 29psi.
2017 F31 328d xDrive
M Sport M Performance |
04-27-2018, 09:29 AM | #8 |
Rep 22
how are you measuring this ?
Alan W
2014 328d SportWagon - Liquid Blue metalic over Black Dakota CPO'd 05/17 with 22K miles Driver Asst. / Driver Asst+ / Dynamic Handling / Lighting / Premium / Tech / Active Cruise / HK Audio / |
04-30-2018, 07:58 AM | #9 |
Rep 308
Banks Power iDash :
Boost Engine coolant temp IAT EGT LOAD EGR cycle Battery
02-23-2021, 07:26 AM | #10 |
Rep 7
03-02-2021, 07:14 PM | #11 |
Rep 37
