03-18-2020, 03:32 PM | #1 |
Rep 63
N55 oil cooler upgrade
I have a 2014 f33 N55 with the oil cooler but I want to upgrade the lines. I can't find the adaptors that work for the F series N55. They look the same but IDK if they will work. I don't want to replace the cooler because I don't track it. Just want to have the nicer lines.
Any help with what I need... thanks
Current Mods
2014 F33 435I // Intercooler//Pure Turbo Inlet // DV+//Charge Pipe//Boost Pipe//Downpipe//BM3 Custom Tune//Pure Stage 2 turbo//XDI-35//PR Black Coils//LSD |
03-18-2020, 04:24 PM | #2 |
Rep 10,367
Contact Turner Motorsport. The sell external oil lines and might have a custom solution for you.
"Drive more, worry less. "
03-24-2020, 10:38 PM | #3 |
Rep 1,934
Why burn the time and money to change the lines but not the cooler.
03-25-2020, 10:10 AM | #5 |
Rep 63
I had the car apart doing a lot over the winter and just did not like the way the lines looked in the engine. So I wanted to do it to clean up the engine... with that said it looks like I will be just doing the whole things anyways.
Current Mods
03-25-2020, 10:11 AM | #6 |
Rep 1,934
Just for looks is a waste imo, but you would probably be better off wrapping the lines with something instead of replacing them.
03-25-2020, 11:46 AM | #7 |
Rep 3,953
