BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
      01-28-2017, 08:42 AM   #89
atzebmw
Drives: Tesla Model 3
If someone is interested and is looking for the RDC control unit 36106855180, then I have one to sell. I don't want much money for it.
It's almost new.
      01-28-2017, 02:47 PM   #90
anom3
Drives: F30 335ix
Good work!
Larry, I will be doing the same install as you next week. I will move my module ot the factory location.
Question : Were you able to do this without lifting the rear of the car?
Originally Posted by larry_bml View Post
So, I received all parts needed and started this retrofit last evening at 20:00 and finished it at 22:00 .
I installed wheels sensors on daytime. I made the wires for module, I installed module in factory way, routed the cables inside trunk, took power from rear fuse box, just as factory from fuse 132, 5A. CAN conection was made to iDrive controller, as I couldn't find conections where ISTA+ showed. Coded car, and drive 1-2 km, and everything is fine now.
      01-28-2017, 03:17 PM   #91
atzebmw
The car has to be lifted up, otherwise there is not enough space to work.
Also because the control unit is in the middle under the car.
      01-29-2017, 03:18 AM   #92
larry_bml
larry_bml's Avatar
Romania
194
Drives: BMW F30 Sport Line 320ded
Good work!
Thank you, and about your question, we have an hole in the floor, special for going under the car. You can't install ECU under the car, without going under the car. On a flat surface there will be no space to go under.
      01-30-2017, 08:40 AM   #93
gup
Drives: f20
@lary_bml
very well done. wish I had the skills.
      01-30-2017, 10:23 AM   #94
larry_bml
larry_bml's Avatar
Romania
194
We want to come to Greece for summer holiday, we can install yours too )))))
      01-30-2017, 02:54 PM   #95
gup
Drives: f20
Name the day!
      02-01-2017, 08:42 AM   #96
anom3
Drives: F30 335ix
Ok so I had another go at making my 'easy install' method 100%.
I was able to make the proper tire locations show up in their proper places. Front was rear, rear was front, now is correct.
The way I did this:
A) Load up INPA (yes, INPA...).
B) My INPA has a F30 section. Goto the RDC module.
C)
I wont go into exact details because it was all in german...
But if you first check the status section, you will see the id numbers of each of the sensors. They can also be read off the TPMS sensors.
Then I went to the "write" (scriben I think it was). And there is a way to manually input the sensor numbers. So I moved the rear to the front, and the front to the rear.
D) Went for a 40 minute drive today. With a stop in between. The fronts show in the correct location, the rears in the correct location.
So it is possible to have the wheels show up in the correct locations even if the RDC module is in the incorrect location. You just need to enter the id numbers manually via INPA.
      02-01-2017, 09:29 AM   #97
larry_bml
larry_bml's Avatar
Romania
194
Good job, Congratulations!
      02-01-2017, 03:02 PM   #98
Apples12
Drives: 520D LCI auto
Hi,
Does anyone know if you can install a TPMS module from a different model? i.e. a TPMS module (control unit) from a f30 into a f10 or a 1series into a 5series
many thanks
      02-01-2017, 03:18 PM   #99
atzebmw
Originally Posted by Apples12 View Post
Hi,
many thanks
On my old F30 i installed the tpms module from a F10.
So i would say in principle, they are interchangeable.
But i also have to say that there can be problems at the coding.
      02-02-2017, 12:48 AM   #100
larry_bml
larry_bml's Avatar
Romania
194
I think that it doesn't worth the risk to buy something else. It is possible to work, but You have the same chance not to go, and then there you are wasting money. If you decide to try, please let us know the working or not combination of sensors and ECU.
      02-05-2017, 05:46 PM   #101
DimitrisM3
e90 my big fat lady!
DimitrisM3's Avatar
Greece
49
Drives: e90
Ok lets do same thing difficult!!!!
I have install nbt unit into my e90 and I want to install the sensors and antennas
Complete retrofit ...
they told that this will work to into my car what's your opinion
      02-06-2017, 03:27 AM   #102
larry_bml
larry_bml's Avatar
Romania
194
For E90, my opinion is to buy what was factory fitted for that car. NBT will display values if it will receive them from car. But first you have to be sure, that RDC is working on your car.
      02-06-2017, 08:40 AM   #103
DimitrisM3
DimitrisM3's Avatar
Greece
49
Drives: e90
I think this is the easy part but will work with nbt ??
And the second that they told to install the newest parts from e90 2011 model
That works this the 2 antennas and four sensors in the wheels
      02-06-2017, 09:18 AM   #104
larry_bml
larry_bml's Avatar
Romania
194
It will work with NBT, your eNBT addapter must know to translate signals
      02-06-2017, 02:33 PM   #105
DimitrisM3
DimitrisM3's Avatar
Greece
49
Drives: e90
Sent you pm
      02-17-2017, 03:25 PM   #106
Conne11
England
Drives: F32 435d
Guys i have been looking at this of sometime now and have checked my car and it does indeed have the DSC Mk100 module installed. looking at this from Gabrola it would appear that i only need to buy the sensors and coding to get this working? Does anybody have the exact part number i would need for the sensors as there are quite a few listed in this thread?
Originally Posted by Gabrola View Post
A friendly reminder for those doing the retrofit on newer cars with a DSC MK100 module; there is no need for an RDC module or antenna since that is already integrated in the DSC module. So you're only left with installing the TPMS sensors in the wheels and coding. I'm not sure at what model year was this change made but you can check through ISTA or physically inspect your DSC module to see if it says "DSC MK100".
      02-17-2017, 06:25 PM   #107
Gabrola
Gabrola's Avatar
191
Drives: 340i
This is the part number I used 36106856209 and has been working perfectly for me.
      02-22-2017, 10:04 AM   #108
larrylam646
larrylam646's Avatar
Drives: 2020 M340i xDrive
It will depend on the vehicle manufacturing date. If your vehicle was manufactured on/after 03/14, then adding the '209 sensors and coding will likely work.
I added the '209 wheel sensors and coded my 435iX 10/13 build date with the MK100 DSC. No errors were generated while coding but the TPMS system would not calibrate. After some debugging using Rheingold, I determined the Radio Remote Control Receiver, used to read the wheel sensors, is not compatible with the '209 wheel sensors.
I purchased the newer Radio Remote Control Receiver and was getting ready to install only to discover, I would have to also purchase the newer Set, Key with FEM - 41_2456.
I have abandoned this approach
Larry
2020 Black Sapphire M340iX
2014 Estoril Blue 435iX - sold
      05-01-2017, 02:16 AM   #109
KingpinRCR
Belgium
61
Drives: F30 320d ed
Hello everyone,
I have a 02/2012 built with navi pro cic, not nbt, if I buy control unit 6876227 together with the sensors 6856227, will this work?
Does the harness and coding stay the same for cic?
Also, how do I open up the connector to the fem to add the 2 pins?
Kind regards,
KingpinRCR
      05-01-2017, 04:16 AM   #110
atzebmw
Originally Posted by KingpinRCR View Post
Hello everyone,
Kind regards,
KingpinRCR
I do not know exactly, but i would say it works. Because these parts are actually for the f10 and there was the cic together with the rdc.
