02-27-2020, 03:38 PM | #1 |
Rep 3
F30 335i 2012 N55 overheating
Hello,
I had a leak from my oil filter housing. I fixed that by changing two gaskets on both sides of the oil filter housing, one of which connect the filter housing to the oil cooler. I followed the following procedure: I lost coolant during the repair and I forgot to top the coolant. I drove the car to work the next day, the heater didn't work. I also noticed the coolant feed line connection (part no. :11537598237) had a leak which I fixed by using silicon ( I needed to disconnect the feed line during the first repair to get access to a bolt). The car currently has no leaks on the coolant and oil system. I drove the car the next day, I got an engine overheat warning. Then I realized that I am so low on coolant. I added coolant and didn't receive any warning ever since. The heater started to work again. The oil is running high though. I am close to 120 C (250 F) which is unusually high. I live in Vancouver Canada, with a temperature of around 8 C (45 F) this time of the year. What would you think is causing the overheating? did I damage the coolant system by running it at below low mark? can something block the coolant system? is there any diagnostic test that I can do? Thanks for your help. |
02-27-2020, 04:28 PM | #2 |
Rep 1,906
Water pump or thermostat are possibilities- getting the fault codes read is good place to start.
Moderate temp rise is not an issue; but large overheat can do significant damage very quickly. Go on YouTube and lookup 'hidden menu' for F-series cars; it will show you how to use cars onboard computer to read coolant temp in real time. You may have air entrapped in the coolant- that will mess with operating temp. Run a bleed cycle. |
02-27-2020, 04:52 PM | #3 | |
Rep 3
335i, coolant, f30, n55, oil cooler, overheating |
