09-05-2020, 02:10 PM | #1 |
Rep 1,794
Drives: F30 328i M 6mt, E36 M3
Lower Wishbone Install gone wrong (one wheel drastic toe in)
Hey everyone -
When I swapped the lowers on my e90, the second time I did the job I didn't even need to have it lined up (even though I did). I did the f80 m3 lowers on the f30 and the pass wheel is toed way in.... If I only did connect the lower wishbones, why on earth would the toe be that far off? Did I bend something, or do I just need to have this thing flatbedded to an alignment rack? Thanks.
09-05-2020, 02:22 PM | #2 | |
Rep 15,858
09-05-2020, 04:38 PM | #3 | |
Rep 1,291
You can't get anywhere, you need to align on the spot at least roughly. But since f80 and f30 have different subframes these parts are not an obvious swap (been there, removed them and got camber plates)
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
09-05-2020, 05:31 PM | #4 | |
Rep 1,794
Thankfully I have another car to drive.
09-06-2020, 11:03 PM | #5 |
Rep 894
I went with the turner motorsports monoball thrust arms and it helped the steering feel a lot. Plus they dont mess with the suspension geometry like the F8x stuff does.
09-07-2020, 03:17 AM | #6 |
Rep 8,495
There's a lot of information on this. The F8X arms are not a straightforward swap due to their increased length.
Turner, Millway, and VAC have options for replacing the bushes. If you want a straightforward out/in option (i.e. not having to machine-press the bushes) SuperPro has a new 4-arm kit coming to market which uses encapsulated monoballs in the wishbones (so no geometry issues).
09-11-2020, 05:14 PM | #7 |
Rep 2,044
Hello BMW Experts!
Even when changing to F80 lateral links (or whatever), giving your car a rough alignment isn't too hard. Put your car up a little so you can fit under the front end. Then run a tape measure up as high as you can on the front tires, measuring the distance between identical points on the right & left tires. Then do this on the rear of the tires, matching the length of the front & rear measurements by turning the tie rods. This should get you to the shop. Clear as mud? Somehow, I don't think about the ~ 1/4 inch of tierod left screwed in after the F80 LCA switch anymore.... Murf Last edited by Littlebear; 09-13-2020 at 04:57 AM.. |
09-12-2020, 02:51 PM | #8 |
Rep 1,794
Update...
I forgot how much the longer arms would change the toe lol.. I had the car lined up with a fairly aggressive spec, really woke up the feel of the car. .05 toe -1.9 Camber driver -2.1 Pass (closest a shop has come to what I asked for) rear .1 toe -1.5 Camber In addition it should be easy on tires, but all 4 have worn evenly in the past. The steering is very responsive, I might have a little more toe added back in the front if it feels out of sorts. I'll be doing an hpde with it in a few weeks, I run 245/40/17 RS4s (from my e36). I'd like to autocross it before then just to see the difference. apparently grey brake 328i cars have odd pads, finding a track pad that doesn't break the bank is impossible.
