07-26-2019, 11:15 AM | #23 |
Rep 1,375
I would have to agree with akgambino. RPM doesn't climb that fast in a log unless it's one of two things. Either the clutch is slipping or loss of traction. Is also occurring right where torque is hitting strong. I honestly don't think your loosing traction in 3rd gear at your boost levels.
akgambino271.50 |
07-26-2019, 01:58 PM | #24 | ||
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
07-26-2019, 01:59 PM | #25 | |||
Rep 529
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
07-26-2019, 05:43 PM | #26 | ||||
Rep 323
07-26-2019, 06:15 PM | #27 |
Rep 1,375
I feel for ya man. I would be beyond frustrated if I were in your shoes with your situation. If I waste more than $50 fixing something that "didn't need fixing", I'm irritated. I hope you get it figured out. Do you mind sharing how you're sure it's not clutch?
13blk335ix74.50 |
07-26-2019, 06:32 PM | #28 |
Rep 1,105
Im just hear for the comments lol Hope its not the clutch because you will be eating crow my friend!!
13blk335ix74.50 |
07-26-2019, 08:59 PM | #29 |
Rep 323
i beleive its not the clutch because stutter will completely go away! then comes back hard
07-26-2019, 09:03 PM | #30 |
Rep 323
it used to be really bad. all the way through the powerband but it got better with xdi hpfp and spark plugs, coils. when i turn boost by gear down 10 percent it dosnt happen at all.
i reflashed to bm3 stage 2 from my custom tune and it went away for now. when i first got custom tune it only happened onve and was gone for a month. then came back. if it was clutch wouldnt it get progressively worse? |
08-04-2019, 11:43 AM | #31 |
Rep 323
http://www.bootmod3.net/log?id=5d4501b6c090c60de425d91c
http://www.bootmod3.net/log?id=5d450164c090c60de425d91b http://www.bootmod3.net/log?id=5d450057c090c60de425d919 logs with xdi 35, 335ixdrive 6mt stage 2 tune new ngk plugs and coils |
03-25-2020, 05:54 PM | #32 |
Rep 53
Was this issue rectified? I'm chasing exact same issue on my car (S55 6MT) pulls fine on stage 1 tune but stage 2 causes stutter around 3k RPM then pulls hard to redline.
03-25-2020, 07:09 PM | #33 | |
Rep 529
Oh and I'm pretty sure he started a bunch of threads and commented in other clutch slipping threads looking to upgrade his slipping clutch. That being said, f80 doesn't suffer from the weak clutch in the f30 so would suggest you send logs to ptf for review and comment. Good luck.
04-03-2020, 08:32 AM | #34 | |
Rep 529
04-03-2020, 11:40 AM | #35 | |
Rep 7,598
02-21-2021, 09:18 AM | #37 |
Rep 529
OP made a few threads about what is needed to replace/upgrade clutch because... this was all because his clutch was slipping lol
12-13-2021, 10:28 AM | #38 |
Rep 33
Gentlemen.....Had the same problem and thought it was coils, plugs, bad turbo, or bad motor. Like a few heads above have mentioned, IT WAS THE CLUTCH!! To all my 6spd heads: Check in with your clutch and see how long its been since it got replaced. Mine had almost 80k mi on it and I believe the flywheel was the original one with 113k mi.
I ended up getting the LuK 550i clutch kit with a LuK DMFW. With the ECS clutch pedal bump stop, it grabs super early - perfect in my opinion - and is suuuuper smooth. And while I've been breaking it in for the first 300mi, I've given it some gas here and there and theres no more hesitations on this custom tune I'm in the process of dialing in with Cary Jordan. Speaking of, Cary was the one that clocked that it was the clutch giving me issues based on my logs. |
