11-22-2018, 09:29 AM | #1 |
Rep 44
What is the process to bleed B48 coolant system
I got the low coolant code added mucho distilled and would like to bleed it. I have a service appointment but it is way out. I assume this is easy for an old man with arthritis. Thx
11-22-2018, 09:42 AM | #2 |
Rep 16,063
Unless the B48 is different from the N20 there is no radiator drain cock, the only way to drain it is by pulling a hose. You can double check here: https://www.newtis.info/tisv2/a/en/
If you just need to increase the % of anti-freeze wait until the wife is done with the turkey baster today, then use it to draw down the level in the coolant overflow tank. Then fill with straight anti-freeze. After a week or so of driving check the coolant protection with a tester you can get at any auto supply store or Walmart. Clean the baster well, ethylene glycol is poisonous. |
330i x, b48, coolant |
