BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > MG flasher - mobile App for B58 Fxx/Gxx tuning -- NOW LIVE!!!
      10-15-2018, 03:04 PM   #1
Jarek@JRAuto
Jarek@JRAuto's Avatar
Drives: G20 340i
BIMMERPOST
     Featured on BIMMERPOST.com
The waiting game is over! MG Flasher is now LIVE!!
First available mobile based flashing tool for BMW Fxx/Gxx B58 in Google Play Store !
MGflasher.com
You can download the app from the Google play app store (iOS support coming out at a later date)
MG Flasher is pleased to announce our latest tuning solution for B58 engines. We would also like to give a brief synopsis on our now released flashing tool, MG Flasher which is a mobile application applicable for Fxx/Gxx B58 vehicles. We are proud to say that we are among the first in the world to unlock the MG1 ECUs with our own solution/core software. Now, we are able to offer you OBD tuning capability through WiFi or K+CAN cable. We have been able to facilitate a flashing time around 1 minute 30 sec! This will enhance your flashing experience as well as provides a safer environment. We know that maintaining your warranty through software modification is a key deciding factor when considering a tune for your car. Rest assured, our MG Flasher software is designed to keep your CVN (Checksum Verification Number) and flash counter untouched. This means our software will be virtually invisible to dealer level diagnostic tools.
About MG Flasher:
MG flasher provides the user flashing capability of various maps along with custom flashing option for BMW Fxx/Gxx series equipped with B58 engines and controlled by the DME86X ECU. MG flasher is a mobile application that has been prepared for Android users such as yourselves! (iOS iPhone version coming soon)
The tuning process has never been easier. Simply connect the mobile device to your OBD connector with the supported Wi-Fi adapter or K+DCAN cable and tune your BMW within minutes with the provided OTS maps or use custom option for flashing maps prepared by your tuner. There are different tuning stages available (OTS maps), outlined below which are offered to meet your specific driving needs!
Our MG flasher also offers many unique functions included with the purchase of the flashing license:
  • OTS maps/ All OTS pack (subject to additional cost)
  • Custom flashing – flash custom maps prepared by your tuner
  • Logger - log real time data and plot it into graphs for troubleshooting and optimizing (subject to additional cost)
  • Diagnostic- Read and clear BMW specific DTC's
  • Reset various adaptations, restore coding
  • CVN number (Checksum Verification Number) along with flashing counter stays untouched. This means our software will be virtually invisible to dealer level diagnostic tools
Various other custom options are available with each OTS map including:
  • Exhaust burbles
  • Cold start with cat heating delete (racing/off-road use only)
  • Speed limit removal
  • HP gauge and TQ gauge calibrated according to the power level
  • More in the future updates
OBDII Wi-Fi adapter or D-can cable with OTG adapter is required for flashing
Please feel free to reach out to us with PM or by sending us an email at info@mgflasher.com
We are looking forward to your feedback. Thank you all so much for your consideration and taking the time to read this! We will keep up on maintaining this post with the newest and most relevant information for you all.
This is how our new and 'improved' Stage 2 tune looks like:
Some MGFlasher App screenshots:
Between creating our flashing tool, to extensively testing our performance software on our in-house dyno, we had our work cut out for us. For starters we purchased a brand new F30 340i B58 with MPPSK which we used to develop our solution for programming. Day in and day out, tirelessly for the last seven months we worked towards unlocking the SPC5777M MCU that runs the DME861.
Our tester car had MPPSK software equipped on it to begin with. We decided to flash/downgrade our 340i with non MPPSK (stock non-performance software) and establish a baseline. From this stock (non-performance) flash we began our research and development. Analyzing and studying software documents along with a multitude of test runs and extensive data logging on both the dyno and the road enabled us to deliver you our end product. A product that does not just focus on maximum power but also reliability and ensures longevity of your vehicle and its components.
Our facility is equipped with a V-Tech dynamometer, that provides us with very accurate and realistic graphs and numbers. All our dyno runs will be displayed in horsepower/torque @ the crankshaft, the same as how BMW rates their engines. We did not apply any smoothing options to our dyno diagrams.
For a point of reference, displayed will be the power output of both Original and MPPSK software based off our measurement of them on our dyno. This can give you an idea of the exact delta gain of our software vs the various stages of what is considered stock software.
ORIGINAL: 343hp 360 ftlb / 488NM @ Crank
MPPSK: + 40hp + 34 ftlb (383hp/395ftlb / 535NM @ Crank)
Our offered solutions are available in the following stages and will be available as OTS maps which will be programmable through our MG flasher:
STAGE 1: + 69hp + 63ftlb / 85NM Torque (412hp 423ftlb / 573NM @ Crank)
A great, entry level software flash designed for all stock components and 91 Octane or greater. This software is intended to be a step up from BMW Performance Software (MPPSK), which reduces the torque spikes, increases power and smooths out the overall powerband. You will notice an increase in responsiveness as well as drivability.
