01-30-2016, 10:11 AM | #1 |
Two turbos are better than one!
119
Rep 404
Begginer's guide to BMW Live and Internet
I have been collecting various bits of information (Mostly from Shawn Sheridan's work) to make a step by step beginner friendly (For myself - I have done FDL coding but that is all so far) guide to activate BMW live and internet over phone's SIM card.
I was hoping one of the more experienced coders could look at this and verify that I have the correct sequence and details the write up and verify that it is correct??? ** I AM NOT SURE IF I HAVE EVERYTHING IN THE CORRECT SEQUENCE AND DETAIL LEVEL. USE AT OWN RISK ** Step by step procedure on how to enable BMW live and internet: 1. Change your VO as follows (This adds the options for BMW live and internet to the car's option list): Connect => Read FA (VO)=> Edit FA (VO)=> Right click on FA => Calculate FP => Expand FA => click on SALAPA-element =>Delete/add FA from the bottom left window (see below) => click Apply changes => Right click on FA => Calculate FP => Save FA => Goto Expert mode => VCM => Load saved FA (VO)=> Right click on FA => Calculate FP => click "write FA FP VIN" - 612 (or 633 or 639 if present) + 644 <- Bluetooth phone preparation + 614 <- Internet Access + 615 <-Online Information Services + 6AL <- BMW Live + 6AB <- Control Teleservices 2. VO CODE HU_CIC (modifies the headunit with the new car options from step 1): Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on Head Unit ECU (e.g. HU_NBT, HU_CIC, HU_CHAMP, HU_ENTRY, HU_ENTRYNAV, etc.) (the ECU itself not the underlying CAFD) => Select CODE (Not Code FDL). 3. VO CODE CMB_MEDIA(modifies the Combox with the new car options from step 1): Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on CMB_MEDIA (the ECU itself not the underlying CAFD) => Select CODE (Not Code FDL). 4. FDL CODE CMB_MEDIA (This step will allow you to write a fake VIN in your Combox: FDL code CMB_MEDIA / TELEMATIK_VIN =Your real FA VIN This will allow you to alter the VIN for the later steps. 5. Change VIN to fake VIN in VO and FDL code to Combox (Allows the fake VIN to be transferred to the Combox) (DO NOT code anything else with this FA, and DO NOT write this FA to the car)For Internet and BMW Live to work, you need a VIN with factory options 614 and 615. Connect => Read FA (VO)=> Edit FA (VO) => Change VIN to FAKE VIN=> Right click on FA => Calculate FP => => Save FA using new name FA_FAKEVIN=> Goto Expert mode => VCM => Load saved FA_FAKEVIN (VO)=> Right click on FA => Calculate FP=>FDL code CMB_MEDIA 6. Read CMB_MEDIA coding data, and verify the new VIN in brackets. 7. FDL CODE Combox and HU and make sure these parameters are as follows (Make note of the original settings in case you need to revert back) : CMB_MEDIA: - MAIN_BOARD_ALONE: mainboard_alone - ETHERNET: nicht_aktiv - DUN_PROFILE: aktiv - PAN_PROFILE: aktiv - BT_EIN_AUS: aktiv - TELEMATIK_VIN: Coding_vin - STARTUP_ACTIVE: nicht_aktiv - DATACOMM_INTERFACE: mamac - SIM_ENABLED_MB: enabled_all - DATACOMM_CSIM: aktiv - ONLINE_ROUTER: aktiv HU_CIC: - CONNECTED_DRIVE: aktiv - PAN_PROFILE: nicht_akitv - DUN_PROFILE: nicht_akitv - BT_MODUL_ON_OFF: nicht_aktiv - BT_DATA_SERVICE: nicht_aktiv - DATACOMM_INTERFACE: combox - DATACOMM_TRANSFER: mamac - ONLINE_BROWSER: nur_mit_bmw_internet - ONLINE_SERVICES: nicht_aktiv - ONLINE_SERVICES_GLS: nicht_aktiv - TDA_CFG_CUST_MOBILE_USE: aktiv - ONLINE_BROWSER_LIVE: aktiv 8. Either shut down E-Sys, or load your original FA back and activate it before coding anything else. 9. Enable Data Transfer Option Under Phone 10. Enable Bluetooth Data Tethering on Phone 11. Under Connected drive; Update services (should show BMW Live and Internet services) 12. Go to BMW Live and Internet and make sure it is working 13. After it is working, use original VO with car VIN: 14. FDL CODE CMB_MEDIA with VO which has original VIN Connect => Read FA (VO)=> Edit FA (VO) => Change VIN to FAKE VIN=> Right click on FA => Calculate FP => => Save FA using new name FA_FAKEVIN=> Goto Expert mode => VCM => Load saved FA (VO)=> Right click on FA => Calculate FP=>FDL code CMB_MEDIA TELEMATIK_VIN = MOST_VIN 15. Read CMB_MEDIA and verify Short VIN in brackets [xxxxxxx] is car VIN. DO NOT update services again or you will lose BMW Live and Internet. *** If you do not return the Combox VIN to car VIN, you will encounter problems with future dealer programming, as the Combox will not be recognized, and programming will halt. ***
Sapphire Black M4 Competition Last edited by rezadue; 02-05-2016 at 07:43 AM.. |
01-31-2016, 05:12 AM | #3 | |
Rep 11
01-31-2016, 05:04 PM | #4 |
119
Rep 404
Thank you. Corrected.
