      09-18-2021, 03:52 PM   #15995
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by RT330e View Post
How many posts to enable PM?
Requirement is:
"In order to use the PM system and be a full fledged member of this community, you will have to make 4 post replies and wait 1 hour for your account to be upgraded."
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      09-18-2021, 03:52 PM   #15996
RT330e
Drives: F30 330E
Requirement is:
It might be the hour then!
Thanks for the headsup.
      09-18-2021, 04:22 PM   #15997
Calmor
Drives: 2018 440i
Hi Shawn. Thanks for doing great stuff. Can you please send me the link to the latest as well?
Thanks!
      09-18-2021, 06:18 PM   #15998
shawnsheridan
Thanks!
PM sent.
      09-18-2021, 06:19 PM   #15999
shawnsheridan
PM sent.
      09-24-2021, 04:00 PM   #16000
JPierce63
Drives: 2014 328i
Hi Shawn,
Thanks for all your hard work and attention. Could you send me the link, as well?
Thank you!
      09-24-2021, 04:04 PM   #16001
shawnsheridan
Originally Posted by JPierce63 View Post
Hi Shawn,
Thank you!
PM sent.
      09-24-2021, 04:40 PM   #16002
JPierce63
Drives: 2014 328i
Thanks Shawn,
If I need to calibrate my 328i (N20)'s DME, injectors, etc.. and read trouble codes, etc.. Is E-SYS what I should be using?
Jeff
      09-24-2021, 04:43 PM   #16003
shawnsheridan
Thanks Shawn,
Jeff
No. E-Sys is for Coding and Programming. For Diagnosis, you need ISTA+.
      09-24-2021, 07:00 PM   #16004
omarsaudi
Drives: BMW F30
Thanks a lot
      09-25-2021, 09:28 AM   #16005
Ruse
Drives: BMW F34 335d 2015
Hi all
any link for Download SWID Reader
i'm appreciate
Tks
      09-25-2021, 09:35 AM   #16006
shawnsheridan
Originally Posted by Ruse View Post
Hi all
i'm appreciate
Tks
PM sent.
      09-25-2021, 11:15 AM   #16007
JPierce63
Drives: 2014 328i
Thanks Shawn. I am struggling to find any active ISTA download info here in the bimmerpost community. Can it be found here? Do you have a link to ISTA +?
      09-25-2021, 11:21 AM   #16008
shawnsheridan
PM sent.
      09-29-2021, 01:07 PM   #16009
Darth Vader
Darth Vader's Avatar
Drives: 2019 BMW X5 40i
Hi Shawn, could you send me the link to download the latest E-Sys Pro & psdzdata please?
      09-29-2021, 01:09 PM   #16010
shawnsheridan
PM sent.
      09-30-2021, 08:27 AM   #16011
barni320
Drives: BMW 428i F32
Hi,
Can you tell me what's the difference between coding on running engine or ignition? Most of the people recommend to do it on ignition. Are there any contraindications, that coding on running engine can brick something?
      09-30-2021, 09:58 AM   #16012
shawnsheridan
Originally Posted by barni320 View Post
Hi,
If you Code with only Ignition on, the car battery may not provide adequate Voltage to ECU(s)
Coding with Engine running ensures all ECU have adequate Voltage, and so long as you do NOT code DME / DDE (Engine ECU) with Engine running, then you have nothing to worry about.
      09-30-2021, 08:10 PM   #16013
barni320
OK, thanks for answer, that's what I was thinking about. I was aware of suddenly lost of power, because of low battery.
But I can't understand why people recommend to do it on ignition only 🤔. The same case when we talking about esys or bimmercode, even manufacturer of bimmercode says in manual that should be use on ignition. Confusing.
      10-02-2021, 10:58 AM   #16014
jmrluke
Drives: f30 318da
Thanks for the link! Appreciated!
      10-02-2021, 10:59 AM   #16015
shawnsheridan
Your Receive PM function is disabled. PM me when working.
      10-04-2021, 05:01 PM   #16016
CarlosIsDead
CarlosIsDead's Avatar
Drives: 2016 BMW M3
Requirement is:
"In order to use the PM system and be a full fledged member of this community, you will have to make [COLOR="Blue"]4 post replies and wait 1 hour[/COLOR] for your account to be upgraded."
Sent you a pm shawn!
