01-18-2017, 04:05 PM | #287 | |
Rep 499
01-18-2017, 05:23 PM | #288 | |
Rep 962
01-18-2017, 08:07 PM | #289 | |
Rep 134
If you look into the part revisions:
-01/15 Timing chain revised -04/15 Oil chain revised My key question in all of this is: Have we seen this type of failure in cars built after 01/2015? After 04/2015? Quote:
01-18-2017, 08:23 PM | #290 |
Rep 861
N20 with 40k miles, looks ok to me, a little bit of scuffing on the chain but nothing that looks to compromise the integrity of the chain. We're selling/trading it anyway, we've gotta get a bigger vehicle
2023 i4 eDrive40
2022 Acura MDX |
01-18-2017, 09:06 PM | #291 |
Rep 1,343
The scuffing means it is rubbing against something.... Possibly the plastic guide? Whatever it is rubbing against that part too is being frictioned off. And if it is the plastic guide then it's a matter of time before the plastic guide's structural integrity becomes compromised and shatter.
Drawing upon my bike maintenance days, stretched chains are normally due to worn sprockets. The teeth would look like shark's fins. Unless one is putting down major torque gears/sprockets last a long long time. Would be good to know the driving habits of the drivers with this issue. |
01-19-2017, 07:00 AM | #292 | |
Rep 861
01-20-2017, 09:46 PM | #293 |
Rep 943
Drives: 2012 328i Modern Line
Had my timing chain/guide replaced by BMW a few months ago, approximately 7k miles ago. Here is a pic I snapped this morning.
[IMG]http://d.pr/i/2WZ2+[/IMG]
:wave:
Stubok471.50 |
01-21-2017, 01:57 AM | #294 | |
Rep 1,343
Out did it break which might let to catastrophic engine issues. |
01-21-2017, 07:26 AM | #295 | ||
Rep 943
Also posted here: 2012 BMW N20 Engine Failure!!! http://f30.bimmerpost.com/forums/sho....php?t=1256248
:wave:
01-22-2017, 10:35 AM | #296 |
Rep 22
Anyone can pm me the email for those who are in charge at bmwna that can help with my situation. I have a 2012 bmw x1 28i with 100,600km that I recently bought from a used car dealership in mississauga ontario in dec 2016. They had in turn bought the vehicle from parkview bmw toronto in sep or oct 2016. The vehicle was on a lease till aug 11th 2016. Service history shows it was maintained and serviced up to date. I recently heard a slight whining sound on acceleration and took in to bmw etobicoke for diagnoses. They notified me that the timing chain and oil pump chain needs replacing due to excessive wear on the chains and sprockets causing the whining noise. Another issue is that the turbocharger oil feed line needs replacing as well. Both issues I have read about have been common issue of the n20 engine especially the timing and oil pump chain wear. I want bmw to atleast cover that repair. Anyways if anyone can pm me the contacts i would need to send my concern to then. will not threaten them yet I will give them a chance first.
01-22-2017, 12:20 PM | #298 | |
Rep 16,088
OP, go to the leasing dealer, and contact BMW Canada. Between the two of them you might come to an arrangement. |
01-23-2017, 09:15 AM | #299 | |
Rep 230
01-23-2017, 09:31 AM | #300 | ||
Rep 943
Not sure what you mean, I was just posting a picture of how my chain looks post upgrade. Is there something wrong?
:wave:
01-23-2017, 10:17 AM | #301 |
Rep 16,088
Nothing wrong, but it does show that the plastic guide doesn't stay white, it turns brown after exposure to oil. Earlier pictures of a removed old chain and an unused new chain would give the impression that if you've got a brown plastic guide that you have the old version, and that's not the case.
01-23-2017, 10:36 AM | #302 |
Rep 396
01-23-2017, 01:56 PM | #303 | |
Rep 34
P.S. timing chain guide failure leads to higher pitched whine that needs to be addressed immediately. There are numerous videos on the web of this sound and one can not miss it.e.g. visit bmwtechnician's blog. Last edited by davitd; 03-16-2017 at 09:55 PM.. |
01-23-2017, 02:15 PM | #304 |
Rep 16,088
You missed my point. This picture shows old versus new oil chain:
The new unused guide is white, because it hasn't been exposed to oil yet. Some have made the mistaken assumption that the new chain will have a white guide. Before installed, yes, but after installed, no. However, there is a visible difference between the two. The links of the old version are all made with two plates back to back. In the new version the center links are still two piece, but the inboard and outboard links are one piece. Whether that's significant or not I can't say. Last edited by Billfitz; 01-23-2017 at 02:25 PM.. |
scostu1623.00 |
01-23-2017, 03:17 PM | #305 | |
Rep 396
01-23-2017, 04:32 PM | #306 |
Rep 962
Still in shock that a company whose middle name is Motor has such a "teething" problem with chains you would normally expect from a brand new car maker.
Amateur hour... |
02-01-2017, 12:46 PM | #307 |
Rep 9
[UPDATE] - N20 in 2013 X3 died at 75k miles
Finally, after 8(8!) weeks of being on a lift at the dealership my X3 has been repaired under warranty and returned to me. As glad as this has made me and my wife, there are still some things to be concerned about.
First, the replacement engine was selected by the dealership, this did not go over very well with the warranty company who were able to find a much cheaper replacement... this is all well and good, except the replacement that was installed still has the out of date secondary chain inside of it. I went back and forth with the dealership and BMWNA for multiple days about getting the chain updated. The best they could do was quote me $2400 for the replacement. I balked at this proposition and happily accepted the 12mo. warranty extension that they offered on the replacement engine. I did this assuming that there will either be a recall between now and then or in the worst case I would get the new chain installed by an independent mechanic the day before the warranty expires. Second, on our way home from picking up the car there was a very noticeable vibration through the seats and arm rests (briefly through the steering wheel while accelerating at low speed). The vibration has a frequency that seems to vary with rpm at nearly every speed. I am currently trying to identify the frequencies as a function rpm using some rudimentary vibration analysis tools. This vibration was accompanied with some very strange noises (something like a whine combined with a lugging sound) coming from the engine bay. We notified the dealership of this and they told us to "keep an eye on it". I guess they are hoping that it "just goes away", in my experience that never works. I initially second guessed myself, thinking that it could be normal, however, we had just been driving a loaner '17 X3 and it was smooth as butter and super quiet once up to operating temp. In fact, the vibration from the "new" engine feels worse than the old engine did immediately prior to the failure of the secondary chain. I am thinking that the secondary chain in this engine has already been stretched, causing the counterbalance shafts to be "out of time" with the engine. Unfortunately, I think I am going to have to bring the car back to the dealership and tell them that I am not satisfied with the work done on the vehicle and they need to have another crack at it. But I am not sure how all of this will play out with regard to the burden of the warranty be fulfilled, etc. etc. If anyone has ideas as to the source of these vibrations, and/or what course of action I should/can take to get this thing running properly I would greatly appreciate it! |
motorwerkeman160.00 |
