BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > How to keep using expired E-Sys Launcher Premium by reverting system date (hack)
      01-18-2018, 01:15 PM   #45
Tony Twoclicks
Drives: 2012 F30 320i
Cool Updated version
Version 1.4.0 is out! Made some tweaks to the script and more importantly, found that (Avast) antivirus interferes with predating system folders. Self-Protection (not shields) needs to be deactivated and can be reactivated after running the script!
      01-18-2018, 01:18 PM   #46
Tony Twoclicks
Originally Posted by maciek49912 View Post
I can't do nothing :/
Program is still showing "date manipulated"...
What can I do with that ?
Maybe my version is not ok - I have 2.7.1.135 instaled.
Esys version - 3.28.1
Windows 10 Pro x64
Disable (Avast) Self-Protection and you'll probably be OK.
      01-18-2018, 01:20 PM   #47
Tony Twoclicks
Originally Posted by thedredd View Post
I have the same problem
Disable Avast Self-Protection module
      01-18-2018, 01:24 PM   #48
Tony Twoclicks
Originally Posted by spudvti View Post
hi there
I've tried 2.5.3 launcher with your script on date november, 15 2017. No good - just looping launcher at token generating moment.
then, I've deleted old FreeToken.est - same - no good
where should i go? what's wrong? hmmm
I haven't tested earlier versions of the Launcher. Generate a new token and open in Notepad. Check the ValidBefore and ValidAfter dates in the header. Does your system date fall in between these dates? That's the only thing I can think of. Otherwise, I have no idea.
      01-18-2018, 02:31 PM   #49
mauro1
mauro1's Avatar
Croatia
Drives: BMW f32 M sport
2008 E92  [0.00]
It works, thanks
      01-18-2018, 02:58 PM   #50
spudvti
Drives: G30
thanks
my sys date is in valid value, but still no good. trying premium 2.7.1, but it asks activation key, and I had no answer from TM in summer, so used 2.5.3
I think, i should try premium 2.6.2 build 124, but i can't find correct source to download from. Can I ask you for link?
UPD. 2.6.2 version asks activation code as well as 2.7.1. damn it
      01-18-2018, 05:05 PM   #51
Tony Twoclicks
If you're not on a virtual machine, I've read about a solution for activation as well. Had something to do with changing your system language. Google it.
Cheers,
Tony Twoclicks
      01-19-2018, 01:29 AM   #52
spudvti
Drives: G30
Cheers,
Tony Twoclicks
thank You
non virtual, US version of Win7 x64, all English.. so no language issues should be
      01-19-2018, 02:15 AM   #53
enemigo13
Drives: F32 LCI 440xi citrineblack
Thanks for the great tool! it would be wonderful if it was possible that you run *.bat or *.exe and it does everything automaticly (turns back date, cleans up launcher, runs it and then restores date to present), don't know if it's possible though..
      01-19-2018, 02:32 AM   #54
r0b3r
Drives: Bmw F
Yes , thanks !!
      01-19-2018, 02:36 AM   #55
Abzynthe
Abzynthe's Avatar
Drives: BMW 440i Gran Coupe LCI
Updates work for me now. This will keep me going until I get Pro launcher. Thanks
      01-19-2018, 05:04 AM   #56
Tony Twoclicks
Originally Posted by r0b3r View Post
I will explain my case and then expose it in a separate post, 10 days ago more or less buy and pay 50USD for this program, that same day I try to activate (the program is limited to two records) which occupies and my pc died, so I had to buy another new one, I sent several mails to him he read them but it seems that he does not want to help me solve or that my program works with my new equipment (the old equipment I do not have and I said to him that It will erase the registry so that it never works again. Also I have not been able to use the program for 1 second, neither in the old one nor in the new equipment, so I have 10 days and it is not able to help me or to give back my money. help people and you can donate some money, but do not play like that with people, with your time and much less with your money.
Please don't use this thread for bashing Tokenmaster. Although I sympathise with your case, I can't help you with that. Please ask Tokenmaster for help. And be patient, he's a busy guy....
Cheers, Tony
      01-19-2018, 05:11 AM   #57
Tony Twoclicks
Originally Posted by enemigo13 View Post
Thanks for the great tool! it would be wonderful if it was possible that you run *.bar or *.exe and it does everything automaticly (turns back date, cleans up launcher, runs it and then restores date to present), don't know if it's possible though..
Thank you. I thought about that, but maybe not everyone wants to go back to the same date. And it also depends on the Launcher version how far you can go back.
