09-19-2018, 10:45 PM | #1123 |
Rep 124
Hello, all.
Just picked up a set of Work VSXX. F- 19x8.5 et40 (thinking of adding a 12mm spacer) R- 19x10 et23 Would I be able to run 235/35, 265/30 without rubbing? 335 xDrive on Dinan Springs. Last edited by CHI3F; 09-19-2018 at 10:57 PM.. |
09-19-2018, 11:19 PM | #1124 |
Rep 463
Those rears are very aggressive. No way you're gonna fit a 265 even if maxing out stock camber. You need rear camber arms and fender roll/pull. A 245 (or probably 235/35) is more realistic and even then I don't think maxing out the stock camber (should get around -2.5 or so) will fit without fender work.
09-20-2018, 01:34 AM | #1125 |
Rep 605
That's pretty aggressive rear at et23, not saying it's impossible but you'll need some work to make it fit. You might need to stretch the tires and add camber.
09-20-2018, 01:54 AM | #1127 | ||
Rep 26
265? no chance. I run 225/35 on 19x10 ET25 in the rear and I could not fit more with max stock camber, which is -3.2 at my height by the way. And even tho I have a slight fender pull, it is still rubbing on the rim lip during hard dips. Last edited by kedafoe; 09-20-2018 at 02:53 AM.. |
09-20-2018, 02:08 AM | #1128 | ||
Rep 26
If we go for stock we have 225/40 and 255/35 on 19” or 225/35 and 255/30 on 20” which gives us a rolling circumference of -0.7%. That’s what the xDrive was designed for. So from this perspective 235/35 and 265/30 is the better option because it is -0.8% = total difference of -0.1% to stock. I also had both combinations on my last setup and had less vibration issues with 235/265 than 235/275. |
09-20-2018, 09:55 AM | #1129 |
Cheapskate
4450
Rep 4,993
I don't think the difference from stock matters. You just need to make sure the fronts and rears aren't too different. If both are smaller or taller than stock it's not that big a deal if both diameters are similar.
09-20-2018, 10:03 AM | #1130 | |
Rep 2,152
a new 235 with a half warn 236 will be closer to 2% rolling diameter difference
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
09-21-2018, 02:38 AM | #1131 | ||
Rep 26
So if you have to change tires you should always change all fours. If you don’t follow that rule you will have problems with no matter what combination, even stock lol. |
09-22-2018, 09:30 PM | #1132 |
Rep 68
335i X Drive M Sport.
305 Forged FT107's 19x9.5 ET35 Squared 255/35/R19 Squared H&R Sport Springs |
09-23-2018, 07:27 AM | #1133 | |
Rep 1,288
Drives: 2014 435iX, FBO
How does it handle? It must feel great... Assuming no rubbing on the front? I should have done this.
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S |
09-23-2018, 12:37 PM | #1134 | |
Rep 68
It handles better than stock but the bumps are quite painful with the springs lol. I’m gonna upgrade my shocks/struts with Bilstein B8’s as soon as possible |
DaFish157.50 |
09-23-2018, 05:29 PM | #1135 |
Rep 439
Not stanced, but pretty low and well fit. -2.1F, -2.7R.
OG TE37 18x9.5 et28, PSS 255/40/18 square.
2022 BRG G80 xDrive
2005 SGM M3 Last edited by Malloy; 09-23-2018 at 05:39 PM.. |
Vulpe279.50 F30_SixSpeed1170.50 cngo56.00 kern4174449.50 Stlthnmrdrd156.50 not.ramos209.50 cdwalls702.00 BMW BRAD204.00 |
09-23-2018, 06:45 PM | #1136 |
Rep 16
Are any of you xDrive guys having problems with front axles/cv boots? I'm torn on what to do with my car. I wanted a RWD to begin with since it doesn't snow too much in Ohio, but they just don't exist around here, and I made an impulsive decision and ended up with an xDrive.
Now I'm not happy with the way it handles or the ridiculously goofy ride height, and want to do coilovers. I'm worried that even at the highest setting on something like a KW SC I'll run into issues with excessive front end wear. I come from the lifted truck world, and told myself with this car ride height was staying stock. Don't know if I should just sell the car and travel south to get something RWD or take my chances and modify the xDrive. It seems like most people on here only keep their cars for a couple years and less than 50k miles so it's hard to gauge long term reliability. I'd like to keep this car for 100k + miles but if I'm going to have to do CV boots every 10k that's not going to work. |
09-24-2018, 03:44 AM | #1137 |
Rep 26
I have 60k miles now and no issues at all.
Only hypothetical issue you could have are vibrations from the front drive shafts and the transfer gearbox. Depends on how low you go and which tire sizes you choose. The latter is the most important. If you keep the rolling circumference as stock as possible you will be happy. If you really want to do aggressive stance and riding low af it would be best if you get an rwd for those purposes beofre you invest money in your current car. If this is not your goal at all, you will be fine with the xDrive anyways. |
09-24-2018, 07:27 AM | #1138 |
Cheapskate
4450
Rep 4,993
09-25-2018, 12:12 AM | #1139 |
Rep 55
09-25-2018, 05:16 AM | #1140 | |
Rep 2,152
20x10 et42 - 275 30 20 tbh the front could maybe do with 3 to 5mm more spacing to be perfect. im lowered on HR lowering springs (28832-1)
09-27-2018, 08:26 AM | #1141 |
Rep 29
F31 328xdrive
running 18x9.5 with 15 mm spacer 215/40/18 18x11 245/35/18 Should be able to run a 18x10 +25/20 ish upfront front airlift camber plates stock rear suspension BTW i have the rear megan camber and toe arms but didnt need them so if anyone wants to buy brand new parts for cheaper than megan sells, slide in the PM Last edited by Luismpr; 09-27-2018 at 09:29 AM.. |
09-28-2018, 12:12 AM | #1143 | |
Rep 26
check your PM |
09-28-2018, 02:19 PM | #1144 |
A family of bimmers
2747
Rep 7,742
that hyundai tho
aggressive, f30, low, slammed, stance |
