04-06-2019, 10:22 PM | #45 | |
David
786
Rep 2,009
04-07-2019, 11:33 AM | #46 |
Rep 14
Sorry for the text wall. I have an interesting bit of data to add to this. I have a 2014 328d that’s no longer under warranty with a slow coolant leak that I’ve noticed since last year. I first noticed it when the coolant light came on, and I had to top of the reservoir. Since then, I have had to add either EG mix or distilled water to the reservoir every few thousand miles. I learned about the recall right before I had an issue with mine. So, here’s the saga.
I was driving the car to work when the EML came on. I don’t live far from the local BMW dealership (Beaumont), and it was a quick drive in. So, I left it with them. They diagnosed the problem pretty quick as an EGR failure and a melted intake. Here’s where it gets odd. They immediately stated that the EGR cooler could not have had anything to do with it because the boroscope images of my cooler look like the “normal” sooty condition in their guidance from the BMW technical staff. So, they gave me the repair bill (~$3k), and said it would not be covered under the recall. I can’t imagine BMW would want me to perform all of this work, and then put the cooler back on the car, knowing there is a leaking coolant problem with no obvious signs of leaking coolant, and the car just recently had a melted intake. So, then the BMW team later came back and said although the cooler is “normal,” I need to go ahead and change it. Lol…wth? When I asked the dealership what they were talking about, I then asked the simple question. Has the cooler failed or not? They literally gave me two different answers for the same question. So, the repair bill is up to nearly $5k even before they get into it. They also have not performed any troubleshooting on where the leaking coolant is actually going. It’s just comical at this point, because I can swap the intake and change the parts myself. The care is still with them now for over 3 weeks. So, I’m wondering my next steps. I have not logged anything with the NHTSA or anything like that. I’ve been cool with everyone, and the case is still open. I believe my case is one where I can help others on the forum, if nothing else but a data point. The parts from my car can be a forensic piece of data, as I’m really beginning to wonder if BMW fully understands how to diagnose the problem. The root cause is a mechanical failure of the cooler, but the deciding factor for recall claims is a very subjective image of the fins on a cooler based on sludge build-up. I think BMW may be realizing these coolers can fail and not exhibit the subjective levels they are showing from their “normal” images. Hence, I believe BMW would like to get my likely defective parts off the car whether either I or they pay for the replacement. I'll keep everyone posted on the outcome. |
04-07-2019, 03:03 PM | #47 | |
David
786
Rep 2,009
Wow i would completely go off on them, what did they speculate the loss of coolant was from? a blown head gasket, or a faulty transmission cooler line? wtf? Sounds like they're trying to foot the bill to you instead of doing the right thing, i would've left immediately and went to another dealership. |
04-07-2019, 03:17 PM | #48 | |
Rep 14
I can't answer for BMW, but if I were the engineers on this one, I would likely at least offer to change the cooler. They already know there was a bad batch, and it's a quick part to change. I already told them I have UV dye in the system, so they should be able to cut the part and see if it is where it shouldn't be. Looking for dye with a black light on a shop bench is much easier to say yay or nay versus comparing sludge levels on a cooler fin for soot that gets sooty anyway. I would say it's just a bad system from the start, and an EGR component is definitely causing damage to intake manifolds (or worse). I feel like they are splitting hairs on this one, and I really just don't see how they could be right. Again, I'm letting it play out, but it's just really odd at this point. I'll be back at work tomorrow, so I may not reply immediately, but I'll surely keep everyone posted. Last edited by Newgene; 04-07-2019 at 03:53 PM.. |
04-07-2019, 05:27 PM | #49 | |
David
786
Rep 2,009
04-14-2019, 12:19 AM | #50 |
David
786
Rep 2,009
Received my first call today informing me that parts are available and they are ready to work the recall.
