01-08-2019, 06:29 AM | #1 |
Rep 1,601
Stages of Naturally Aspirated Engine Phase-Out Grief
So we all know about the trend towards turbos and away from normal aspiration.
I tried to resist but in the end could not simply find a normally aspirated car that otherwise met my parameters...and so I ended up in a 2018 m240i with the b58, which is one of the least laggy motors out there...but alas there is still lag. I have come to recognize the stages of the loss of normal aspiration grief as follows: 1. shock...my test drives of the b58 didn't unmask the extent to which turbo lag still presented itself in everyday driving...in my first couple days of everyday driving, I was shocked at how present lag still was 2. Anger...I felt cheated, I thought the b58 was the unicorn, the one turbo motor that didn't feel like a turbo motor, but alas it wasn/t 3. Denial...for a while I told myself it didn't matter, turbo lag so what, no big deal, I am getting used to it, car is still blindingly fast so what if there is lag and less connection 4. Acceptance...I finally moved to a place where I realized turbo lag was real and it did matter in my driving experience. I didn't feel as connected to the drive as I did with my normally aspirated cars. But I moved on to accept that this just a reality of our modern driving experience, and to live with it 5. Hope...the final stage I've arrived at is to recognize that one day I will be back with normal aspiration and I when I am in a place again in life where I can have a wonderful torquey normally aspirated car with a manual transmission I will hold on to it, until and unless they start making them again. Hope this post helps other NA mourners out there You are not alone |
01-08-2019, 06:51 AM | #2 | |
Primo Generalissimo
4675
Rep 4,026
Drives: All of them
Garage List 2017 Porsche 911 Ca ... [10.00]
2023 BMW M2 [9.00] 2023 Porsche Macan GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
01-08-2019, 06:56 AM | #3 | |
Rep 1,601
the f type R is an absolute riot and has so much immediate low end torque...I do wish it came in a manual, but it's still a contender for the car I hold onto |
01-08-2019, 06:57 AM | #5 |
Primo Generalissimo
4675
Rep 4,026
Drives: All of them
01-08-2019, 08:38 AM | #7 |
Rep 3,034
I know you say you know the difference but are you SURE it's not throttle lag? It staggers me how much throttle lag there is programmed into BMWs.
On a related note, I am beginning to shop for a toy car or angry DD and I have it down to three cars, 911 S, Mustang V8 or rod bearing M3. Notice a trend? |
irishbimmer1139.00 |
01-08-2019, 09:55 AM | #9 |
drunk poster
6614
Rep 3,649
I’m curious, what were your “NA parameters”?
My powertrain parameters for a fun car have usually been NA, MT, RWD, sounds great, and high revving if possible. There are still a precious few of those cars out there, but (a) not for long and (b) not for cheap. Your “hope” stage is probably never going to pan out so my plan is to hoard these cars till i die. |
01-08-2019, 10:56 AM | #11 |
Rep 1,881
BMW died in my eyes after the s65 stopped production.
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
inTgr8r2433.50 |
01-08-2019, 11:07 AM | #12 |
Rep 1,597
I drive in Sport+ and the turbo lag is nowhere. Other makes have a real turbo lag problem.
irishbimmer1139.00 Captain Blood13871.00 |
01-08-2019, 08:06 PM | #13 |
Rep 1,561
Gotta say in sport plus there is no turbo lag-and when moving into higher rpms the performance is sensational.
01-08-2019, 08:39 PM | #14 |
BXR
575
Rep 636
I mean....I get that lag is a bummer, but I'd rather have a little bit of lag and 300hp than no lag and 200hp.
2012 135i M Sport Alpine White
01-08-2019, 09:05 PM | #15 | |
Rep 2,738
OP I feel you. I’m also committed to N/A (and 6MT lol) Last edited by Biginboca; 01-08-2019 at 09:16 PM.. |
01-08-2019, 09:21 PM | #17 | |
BXR
575
Rep 636
Generally I was comparing the 128 and the 135. And BMW does a lot of trims that way. The kind of money you have to put into an NA car to get similar power gains (at least for the little inline six's that BMW uses) is pretty outrageous.
01-08-2019, 09:31 PM | #18 |
Rep 2,738
That is right on point, and sadly I’m very familiar with this topic lol. The only thing I’ll add is that alot of the money for the n/a mods is recovered in the lower purchase price of the N/A car. So if it cost $2500 to add 70hp to the n/a car usually the n/a car is priced around $2k less also.
01-08-2019, 09:44 PM | #19 | |
BXR
575
Rep 636
01-08-2019, 10:44 PM | #20 |
Rep 3,472
Given the difference between my bmw driving modes and driving old school turbo cars, it’s not turbo lag when you are driving modern turbo cars (hot-v, short headers, twin scrolls, etc.) that produce full torque at 1500-1700, its throttle response and the automatic transmission. If you are feeling significant turbo lag, IMO you don’t know what it’s like to drive a car that needs 2800-3000 rpm before it wakes up and one that WILL NOT climb to that rpm under load in too high of a gear.
3798j11479.50 Viffermike1753.00 |
01-09-2019, 05:37 AM | #21 |
Rep 18,762
Sorry for the edit... but there is a 6th stage :
5. Hope...the final stage I've arrived at is to recognize that one day I will be back with normal aspiration and I when I am in a place again in life where I can have a wonderful torquey normally aspirated car with a manual transmission I will hold on to it, 6. Pipe Dream...until and unless they start making them again.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
baege1335.00 |
01-09-2019, 06:06 AM | #22 |
Rep 6,301