Also, restoring the date to present after running the Launcher is possible. However, you'll likely end up having to use my script everytime you start the Launcher as Windows system folders will be updated to present date pretty fast as you're working. After that, the Launcher will detect a date manipulation.
Since the script suffices my needs I thought it was best to keep it the way it is.
      01-19-2018, 05:16 AM   #58
baroines
Drives: BMW F30
It works!
It's working on Windows 10 Pro 1709 x64 Portuguese!
Already coded my car!
Thank you very much Tony Twoclicks!
      01-19-2018, 09:26 AM   #59
Sasquartch
Drives: 520i G30
Probably of limited use but FYI my esys (3.2.7) and launcher (2.4.3.85) runs on an old XP laptop
Just setting the date back before starting the launcher works fine with no need to run Tony's script
I know XP is ancient but as it will never connect to the internet and esys etc (at least my versions) run fine then I dont see an issue.
Just coded a 2016 car without any problems
      01-19-2018, 10:47 AM   #60
Abzynthe
Abzynthe's Avatar
I had old version on an XP laptop also, but for some reason was unable to code my 2017 440i. When I went to update the launcher, my laptop was not compatible, so had to put it on my Win 10 laptop.
      01-19-2018, 01:39 PM   #61
Tony Twoclicks
Older Launchers have limited or no date checking and allow for predating your system clock. However, they offer no support for the latest psdzdata files, which you need for coding the latest cars.
Premium Launcher 2.7.1 already lacks support for the very latest E-sys and psdzdata files. In time this necessitates migration to other solutions like E-sys Launcher Pro or BMWaicoder (too bad development seems to have stopped for that one, it was very promising).
      01-19-2018, 01:52 PM   #62
Tony Twoclicks
Version 1.5.0 is out! Optimized script by removing RSA-key deletion and other unnecessary steps. Added compatibility with Launcher 2.5.3. No more endless loops for token creation and entering pin.
Tony Twoclicks
      01-19-2018, 04:18 PM   #63
Ian-F80M3-UK
Drives: F80 M3 2014 Black
Windows system folder locked
Hi Tony, firstly thanks for the rearmer! I'm sure I'm nearly there, but get this message:
* E-Sys Launcher Premium Rearm 1.5.0 - 19/01/2018 *
* By Tony Twoclicks *
Rearming E-Sys Launcher Premium.
- Deleting Launcher config files/folders...
- Changing Launcher file/folder dates...
- Changing System file/folder dates...
ERROR: Windows system folder locked
There was a problem predating one or more Windows system folders.
Avast Antivirus Self-Protection must be temporarily disabled to prevent
system folder locks. Shields are OK. Afterwards, Self-Protection can be
reactivated again. Other antivirus solutions may have similar issues.
Please try again.
Press any key to continue . . .
I'm on windows 10 with just the standard Windows Defender Antivirus disabled, so no Avast, running as admin, i turned off all security - Windows Firewall, Windows Defender Antivirus. [Edit: And I'm using v 1.5, on the desktop of admin user] Any ideas? Many thanks
      01-19-2018, 06:46 PM   #64
Tony Twoclicks
Can you do something for me:
1. Run the script again
2. Right after running it, open a command prompt and type:
dir c:\programdata /tc /a
What date is mentioned for the directory . (single dot)?
3. Now do:
dir c:\programdata /tw /a
What date is mentioned now for . (single dot)?
4. Now open Explorer and go to the folder where you installed my package. Open the Tools-folder. Right-click on RearmLauncher.cfg and select Properties. Can you give me the Last Changed date please?
Don't know if I can help you, but this will give me some insight...
      01-19-2018, 09:19 PM   #65
jkwhar
Drives: F30 328i Xdrive | F15 x35i
First off, thanks for the script!!
I'm having an issue with the EST token. I've tried deleting the freetoken.est and recreating it but keep getting the "an error occured while processing the EST file" when trying to read FDL code.
Any help would be appreciated!
I'm running the 2.6.2 with psdzdata 63.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      01-20-2018, 02:26 AM   #66
spudvti
Drives: G30
Tony Twoclicks
well then.. thanks for older launcher support.
but
still looping on token creation
once again
e-sys 3.27.1
Psdzdata_v3.59.5_lite
launcher premium 2.5.3
win7 x64 us/en
1.50 rearm
thinking about reinstalling windows
clock, date, esys, launcher, premium
