06-19-2019, 06:31 AM | #1 |
Mike: Everyone's Pal
2044
Rep 2,972
Drives: F80 M3
75k mile service/preventive maintenance
Hey guys, here is the list I am planning to do.
Any ideas? -water pump/thermostat -tensioner/pulley -automatic tranny fluid -check for any leaks Plugs were changed at 50k, coils were not changed yet. Any other fluids I should change.. power steering maybe?
Alpine MSS Stage 2+ E30 tune|MST Intakes|VRSF Single Mid Pipe|Agency Power Intercooler|VTT Full solution crank hub fix |
06-19-2019, 08:14 AM | #2 |
Rep 975
Diff and brake fluids?
15' 435i F33 Metallic Grey/Dakota Black/Contrast Blue | AWD | M Sport
15' 328i F30 Mineral White/Dakota Saddle Brown | AWD | Luxury Line |
06-19-2019, 09:30 AM | #3 | |
Rep 387
For tranny fluid, ZF recommends between 60 and 80k miles. My Bentley manual states 100k. As long as you do it before 100k, I think you should be fine. Tensioner pulley, I probably wouldn't replace myself if it wasn't giving me issues. Regarding the power steering, these cars have electric power steering, so no fluid to change. Diff fluid wouldn't be a bad idea. Brake fluid, I would test before changing. Amazon sells these pretty nifty electronic brake fluid testers that will tell you if your fluid needs to be changed. I would probably buy one of those and test it before changing it. That way you can test all your cars. Last edited by IraHayes; 06-19-2019 at 12:32 PM.. |
floridaorange10152.50 Mike.2044.00 |
06-19-2019, 09:52 AM | #4 |
Rep 4,456
Brake fluid should be changed every 2years I think. Regardless of miles.
If your taking your car into an Indy shop I would buy the parts ahead of time and wait for them to have issues before replacing. This way your ready to go with no wait time for parts and you might be able to find a deal on OEM stuff. Water pump is expensive. |
06-19-2019, 11:14 AM | #5 |
Rep 191
Drives: 2013 328i xDrive
I'm at 70K miles and the following maintenance has been recently performed by myself with the exception of the tranny flush and fill:
Replaced plugs @ 69K Brake fluid flushed @ 62K (I try to do this every 20K) Transmission fluid and filter replaced @ 65K. This was done by a local indy shop who has BMW certified techs on staff. Labor was about $280 and I supplied all fluid (ZF Lifeguard 8 / tech used about 6 liters), ZF pan/filter and hardware. Parts were the most significant cost so I sourced and purchased everything myself....eBay was a great source and I got some pretty good deals. Thermostat and Water Pump @ 64K. I also did this myself as the quote from the same indy shop was crazy...as you can imagine they were overcharging me for parts. Ended up finding an OEM water pump on eBay for $210, thermostat for $50 and antifreeze for $20. I ran a diagnostic via the Carly app and it showed a blockage in coolant system which most likely was the thermostat stuck open...I wasn't aware of the extended thermostat warranty at that time. Being proactive I ended up replacing water pump as well...it will eventually fail as they all do. Cabin filter replaced @ 62K (performed every 20K) So far, so good...no issues at this time. Motor oil changed every 5K...Castrol Syntech 0W-30 which is becoming harder to find lately. Overall, the tranny fluid was my biggest concern as I plan on owning this car for a few more years.
'13 328i xDrive│Jet Black│BMS JB Stage 1│MPE│18" 400M & Conti DWS 06│DelVal BMW CCA #533245
06-19-2019, 02:26 PM | #6 | |
Rep 50
I'm scheduling a brake fluid change but i guess I should plan for a tranny fluid change as well. |
06-19-2019, 03:43 PM | #7 |
Rep 191
Yes, tranny flush/fill is highly recommended if you plan on keeping the car beyond 80-100K miles. Check out ebay for the parts needed....there's always a good deal to be had. Be aware that the (plastic) pan will need to be replaced. All pans include an integral fluid filter and typically come with new hardware. ECS Tuning and FCP Euro are good places to check for parts in addition to ebay. You may get some sticker shock when you see the price of a liter of tranny fluid....so you've been forewarned!
H4CK1NT05H24.50 |
06-19-2019, 05:23 PM | #8 | |
2044
Rep 2,972
Drives: F80 M3
murphius111899.00 Machinebuilder278.50 |
06-19-2019, 05:25 PM | #9 | |
2044
Rep 2,972
Drives: F80 M3
06-19-2019, 10:50 PM | #10 | |
Rep 4,456
06-21-2019, 05:31 PM | #11 |
Rep 191
Loosening the top bolt was the hardest part. Difficult to get to....had to use two extensions and a universal joint in order to remove and replace. Besides that fairly simple being that its an electric water pump so no belts to worry about.
BMW recommends all new hardware when replacing the thermostat and water pump. Hardware is the E-socket torx type so you'll need to purchase sockets if you don't have already. I'll post the part numbers for hardware when I get a chance. Also you'll need to refill and bleed coolant system. I used the tried and true Bentley manual for reference.
06-22-2019, 12:33 PM | #12 |
Rep 387
H4CK1NT05H24.50 |
06-22-2019, 12:37 PM | #13 |
2044
Rep 2,972
Drives: F80 M3
correct. It is an n55, and yes you are right
06-23-2019, 08:22 AM | #14 | |
Rep 10,352
Coils are 100k miles. Tensioner pulley, Water pump and thermostat? Nah. Even Mike Miller doesn't recommend replacing perfectly functioning parts for the sake of it.
"Drive more, worry less. "
06-23-2019, 08:37 AM | #15 | ||
2044
Rep 2,972
Drives: F80 M3
06-23-2019, 11:58 AM | #16 | |||
Rep 10,352
06-24-2019, 05:34 PM | #17 |
Rep 387
I would swap it out, personally. Slow death or no, I’d rather not risk overheating an all aluminum engine.
06-24-2019, 07:12 PM | #18 | |
Rep 191
Water pump hardware BMW #11517602125...requires 3 This is for 328 2.0 N20/26 motor....not sure about 335 which the OP drives