Sapphire Black M4 Competition |
01-31-2016, 07:07 PM | #8 |
119
Rep 404
Not everyone has it. As best as I can figure out in some markets like north America you can order it, but it uses the SIM card in your car.
In some markets like the UK it can use your phone's SIM card. I an in Canada and my car didn't come with it, so I don't have a telematik Combox. So I am trying to a ti ate BMW live and Internet through my phone. |
02-05-2016, 08:21 AM | #11 |
867-5309
76
Rep 308
Drives: F80 M3 ZCP and E36 328i
12-01-2017, 04:22 PM | #12 | |
Rep 524
trying to FDL code instead of VO
I have a US Spec car with an expired BMW Assist and would like to FDL code for BMW Live. Do these settings work? Is there a detailed write up of FDL coding instead of the VO coding for these parameters?
12-08-2017, 07:37 PM | #13 |
Rep 524
having trouble injecting fake VIN to CMB_Media
I got everything to work including changing the VIN and saving it and reloading it in Esys, however when I go to code for CMB_Media with the fake VIN, I get a finalizeECUcoding error - says there was an error during TAL execution, something about service returned global negative response.
What am I doing wrong? I do have the updated Combox from 3G to 4G, is that what could be causing issues with this? |
02-10-2019, 11:45 AM | #14 |
Rep 5
Hello everyone,
sorry for bringing this thread back from the death. I just need some information, i have a f20 2015 with hu_entrynav with stabdard navigation system. I already coded the ebt but i m having some troubles to get the bmw live. The first problem is at step 1 because if i try to add 644 it return an error when coded, thus i tried to get over not adding that feature, a d it works (but i have no 644), the second the problem is at step 3 because i have no bmc_media...what's the problem? I miss any hardware? Thanks in advance |
05-07-2019, 05:56 AM | #15 |
Rep 3
Help needed please
Hi all
I was trying to do this and now my car won’t start shows loads of errors and so I took it to bmw and they won’t touch it as it doesn’t have the original headunit . They also say the VO has been changed. I brought the car from auction about a year ago and it came with the nbt unit already installed |
03-02-2020, 12:02 PM | #16 |
Always on track!
Rep 90
Drives: 328i
Hello, I would give a try to this function in my car, but I can't find CMB_MEDIA ECU. On the list of ECUs there is only HU_NBT.
03-02-2020, 12:10 PM | #17 |
Rep 40,786
NBT Head Unit has Combox functions within itself and not a separate standalone CMB_MEDIA Control Unit.
03-02-2020, 01:11 PM | #18 |
Always on track!
Rep 90
Drives: 328i
So this newbie guide for me don't work, right?
Because these steps aren't applicable: 4. FDL CODE CMB_MEDIA (This step will allow you to write a fake VIN in your Combox: FDL code CMB_MEDIA / TELEMATIK_VIN =Your real FA VIN This will allow you to alter the VIN for the later steps. 5. Change VIN to fake VIN in VO and FDL code to Combox (Allows the fake VIN to be transferred to the Combox) |
03-02-2020, 05:39 PM | #19 | |
Rep 40,786
This method though is just a way to reprovision the Car SIM to get BMW Live and Internet, by provisioning car with different VIN that is authorized the services. For NBT, this can be accomplished with Tool32, whereby instead of using provisioning file of other VIN, you edit the car's own provisioning file to add the services: https://www.bimmerfest.com/forums/sh...d.php?t=735962
03-04-2020, 03:16 AM | #20 |
Always on track!
Rep 90
Drives: 328i
OK thanks, i'll give a try to this procedure:
https://www.bimmerfest.com/forums/sh...&postcount=542 |
03-04-2020, 05:08 AM | #21 | |
Rep 40,786
03-18-2020, 04:30 PM | #22 |
Always on track!
Rep 90
Drives: 328i
I've got ERROR_ECU_REQUEST_SEQUENCE_ERROR while reading in tool32, anyone can send me another version of NBT.prg to try? I heard that exist 3 versions...
