BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Approaching 70k n55 maintenance
      10-26-2020, 03:04 PM   #1
Pussiwillow
Drives: Alpine white 2014 335i msport
Hey guys! Have a fairly new to me 2014 335i msport zf8 automatic, I'm approaching 70k miles. I haven't touched the car aside from charge pipe and downpipe. I have a 1000$ budget for maintenance DIY.
This platform is new to me, PO serviced the car regularly but doesn't know what had been changed or done so I would like to have piece of mind for myself.
What should I prioritize for maintenance on engine and drivetrain?
Going to do an oil and filter change, what's the consensus on oil weight and brand specific, we are approaching winter however I'm in AZ and we don't usually go under 40• winter.
Going to do plugs, should I do the coils as well? Package deals on fcp have delphi and Bosch brand for good prices, maybe worth it?
Should I do the water pumps and thermostat at this point? Any particular hoses I should replace, all? Be one and done?
Transmission fluid and pan replacement?
Drive belt and tensioner?
Anything is super helpful thanks guys
      10-26-2020, 03:59 PM   #2
F32Fleet
Drives: 2015 435i
Plugs: 60k miles
Coils: 100k miles
ATF: approx 75k miles (iirc revised recommendation from ZF)
Water pump/thermostat: Whenever it starts to act up as it tends to fail slowly (ex, cooling fan continuously running at high speed).
Motor Oil: For the 10k mile drain interval look for LL01, LL01FE, or LL04 oil certs. If for some weird reason you can't find it then look for Mercedes Benz 229.50, 229.51 VW 504,507
Weights 0w-30, 0w-40, 5w-30, 5w-40
Walmart Castrol 0w40 is popular, so is M1 0w40, BMW TPT (dealer oil) is also very good.
Belt tensioner: It'll allow the belt to squeak. Replace belt along with it.
First I would look at the oil filter housing gasket (OFHG) and valve cover gasket for leaks. You don't want to let the OFHG go unattended.
      10-26-2020, 04:02 PM   #3
Pussiwillow
Originally Posted by F32Fleet View Post
Plugs: 60k miles
Coils: 100k miles
Thank you for taking the time to reply
This helps out a lot thanks
F32Fleet2336.00
      10-27-2020, 03:50 AM   #4
davidr3
Drives: 335i
Last time you did brake fluid? it's a time interval as opposed to mileage.
      10-27-2020, 05:00 AM   #5
Logicoeur
Logicoeur's Avatar
546
Drives: F30 335i xDrive
Plugs yes. Oem, or Bosch equivalent to save some coin.
Don't change ignition coils unless you need to our see cracks in the plastic.
Check for oil leaks: OFHG #1, VCG #2, oil pan #3.
Transmission fluid is nice too. Bmw says life time by ZF says 60-70K. Listen to ZF.
F30 335iX | Remus Axleback | 18X9 ET32 19lb TR-1 255/40/18 | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete
      10-27-2020, 11:00 AM   #6
Pussiwillow
Fairly certain the last service done from PO was 4k miles ago and it was oil and brake fluids included
But he doesn't know for sure if the brake fluid was involved
"He thinks"
So I will add that to the list so I know for myself
      10-27-2020, 11:12 AM   #7
Pussiwillow
Thank you sir
I'll probably change the ofhg when I do belt and tensioner at the time of oil change
Valve cover looks fresh for now
      10-28-2020, 06:50 AM   #8
torquer
Drives: e90 320d
Plugs: 60k miles
Coils: 100k miles
This is a nice listing. Many thanks
      10-29-2020, 01:54 PM   #9
thejeremyman9
thejeremyman9's Avatar
1465
Drives: 2015 BMW 335i
Plugs: 60k miles
Coils: 100k miles
Yeah ZF 8AT recommendation was recently revised to 150k km, or shorter if necessitated by driving conditions. I attached the PDF to my post here: https://f30.bimmerpost.com/forums/sh...32&postcount=7
Only other thing i would say is expect shorter intervals than 60k for spark plugs once FBO+tuned / turbo upgrade. Closer to 15k is typical, although thats more preventative and you can probably stretch them a bit longer if you really wanted to. People usually also shorten oil changes to 5k once modded/tuned significantly.
I do brake fluid flush every 2 year per dealer recommendation but some people disagree its necessary and stretch it longer.
Coolant is supposed to be "lifetime", but plan on a flush/change at he time of thermostat/water pump.
