BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Just changed oil: potentially stripped plug
      02-12-2019, 11:51 PM   #1
poomunj
Drives: BMW 328i
Hello,
Just changed oil and while putting the plug in and setting my torque wrench to 8lb I noticed that it kept spinning so I stopped. The area where the Allen meets the plug is a little deformed and I noticed that the plug kept going.
My question is which has more potential to strip? The plug or the pan? Hopefully the plug is just a little stripped and able to be extracted not a big deal. Do plugs strip more often then pans or is the whole guy done for?
Also how much does this usually cost to fix if it is?
Will take it to a shop tommorrow. No more diy for me..
      02-13-2019, 12:18 AM   #2
the dope steez
Drives: F30 335i M-Sport
Wait, what?
      02-13-2019, 12:30 AM   #3
poomunj
Drives: BMW 328i
Originally Posted by the dope steez View Post
Wait, what?
Tried to change oil and seems as though I stripped the drain plug. Asking if the pan is easier to strip or the plug, and a ballpark of what the pan might cost to replace if needed.
      02-13-2019, 06:09 AM   #4
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
The drain plug is a bit finicky and will keep spinning after its tight.
Are you sure its stripped?
As long as you put it on perfectly square and didnt cross thread it... your probably fine.
And dont get discouraged with DIY... this is only the start, take your time and learn from your mistakes! No problem.
      02-13-2019, 06:23 AM   #5
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Originally Posted by poomunj View Post
Hello,
Mine was stripped too.. I dont remember ever tightening it too hard.
Luckily I was still under warranty and the dealer fixed it and rethreaded it for me.
Hi
      02-13-2019, 07:58 AM   #6
poomunj
Drives: BMW 328i
Didn’t know the pan was able to be rethreaded since it’s plastic. Good to know.
I will monitor the plug for leaks over today and tomorrow.
      02-13-2019, 08:08 AM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Did you use a new plug? The correct OEM grade oil filter comes with a new plug, as once removed they should not be used again.
      02-13-2019, 08:14 AM   #8
poomunj
Drives: BMW 328i
Yup, used new plug provided
      02-13-2019, 08:25 AM   #9
n00bkiller944
Drives: '14 328d M Sport
This Don't get discouraged. This is how we all learn
      02-13-2019, 09:13 AM   #10
sspade
sspade's Avatar
Drives: F30
Highly doubt there is any re threading to be done on a plastic pan.
Dont take every bit of advice as accurate on here. Some models (xDrive) come with a metal drain pan.
      02-13-2019, 03:17 PM   #11
ctbear
Drives: 2015 335i m-sport
This is only true if you buy the OEM oil filter from the dealer right? Only buying it from the dealer will it include a new plug?
      02-13-2019, 03:57 PM   #12
sspade
sspade's Avatar
Drives: F30
No, you can find OEM filters with plug for $13 online including shipping.
eBay
11427953125 is my part number, please verify yours!
      02-13-2019, 04:24 PM   #13
Billfitz
Billfitz's Avatar
They're included with Mahle and Mann filters no matter where you get them.
      02-13-2019, 04:57 PM   #14
ctbear
eBay
Interesting, guess for my vehicle it is just a drain plug crush washer. Thought it would be a plastic replaceable drain plug like your's.
Part#: 11427953129
      02-13-2019, 05:43 PM   #15
Billfitz
Billfitz's Avatar
Mine doesn't have a plastic plug, it's metal, just like my pan. XDrive N20s have metal pans, RWD have plastic. I don't know what 335s use.
      02-13-2019, 06:44 PM   #16
J.D.
Drives: 2015 328i
Ummm, correct me if I'm wrong, but I thought the torque spec was 8nm, not 8 pounds. 8nm is roughly 70 inch-pounds. So if you torqued it to 8 foot-pounds you over torqued it quite a bit.
      02-13-2019, 06:52 PM   #17
poomunj
Drives: BMW 328i
I guess there is my answer. I did stop once i realized something didn't feel right so hopefully nothing too bad happened. Will check the plug tonight to see if any oil is leaking from it.
      02-13-2019, 06:56 PM   #18
J.D.
Drives: 2015 328i
It's an easy mistake to make. Don't sweat it. I would second what's been said already. Don't give up on DIY. Some growing pains are just part of the process.
      02-13-2019, 07:20 PM   #19
Broadsword
Sustinendum Victoriam
Drives: '13 335i
All 335s have metal pans.
      02-13-2019, 11:15 PM   #20
ctbear
So metal pans with metal drain bolts that just have a crush washer that needs to be replaced every time oil is changed, correct?
      02-14-2019, 06:23 AM   #21
Broadsword
Drives: '13 335i
Correct.
      03-18-2019, 11:29 AM   #22
F30sam
F30sam's Avatar
Drives: 2014 320i XDrive
I was teaching my son and he did the same exact thing. Just a bit too tight and spun it all the way around. What's the recommended repair? Nothing is leaking and i had it running for a while in my driveway.
