02-03-2019, 01:35 PM | #1 |
Rep 7
MHD stage 2 without dp
I know going with a dp is recommended but im in CA so i don't want to deal with the hassle of taking off and putting on the downpipe for emissions. So i was wondering if I can run stage 2 with just an intercooler, chargepipe and exhaust without any problems.
02-03-2019, 01:43 PM | #2 | |
Rep 24
" you can run the stage 2 without any mods yes (a upgraded chargepipe is recommended) but the stage 2+ requires the recommended mods. " |
02-05-2019, 08:28 PM | #3 |
Rep 190,750
They should call it stage 1+ then instead of stage 2
Shayan55338.50 |
02-06-2019, 10:00 PM | #4 | |
Rep 5,776
Last car: 2011 335i Msport. JB4. Vrsf CP |
02-06-2019, 11:07 PM | #5 |
Rep 7
02-07-2019, 01:09 AM | #7 |
Rep 5,776
02-08-2019, 06:18 PM | #8 |
Rep 128
i find this interesting.. so i'm not a tuner but i kind of understand that tuning is messing with the engine air fuel ratios to get more power out of the motor. so if you tune a car to "stage 2" which typically requires some bolt ons in most cars... if you don't have those recommended parts with the tune then i would think the ecu would pull timing and not run as well.. specially when it's hot outside (heat soak).
i guess this all depends on the tune you're running but would that suck if you flashed a pretty aggressive stage 2 map and then you get a few misfire codes and the knock sensor detects engine knock. i'm not a BMW expert in any way but sounds definitely possible.. not enough for me to want to put a stage 2 tune on my car when i'm clearly stage 1 lol.. correct me if i'm wrong though. I would like to know, thanks! |
exhaust, inter cooler, mhd flasher |