Only issue is my vehicle isn't experiencing coolant loss, and based on the remedy instructions/TSB if your EGR cooler passes inspection (no coolant/soot build up in the cooler) then all they do it replace an o-ring and reassemble, I attached the TSB. So i'm going to wait at least another 25-50k miles before taking it in because I don't want to pass inspection, then have the cooler fail down the road and be denied replacement, if that is how the system works? Last edited by 328iX; 04-14-2019 at 12:31 AM.. |
04-15-2019, 07:51 AM | #51 | |
Rep 424
04-15-2019, 10:33 AM | #52 |
Rep 10
EGR Cooler Failure - still no parts available
The EGR cooler on my 2014 328d failed in November 2018. There was a bit of exhaust migrating into the ventilation system and it progressed to full gas chamber experience in about 3 weeks. There was info posted around that time on the EGR cooler recalls in Korea with talk of extending the recall to other regions.
The local dealer wouldn't take the car for the recall issue until January. It has been sitting on the lot at Performance BMW in Raleigh NC since January 15. Checked again today - no parts available, no horizon for parts delivery. No loaner vehicle so far, either. |
04-15-2019, 10:35 AM | #53 | |
David
786
Rep 2,009
04-15-2019, 11:42 AM | #54 |
Rep 14
I am working with them now, but it's still up in the air. However, the last conversation was better. They understand where I'm at. I'm trying to get their clear position on the cooler. If it's bad, I believe it should be covered. If it's not bad, I'm not sure they really recommend putting it back on the car knowing something has been leaking coolant. With all the telltale signs, I just don't see how it's not the cooler. I'll definitely update this post either way. They've had my car for a month, so I hope it gets resolved soon.
04-15-2019, 05:14 PM | #55 | |
David
786
Rep 2,009
04-15-2019, 05:55 PM | #56 |
Rep 112
Drives: 2014 328D
I called my Dealer last week and was told the parts aren’t available yet.....Silver Spring Md
04-17-2019, 07:31 PM | #57 |
Rep 14
Oh well, I received a call back from BMW NA today, and they said they talked to the engineering team, and they stated that carbon buildup caused the failure of the EGR system, which includes the cooler, valve, and intake. They still haven't figured out why the coolant has been leaking since last year, and they haven't discussed if any excess carbon is related to the failed cooler. They are still with a denial to claim any of this under recall, and they stand behind their statement that the cooler needs to be changed. I'm disappointed in BMW at this point, and I have another '18 diesel X5. Loyalty has not been a factor in anything to date. I am still asking to escalate this to another level, and I would like to directly talk with someone technical. I also asked them to put in writing if the cooler is bad or not. They are saying it is bad, but they are saying they won't cover it under recall. I'll post when I hear more.
04-17-2019, 08:53 PM | #58 | |
David
786
Rep 2,009
04-18-2019, 07:55 PM | #59 |
Rep 14
It has right at 100k miles on it. Here is an image of the fins. Clearly there is some build-up on the fins. I just don't know how they have arrived at their pass fail criteria to determine if an EGR cooler is leaking. I would assume some have much worse leaks than others, and I believe that is evident from their bad images, which I would assume are very severe. In my photo, you can see I have some fin holes blocked off. I would assume that not every car that fails the test has images as bad as below because I'm not sure if every car is going to make it to that point before an intake failure.
04-18-2019, 07:58 PM | #61 |
David
786
Rep 2,009
Now how can they know it's not EGR failure and caused by carbon build up. That is definite EGR failure they should be responsible!
04-18-2019, 08:19 PM | #62 |
Rep 14
I just want to make sure I'm not losing my mind, and others can see the build-up on the fins. If they are looking for wet soot in 100% of the cars with failed EGR's, they are overlooking other scenarios. If you have a car that has been leaking slower over a longer time, you should have more dry soot and less of the sludge. It is still a failure nonetheless. This is ridiculous.
04-18-2019, 10:12 PM | #63 | |
David
786
Rep 2,009
04-30-2019, 01:24 PM | #64 |
Rep 1,387
05-01-2019, 10:17 AM | #66 |
David
786
Rep 2,009
