07-12-2020, 01:55 PM | #1 |
Rep 90
Drives: 2013 BMW 328i
drivers side brake light housing sticking out
I have started to notice that sometimes when I approach my car that I will see the brake light housing on the drivers side sticking out a bit. I am specifically talking about the part that is connected to the trunk door. The part that sticks out is the edge next the brake lights that are actually part of the chassis. With my hand I can kind of push it back into place, but every once in a while it will start sticking out a bit again. I wanted to see if anyone here is having or has had the same issue and what their solutions were to this issue.
07-12-2020, 10:32 PM | #2 |
Rep 211
It is a known problem. To get to the light, remove the trunk lid liner. Once you unplug the harness, there is a retaining nut holding a white nylon lock piece. Removing that nut and lock piece lets you remove the light.
If you are lucky, the retaining tab on the light housing has simply slipped out of its place (a slot on the trunk lid). You can actually take a large screwdriver and gently tweak the opening of the slot to grab the tab a little more. Reassemble and enjoy the fact that it doesn't pop out anymore. If you are unlucky, you get to replace the light housing (used about $50 on eBay). When you reinstall the new one, do the tweak described above. If you have only had this problem on one side, fix it on both sides when you have the liner out! I had to replace one of mine, but was able to fix one without replacing. |
sick_guy18.50 |
07-12-2020, 10:45 PM | #3 | |
Rep 90
07-13-2020, 10:16 AM | #4 |
Rep 211
To engage the tab, the light has to slide inboard. Consequently, when you remove it, slide it outboard about 1/4". When the outer edge is loose, you can pull the entire light assembly out. You may have to compress against the weather seal to get it to slide in or out.
07-13-2020, 03:30 PM | #5 | |
Rep 90
08-09-2020, 02:17 PM | #6 |
Rep 90
Update: I was super lucky and the tab was just out of place. I just put it back and that was that
08-31-2020, 10:41 AM | #7 |
Rep 211
08-31-2020, 04:37 PM | #8 |
Rep 90
I bent it a tad bit like you said so hopefully it stays in place. I was actually considering getting the depo blackline lci tail lights in the future so worst case scenario I'll just get a new set of housings.
