05-18-2019, 11:19 AM | #1 |
Rep 928
Good alignment specs?
How are my settings? This is with the powerflex adjustable camber bushings up front.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
05-18-2019, 04:08 PM | #2 |
Rep 241
confused. looks like everything is in the stock ranges. I would have expected to see more camber up front. the F30 begggggs for more camber up front. I would get to 1.5 at least if you can. everything else seems fine.
05-18-2019, 05:50 PM | #3 |
Rep 928
The bushings only neted .5 deg camber
05-18-2019, 06:37 PM | #4 |
Rep 241
ah. well every little bit helps. I'll recommend the F80 arms. they really helped me.
05-20-2019, 02:19 PM | #5 |
Rep 129
Hijacking thread.
Should I get an alignment before track season starts? Stock suspension so no lowering, but not sure how off it is off from all the potholes over the winter. Last edited by reyoasian; 07-20-2020 at 01:57 PM.. |
05-22-2019, 09:50 PM | #6 |
Rep 8
I can't speak to potholes. I got an alignment last season while still stock, to get some camber in back and some of the toe out in front. I think it helped a little. The rear tires certainly wore a bit more evenly.
05-24-2019, 08:10 AM | #7 | |
Rep 129
Too bad camber is not adjustable up there though, would prefer more camber up front as well. My tire wear isn't bad but it's definitely not even. |
06-27-2019, 06:53 AM | #9 | |
Rep 345
10-14-2020, 11:37 AM | #11 |
Rep 928
Running fortune auto coilovers with camber plates now and neg 1.5 camber up front and had to dial in neg 2.3 camber in the rear to fit my 275/30/19 on 19x9.5 et35 wheels. We're actually going to take out a little more camber in the rear to like neg 2.0 or 1.8 cause i originally was on 275/35/19 tires when alignment was set.
10-14-2020, 11:41 AM | #12 | ||
Rep 928
10-16-2020, 02:59 AM | #13 | |
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
05-28-2021, 12:19 PM | #14 | ||
Rep 928
05-28-2021, 12:57 PM | #15 |
Rep 14,115
Oversteer changes what direction your car is facing(rotation) but it won't always necessarily change the direction your car is traveling(vector). So you can create the rotation with throttle and weight transfer, but the camber will actually help you get the grip needed to make the turn and hit the apex.
05-28-2021, 05:05 PM | #16 | |
Rep 928
05-28-2021, 05:56 PM | #17 | ||
Rep 14,115
In general a little oversteer is better than understeer, but predictability is actually what you are looking for. Gradual traction loss that translates to the driver so you know when you are at grip limits. That is accomplished through the tires and suspension. Playing with camber, castor, rebound and spring rates so that upsetting the car is minimized during weight transfer and by road/track conditions.
Foxtrot3Zero148.50 |
06-04-2021, 10:28 AM | #18 |
Rep 289
Here is mine.
I'll be maxing out my camber plates later today. Trying to get to around -3.1 front This is official BMW KDS so it reads in degrees then minutes. 60 minutes = 1 degree. |
