08-14-2019, 08:54 PM | #1 |
Rep 7
Bird Crap on paint stained it ? Or just deep dirt?
Hey guys , quick question is it possible for bird crap to stain the car paint or leave its marking after it's washed off not even sure if it's bird crap or it just might be dirt ? Seems like I have a few though so any recommendations on product that can clean them off like a wax or paste ?
08-15-2019, 03:05 AM | #2 |
Rep 202
Yep, it definitely will stain your clear coat if you don't remove it quickly. In fact, if left long enough it will actually etch through your clear coat and totally destroy it.
If it is just a dull mark, you should be able to hand polish it out with a coarse or heavy polishing sponge and a polish of your choice. If that doesn't do it then try some rubbing compound with a hand polish afterwards. If not, then a machine polish will certainly get it out. However, if it has started to craze the clear coat, then a machine polish may get it out depending on how deep the etching is, but if not, then youre looking at a wet sand a polish at best. FYI, wax doesn't have any cleaning properties whatsoever, wax is just used as a protectant and to exaggerate the gloss of your paint, it wont clean anything off other than light water marks. Keeping your car waxed with a quality product will certainly help prevent stains like from occurring in the future though, but I would still recommend removing bird crap as soon as possible regardless. Hope that helps |
09-02-2019, 06:10 AM | #3 |
Rep 3,827
The above is very true.
Depending on the bird and the weather (direct sunlight expedites the process), you may get very noticable damage on your clear coat! On my Audi, I have 2 spots on the roof where the clear-coat has been literally micro-cracked by the bird crap which was there for just a couple of hours one sunny day...... The cracks are quite deep, so polishing only improved and evened out the top surface, but the spots are still visible (if you look for them). So rule #1: Remove bird crap (and dead insects) A.S.A.P.!! What A.S.A.P. means is up to you. For me it means I go out of work if I see my car with a bird crap on the parking lot outside. I remove insects within the day (with wet wipes, detailer or water, whichever is available). Always keep a bottle of Quick Detailer and MF clothes in your trunk. Rule #2: Regularly use wax or ceramic sealers. I do not know how much they protect against bird crap (especially the waxes). It certainly depends on the wax/sealant as well. But best case - they give you some extra time to clean without damage, but they are not a full protection. Ref. Rule #1.
09-02-2019, 07:45 AM | #4 |
Rep 15,935
That's what you apply to protect the paint after you've cleaned it. A polymer sealant is best, as it prevents crap, including bird crap, from reaching the paint. I use Jescar Power Lock myself.
09-02-2019, 10:55 AM | #5 |
Rep 55
Have a full paint inspection / correction done and ceramic coat the entire vehicle + wheels for best protection against stains / light scratches & swirls and fading from UV.
Have the correction done professionally and perhaps the first application of ceramic, every year or two you can re-apply the ceramic yourself if you're keen with that kind of thing.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
10-11-2019, 05:46 PM | #6 | |
Rep 62
