11-23-2020, 07:08 PM | #155 |
Rep 14
Lets see how it sounds first, I would consider better front tweeters if more highs are necessary or rear surface mount. I hope not..
What do I need to know about the engine note thru speakers after upgrade? I like the engine sound in the cabin with spirited driving. Angel |
11-23-2020, 09:35 PM | #156 |
Rep 16,083
I've tested the OEM tweeters against expensive aftermarkets and the OEM are fine. The high pass filtering for them is woefully inadequate, and there's no low pass on the midranges, which I fixed with real crossovers that I designed. I don't have engine sound in my speakers.
11-24-2020, 02:10 PM | #157 | |
Time to switch brands
Rep 6
12-09-2020, 03:41 PM | #158 |
Rep 14
First impression on the Match amp.
Very easy install. Very easy USB update. Much more head room, definition, bass is also much more noticeable. Impressed... I loaded the touring file and the system came alive. I have a F31. I am going to explore if the DSP can assign frequency ranges to select channels? I notice the highs could be much sharper, sounds filtered. Still need the bass amp, sub and box. Any DSP advice out there? |
12-10-2020, 07:07 AM | #159 | |
Rep 500
12-10-2020, 05:13 PM | #160 | |
Rep 14
Yes, Match amp and factory speakers. Those Focal's look amazing. Man this is going to expensive! Can the high's be enhanced in the DSP? This weekend I get the Kicker 800.1 and listen to a tube, sealed, ported box. Until my side mount arrives. So tempted to go with Focal's R/L and 10" sub.. Angel |
12-10-2020, 10:31 PM | #161 |
Rep 16,083
I've actually tested the stock speakers, they're just as good as the Focal. This is a case where more expensive is just more expensive, not better.
wilbur_the_goose353.00 |
12-11-2020, 07:33 AM | #163 |
Rep 16,083
Not in a car, that's for sure. The difference in how well a $70 driver works compared to how well a $300 driver works in a high end stereo speaker is slight, and can hardly be heard in a perfect listening environment. A car isn't a perfect listening environment by any means. If BMW used $10 drivers there would be room for major improvement, but they don't.
johnung4528.00 SD Convert65.00 |
12-11-2020, 08:02 AM | #164 | |
Rep 5,392
I just want to add to this thread that guys keep trying code out the ASD engine noise and have problems by doing so. The simple and 100% effective solution is to install a hardware fix, the ASD bypass harness from Technicpnp, about $55. https://technicpnp.com/product/asd-bypass-harness/ The ASD is a box near the BMW audio amplifier under a panel in the left alcove of the trunk. Note: I went through lots of gyrations trying to find an ASD that my dealer parts department swore that I had based on my VIN. Then I was told by Technicpnp that they had never seen as ASD installed in a built for the US F3x 3-series. Apparently the UK model 3-series might have gotten an ASD. |
SD Convert65.00 |
12-11-2020, 08:19 AM | #165 |
Rep 16,083
All of the ASD systems I've seen use a separate box. I've never investigated coding it off as I don't have it. Bimmercode has an Active Sound Design deactivation function, but I can't say if it works.
12-12-2020, 11:46 AM | #166 |
Rep 1,245
It worked for me in my old '14 F30. My current car, an '18 F34 didn't have ASD, which made me very happy.
12-13-2020, 02:20 PM | #167 |
Rep 14
Where can I find a tune with sub out enabled?
Any advice on the Match amp? The red led is on indicating low voltage, WTF? Also, no sub out data? I have reset the amp, loaded different files and still steady red? Defective? Last edited by ALara; 12-13-2020 at 04:37 PM.. |
12-15-2020, 05:10 AM | #168 | |
Rep 500
There's 2 groups of people here. Those that said stock speakers is good enough but I'm sure they never install better speakers in their car. There's another group that have done the listening test and can vouch that changing the speakers does bring better SQ to the whole system. I have done my system upgrade progressively and noted down the changes for each component to the overall SQ. If you are interested, check out the thread in X3 forum. I also have calibrated MiniDSP mic that I use to calibrate the whole system as different speakers will need to be EQ differently. There's no one size fit all tuning profile from my perspective. Some people like very sharp treble but I found it's very annoying in car environment especially Adele songs. Too screeching to my taste. I need to tame the treble down by using shelf filter at 2khz, -2db. Last edited by pierreye; 12-15-2020 at 06:47 AM.. |
12-15-2020, 08:24 AM | #169 |
Rep 16,083
There's a third group, engineers who understand how speakers work, and don't rely upon unsubstantiated advertising claims to make sensible decisions on what's worth spending time and money on and what's not. Claims of improvement without supporting data are as useless as claims of which bottled water tastes best.
Liquidfox34.00 wilbur_the_goose353.00 |
12-27-2020, 10:34 AM | #170 |
Rep 14
After incredible patience and tweaking, I finally got the trunk sub to work. Can someone explain the reason for summing the front R/L on the in/out setting of the DSP? Are the front mids and highs on the same channel? can they be individually set up in the DSP?
Is it possible to individually set frequency ranges to all 7 channels? Billfitz is correct, the highs are not crispy especially when the tracks slam those symbols! |
12-27-2020, 11:11 AM | #171 |
Rep 16,083
I can't comment on the specifics, as I don't have one, but where content is concerned everything below 80Hz has been summed to mono in the recording studio since the 1980s, so that might have something to do with it.
12-27-2020, 05:51 PM | #172 | |
Rep 500
12-29-2020, 05:20 PM | #175 |
Rep 14
I don't think amplification will be an issue? I have installed a Kicker 800.1 @ 2 ohms 600.
Also I am hearing a tic, tic on the front passenger side. The noise is in phase with the engine, but its not alternator noise? The noise was there before the sub amp install, so I do not see a relation. Its from the Match amp. Going to see if the engine noise thing is the cause. I think it could be coded off. |
01-10-2021, 03:14 PM | #176 |
Rep 126
I've got a small box near my amp, with a similar connector, but I don't know what it is. The label lists it as a Harman Becker "HS B224", with a BMW number of "2 448 116 AI:01" (obviously not a part number). The label also says it's an amplifier (supported by the heatsink top). Does anyone have any ideas what this might be?
