08-07-2018, 04:18 PM | #1 |
Rep 26
F30 335i Xdrive Staggered Wheels ISSUE
I recently purchased some new wheels for my 335.
Front: 19x8.5 w/ 245/40ZR19 Rear: 19x9.5 w/ 275/35ZR19 Wheels are originally off an e9x M3 There was a very noticeable stutter when accelerating... I've since taken the wheels off since I'm sure my xDrive system didn't agree with the new setup... I am wondering why this happens, if there is a possible solution, and if not, what size wheels should I try next... Thanks! |
08-07-2018, 05:27 PM | #2 |
Rep 4,329
The difference between front and rear diameters is 0.4%, so it should work. How much of a tread depth difference, if any, is there between front and rear?
08-07-2018, 08:50 PM | #3 |
Rep 26
08-08-2018, 08:20 PM | #4 | |
Rep 108
Continental extremecontact dws too... Style 219m wheels 245/40/18 front 275/35/18 back 2012 X1 xdrive and does the exact same thing as you... The tire size difference% is/should be more than fine... IT isnt for some Reasons. Last edited by BeeHemDoubleU IksWane; 08-08-2018 at 08:50 PM.. |
08-08-2018, 08:44 PM | #6 |
Rep 108
Me
245/40/18 = 808 revs per mile 275/35/18 = 811 So 3 revs per mile difference... 245/40/19=778 275/40/19=781 Again, 3 revs per mile... You can't get closer than that.. Source: http://www.continentaltire.com/produ...7535r19-100y/?
You talk about German technocracy and you get automobiles.
08-08-2018, 08:49 PM | #7 | |
Rep 108
255/30/19 = 806 5 revs per miles.
08-08-2018, 10:34 PM | #8 |
Rep 26
08-09-2018, 01:07 PM | #10 |
A family of bimmers
2747
Rep 7,742
I have 235/265 combo on 8.5/9.5 combo with no issues. maybe look into that?
08-09-2018, 06:57 PM | #11 | |
Rep 26
Some mechanics at BMW told me that the xDrive system is so picky, that sometimes you have to try multiple types of tires before you find a tread pattern that agrees... |
08-09-2018, 08:39 PM | #12 |
Rep 495
I have Firestone Indy Firehawk Indy 500s
Instagram: @f80ghost
05-30-2019, 10:44 PM | #14 |
Rep 1,934
Go square.
f80.theo6.00 |
05-31-2019, 04:13 AM | #15 |
No 55mph
1622
Rep 8,476
I've used the exact same setup (wheel/tire sizes) for summer on my 435iX since 2015 - never had any problems
I go back to square setup with 18's in the winter
steveindabmer47.50 |
05-31-2019, 01:13 PM | #16 |
Rep 112
Im running 763m reps. 8.5in with 235/40R19 front, 9.5in with 265/35/R19 rear for my summers. Tires are Continental ExtremeContact Sports. No issues with my Xdrive.
I go back to the 400m squares for the winters. Will the computer go nuts if the xdrive is having an issue? With as many sensors there are on these things i would think something would throw a code? |
05-31-2019, 08:54 PM | #17 |
Rep 27
Drives: F30 335i
I wonder if x-delete will eliminate the 1% wheel diameter restriction on xDrive vehicles?
06-03-2019, 03:36 AM | #18 | |
Rep 109
xdrive, 4motion, quattro ( haldex). I have an RS3 with staggered setup (OEM from Audi) 255front-235 rear. originally it came with Pirelli PZero , had 0 issues. then after some miles I installed Michelin Pilot Sport 4 , issues sometimes. then tried Michelin Sport Cup 2, issues sometimes. now my setup is 255-255 MSC2. 0 issues. In my 435 xdrive have non staggered setup and no issues. my setup front and rear have been: 225/45 , 245/40 and 255/40, 0 issues. conclusion, best thing is going square. |
12-10-2019, 10:38 PM | #19 |
Rep 77
Maybe it's the the overall diameter bigger or smaller than the OEM 26inches. Basically an rpm/speed mismatch.
335i, f30, staggered wheels, xdrive |
