03-23-2021, 02:53 AM | #3081 |
Rep 6
03-23-2021, 04:43 AM | #3082 | |
Rep 1,048
Kri |
pandetta90ct0.00 |
03-23-2021, 08:38 AM | #3083 |
Rep 4,903
03-23-2021, 08:47 AM | #3084 |
Rep 4
03-23-2021, 10:03 AM | #3085 |
Rep 12
I have followed this thread for quite some time now and after a year or two I still haven’t seen anyone list the screen variant that I have... Figured I would share. It is the 1920x720 with 4Gb Ram, Snapdragon 625 w/LTE and the deep black screen/antiglare screen. It is manufactured by Carnavi (Carnavi was one of, if not the first makers of the 1920x720 antiglare). It has an MCU identifier of dALS. If someone would be willing to tell me how, I’m willing to extract and upload the MCU file for others if they need it. I have attached a picture of the MCU version string.
03-23-2021, 10:23 AM | #3086 | ||
Rep 1,048
This is an english speaking community Quote:
Thats not an uncommon Headunit, if you check the 1st page, you will find out that there are already two updates available for your MCU Btw. Its not possible to extract the MCU from the headunit with our resources. Kri Last edited by Kri; 03-23-2021 at 11:24 AM.. |
03-23-2021, 10:53 AM | #3087 |
Rep 12
Oh gotcha, I didn’t realize the mega folder already had MCU files for dALS. Thanks for the clarification!
03-23-2021, 06:10 PM | #3088 |
Rep 71
Hi guys. I've received the Fiio K3 USB DAC today. As soon as you connect it, you notice the quality increase. The problem is that sometimes when I start the car it doesn't works. I have to manually disconnect and reconnect the DAC and then it starts working, is that normal on this device?
And another question: I have an aftermarket backup camera but I can't figure out how to separate the parking lines to match the real size of my car. As you can see on the image, the lines are closer from what they have to be. Last edited by coniman; 03-23-2021 at 06:57 PM.. |
03-23-2021, 07:48 PM | #3089 | |
Rep 26
DAC Location
03-23-2021, 07:50 PM | #3090 |
Rep 26
LTE Settings for Verizon in USA?
Hi All,
I'm using a Verizon SIM Card in my unit, but don't get a consistent connection.. What settings do you recommend in the Cell menu? Thanks! |
03-23-2021, 09:56 PM | #3091 |
Rep 399
May I ask what you do to seal the camera from outside? I just got a replacement camera after the first one stopped working after a couple of car washes.
03-23-2021, 09:58 PM | #3092 | |
Rep 71
I also have problems with 4G using Movistar in Spain, sometimes it doesn't works and I have to turn on and off airplane mode. |
03-24-2021, 01:35 AM | #3094 |
Rep 353
03-24-2021, 02:06 AM | #3096 | |
Rep 353
That total sealing definitely helps, especially in the hard and contrast weather conditions that we have in my area) |
Mjam133.50 |
03-24-2021, 02:23 AM | #3097 | |
Rep 353
Make sure you're using 2.3.6 firmware + Sound Restorer v1.2, your media sound level in Android settings is on max. In my E70 it works like a charm but on F30 yesterday I noticed strange behavior when compared with/without DAC - android gets stuck and I could not access android sound settings, perhaps it doesn't like hot connection/disconnection. Regarding the reverse camera lines unfortunately there's no possibility to calibrate them as like in oem camera. These android lines are indicative, don't reflect the actual width of the car. |
03-24-2021, 05:45 AM | #3098 | |
Rep 25
Thank you very much for your prompt reply and for always being helpful! I think I'll have to wait for my unit to arrive to determine what type of harness it comes with. From what I can tell from online video installs, it appears that not all harnesses have both AUX IN and AUX OUT mini-jacks available and connected to each other like yours and some others. Any thoughts? |
03-24-2021, 07:19 AM | #3099 |
Rep 4
Ciao ragazzi , io ho un head display Coika , quindi fake almeno credo , potete vedere questo video ? , pure io ho questo tipo di setting , ma in questo video ci sono piu funzioni di setting . Posso mettere questo software ? questo nel video e' id7 ? grazie
03-24-2021, 07:42 AM | #3100 |
Rep 2,369
Drives: E63 645Ci
Dude, this is English speaking forum...
03-24-2021, 07:52 AM | #3101 | |
Rep 353
What is the seller you purchased it from? |
03-24-2021, 10:20 AM | #3102 | |
Rep 25
I believe their units are dGS, based on the System Info screenshot they sent me. |