Technical Information:
Boost Pressure: 16 PSI (1.1 Bar)
Options
Exhaust Burble
Cold Start Delete
Display NBT HP/TQ gauges calibration
STAGE 2: +99hp +118ftlb (442hp 478ftlb / 648NM @ Crank)
For the spirited driver that wants the most out of their stock component vehicle. This software is intended to safely maximize your vehicle’s potential performance. The power curve has been delicately engineered to eliminate any dips in the overall powerband as well as maximizing delivery of that power throughout the entire RPM range. Designed to work with 93/94 Octane for best results.
*Transmission Tuning Recommended* - See technical information for more.
Boost Pressure: 19 PSI (1.3 Bar)
Options
Exhaust Burble
Cold Start Delete
Transmission Limiter Information:
The 340i is equipped with an 8HP50 transmission where the factory torque limiter is set to 550NM which is roughly 400ftlb tq @ the crank. For the best results and proper smoothing of the torque curve without any transmission related torque intervention we have found that is best to increase the limiter within the transmission software. We can present you with two options to implement this on your vehicle.
Option 1: Lifting the limiter in the transmission ECU which can be done for example with xHP Flashtool - based on information from their Facebook Page the flashing possibility arriving soon.
Option 2: Bringing the car to our shop for reprogramming of the transmission ECU
STAGE 3: +XX HP + XX Torque (Actual Dyno Numbers @ Crank) – in development
This software will be intended for those of you who will modify their exhaust by fitting either a catless downpipe or a downpipe fitted with a high flow catalytic converter. We will be fitting our tester vehicle with both options, analyze the pros and cons of either and will soon have a solution released after extensive testing on both the dyno and road.
Below will be examples of our dyno and logs from our research and development:
ST1 vs stock
Basic log ST1 here https://datazap.me/u/mgflasher/st1b58?log=0&data=9
· ST1 vs MPPSK vs stock
ST2 vs stock
Basic log for ST2 here https://datazap.me/u/mgflasher/st2b58?log=0&data=9
Now, enjoy some eye candy!
Just a teaser of MG Flasher in action:
New Addition in the app - Logger
MG Flasher offers products intended only for competition racing/off-road use which may not be road legal in your region. MG Flasher accepts no responsibility for compliance with vehicle’s factory warranty or road legality.
Appreciate 11
Nugget649.50
B58togo808.50
RustyBitz1573.50
eluded3029.00
clee1982797.50
Forgiven121.50
135iDCT137.00
      10-15-2018, 03:18 PM   #2
TorqueAddict
TorqueAddict's Avatar
Drives: 340i - 335D
+1 For JR. Solid tunes!
JR Auto tune and Bohl Diesel Downpipe - KWv2 coils - Apex Racing 18" EC7 wheels wrapped in Michelin PSS 245/275 F/R - Zimmerman cross drilled rotors F/R with Hawk HPS pads - SS brake lines - Motul RBF 600 - ADD W1 oil catch can - BMW performance CF spoiler
      10-15-2018, 04:04 PM   #3
B58
B58's Avatar
558
Drives: 922 Turbo
Waiting for the stage 2 numbers
2024 X3 M40i
2014 BMW M5
      10-15-2018, 04:17 PM   #4
NISFAN
NISFAN's Avatar
Drives: BMW M2
Awesome, any issues running this on F22 M240i ???
      10-15-2018, 04:24 PM   #5
Jarek@JRAuto
Drives: G20 340i
ST2 dyno diagrams are in the post, ST3 will be developed soon
arvi60461.00
      10-15-2018, 04:38 PM   #6
B58
B58's Avatar
558
Drives: 922 Turbo
Sorry i meant stage 3 with the exhaust modification.
Has the fuel system been tweaked around so you can run a more ethanol mix safely?
2024 X3 M40i
2014 BMW M5
      10-15-2018, 06:50 PM   #7
G.Newt
Drives: CT4-V Blackwing 6MT
I'm more interested in awhp and torque dyno numbers. If I do the usual 0.85 * crank hp/torque, these don't compare favorably to Mission Performance. This is assuming there is a 15% drivetrain loss.
I also know you can't compare dyno to dyno, but rather take the deltas into consideration. Still, I'd like to see something to give me an idea of what the car will put down to the concrete.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      10-15-2018, 07:21 PM   #8
mookie45
mookie45's Avatar
770
Drives: 2017 AW 340i M-Sport
Congrats on offering another solid option!
So to eliminate torque intervention for driveability purposes, we have to get xHP flash tool? Is this additional cost to the tune?
      10-15-2018, 08:09 PM   #9
DG20
DG20's Avatar
Drives: M340i
This is probably a stupid question and unrealistic, but is a burble tune offered separately or do you have to get the main tune for that to be an option? And also where could I get some pricing info?
Thanks!
Instagram: @dg_g20
      10-15-2018, 09:18 PM   #10
B58togo
Drives: M240i
There’s no magic bullet to make power that any company is going to come up with to have an advantage over the others. Boost, timing, A/F ratios are where the power lies and all will make similar power. At the end of the day, it’s best practice to pick the company with the best customer service. By next spring PTF will have released BM3 for this platform and MHD will be in the game as well. Then pricng will get competitive and the cream will rise to the top.
G.Newt810.50
ceedawg467.50
kern4174446.50
      10-15-2018, 09:19 PM   #11
Jarek@JRAuto
Drives: G20 340i
No issues at all with your F22 M240i - the same DME8.6 ECU with same hardware - there is some data software difference. We have most of the newest software versions/calibration.
      10-15-2018, 09:21 PM   #12
Jarek@JRAuto
Drives: G20 340i
Thank you very much for your response. Just as you said, deltas matter more than anything. Our dyno has produced comparable values to the figures published by BMW. Many factors effect wheel horsepower. We believe it is enough to show the customer the information displayed above.
      10-15-2018, 09:40 PM   #13
BPAC306
BPAC306's Avatar
Drives: M240I X
Does the M240 need a trans update for stage 2? I'm thinking a sweet spot for stage 1 would be 17 psi as the m240 is basically the mppsk b58
M240i xdrive - K&N Drop in, MPE
12.3 @ 108 Stock
      10-16-2018, 12:22 AM   #14
StockLOL
Drives: 2018 340i MPPSK
For us in California/Arizona/Nevada only have access to 91 octane and e85. Would the Stage 2 tune be good to run on an ethanol mix? 3 gallons e85 with the rest 91 to get 93.
      10-16-2018, 06:28 AM   #15
BLACK HAWK DOWN
BLACK HAWK DOWN's Avatar
Drives: 16' AW 340i xDrive
Prices?
Their whole life sheep are scared of the wolf but in the end, it's the sheppard who eats them.
      10-16-2018, 08:23 AM   #16
B58togo
Drives: M240i
Originally Posted by BPAC306 View Post
Does the M240 need a trans update for stage 2? I'm thinking a sweet spot for stage 1 would be 17 psi as the m240 is basically the mppks b58
I don’t understand why so many people think the M240i is “basically” the MPPSK B58. It doesn’t have M Performance exhaust and it doesn’t dyno appreciably more than a base 340i. It’s probably running a whopping extra pound of boost.
      10-16-2018, 08:24 AM   #17
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
looks promsises , can you send me a p.m. with prices ( my car is a m240i xdrive 2017 )
thanks in advance
      10-16-2018, 09:54 AM   #18
B58
B58's Avatar
558
Drives: 922 Turbo
Because it says ///M before the 240i
2024 X3 M40i
2014 BMW M5
      10-16-2018, 10:00 AM   #19
rahlow
Drives: 2016 340i
I would very much appreciate a PM with prices as well. I purchased the stage 2 flasher tune originally as I have a catless downpipe and I'm very interested in working out that torque limiter situation and taking advantage of that with possibly stage 3 in the future as with stage 2, If over 400hp I'm bairly there. I need more power!
      10-16-2018, 10:46 AM   #20
B58
B58's Avatar
558
Drives: 922 Turbo
Originally Posted by rahlow View Post
I need more power!
I need like 460-475rwhp to be satisfied. My 340i feels slow even with JB4 map 3 and map 5.
2024 X3 M40i
2014 BMW M5
      10-16-2018, 12:06 PM   #21
marcthedark
Drives: M240i xdrive Convertible
a) how about a stage 1.5 for 91-93 gas (usually get 93 but some stations have only 92 or even 91)
b) this needs a release asap as doing everything on the iPhone is just so choice
c) Group Buy !?!
      10-16-2018, 12:09 PM   #22
ivanj308
Drives: M240i DownPipe MHD
Questions
I am assuming those of us with 6 speed manuals have no need to be concerned about torque limitations ?
Any options to change throttle mappings for Comfort/Sport ? Is this possible with a custom tune ?
Any options to control rev matching ?
kern4174446.50
