03-09-2019, 12:31 PM | #23 |
Rep 35
Thanks - I guess I will need to lower the beams manually.
For future reference for other members, here is how it is done: https://f30.bimmerpost.com/forums/sh....php?t=1262875 (check the last image in the thread). But how about the ride height? Back is optically lower the front. Will the springs settle / give-in over some time? Do i need to drive the car a bit more for the front springs to meet the rear height? The balance of the car is visually not OK, however the car rides very well and doesn't feel out of balance (front-to-back). Any other thoughts? |
03-10-2019, 07:53 AM | #24 | |
Rep 253
All you should really consider with springs is the lowering amount, stiffness (Dinan is 30% stiffer than stock for example ), and maybe if it's a progressive or linear spring. Ultimately I went with Dinan because the Eibach's weren't common at the time and Dinan reportedly offered a bit smoother ride than H&R and almost as good of a drop on RWD, XDrive has reverse rake. At the end of the day wish I went coilovers though because I want to dial in my gap more. |
03-10-2019, 01:23 PM | #25 |
Rep 35
I've checked again.
Rear wheels have "112003101ha" installed, which are rear springs (as per eibach). Front wheels have "112003102va" installed, which are front springs (as per eibach). Both (all 4) springs are for 340i non x-drive - fits my car. I am still puzzled as to why the car sits so low in the rear. Check out the picture: and here is the max resolution image: View post on imgur.com Please advise on what can be done. Car has very little mileage so I don't believe there's something wrong with suspension. Also, the car sat really nicely on stock springs (was even). I also tried putting my fingers between tire and bumper and in the front I can fit 2 fingers easily, while in the back I can't. There's only room for 1 and a half finger (very inaccurate measurement I know, but it shows the difference). Thanks |
03-10-2019, 06:43 PM | #26 | |
Rep 3,535
If you want to increase your rear ride height, check out some of the other rear springs listed in their catalog and spec sheet to see which has the same spring rate, but is a bit taller. |
03-10-2019, 07:16 PM | #27 |
Rep 35
Hi,
but how am I suppose to know which length of spring was installed in my car now? LIke i said:" Rear wheels have "112003101ha" installed, which are rear springs (as per eibach)." The place where I bought the springs did not provide an info on the back spring's length. On a side note - is there like a simple fix to add 1 cm to the height without buying new spring? Like adding "static 1 cm" on top of the spring? Maybe I am talking nonsense... |
03-10-2019, 08:52 PM | #28 |
Rep 81
There is. You can add a 'spring booster,' but it is difficult to find one that fits correctly. Remember, you only need to a small booster to the spring to produce a larger lift because of the angle of the suspension pieces involved. You are placing the spacer closer to the fulcrum of the lever.
03-11-2019, 04:11 AM | #29 |
Rep 35
Thank you.
So if I needed 0,5 cm to be added in the back how big a "booster" should I choose? Also, is this a simple install? Would that require to perform "optical alignment" at the end of procedure? |
03-16-2019, 05:47 AM | #30 | |
Rep 61
Firstly i don't think your car looks bad as it is, i have an x-drive so i am used to the front looking higher than the back!! However if you were to put 100Kg on each front seat i.e. a driver and passenger, i bet it looks perfect. Looking at the Eibach specs for the 340i rwd it states a lowering of Front 35mm and Rear 40mm which is probably what you have, the x-drive springs that i am looking to get are Front 35 & Rear 25 which may give you the stance you are after. If you are really set on changing it maybe buy the rears for an x-drive and sell yours? I think how it drives and feels is more important than how it looks anyway, if Eibach thinks it drives better with lower rear springs on a RWD I'd probably stick with it! |
tejula34011.50 |
03-17-2019, 02:56 PM | #31 |
Rep 35
I am a 110kg guy so I balance the front quite fairly :-)
Well in fact in the last days I think the front settled down a bit more and now it looks more balanced (front to back). I also like the appearance much more. Not to mention the AMAZING TRANSFORMATION of the car, due to these springs. Yesterday I took it for a blast on some country road (where I often drive) and the difference is absolutely amazing. I love how it corners now, so stable and confident! Before, with stock springs, It was really shaky and unstable on the curves, albeit cornering well. Now I feel like driving another car. Also, traveling on highway is much more stable and only a little less comfortable. It still bounces at high speed, but much much less. I would rate this upgrade 10/10. Very little sacrifice to comfort, yet a huge upgrade in driving dynamics!! To anyone in doubt - do the upgrade and thank me later. The only thing I'm worried now is the following - let's say I drive 2 guys in the back (both having 100kg each) - would that slam the car totally? I don't want the car to look like a cheaply modded honda civic when traveling in 4.... Next upgrade - MPPSK ! |
03-18-2019, 07:48 PM | #32 |
Rep 1,062
I’m the OP
After 3 months with the Eibach Pro Kit and stock dampers, I decided to ditch the Eibachs and go with Dinan spings + bumpstops, and replace the OEM dampers with Koni Sport yellow. (I tried to order the Bilstein B8, but they are still unavailable. I would have kept the Eibach if I could have gotten the B8.) Why? Well, I have no scientific data, but it feels like the OEM dampers have degraded a bit in the last 3 months. The car has 33K miles on it, and about 5K since the Eibachs were installed. The car just feels underdamped to me. I originally went with Eibachs + stock shocks as it seemed like the most cost effective option, but now, well, I guess I learned another le$$on the hard way as usual. I will post a new thread when I get the Dinan + Koni installed and post before/after. |
scostu1621.00 |
03-18-2019, 09:30 PM | #33 | |
Rep 216
03-18-2019, 10:25 PM | #34 | |
Rep 5,391
I was trying to improve handling without going harsh and rattling teeth especially on a long drive. At the same time I installed Koni Special Active shocks. They use an automatically adjustable two valve system that softens potholes and road seams but reacts like a sport shock when I drive aggressively. They developed this technology with McLaren. I am really happy with the combination. A Koni technical guy actually recommended the combination of their Special Active shocks and the Eibach springs which they said they had tested in the US. I also install the H&R front and rear sway bars. This is something that seems to be avoided on F30's because the labor cost is high, but so very worth it. I love the way this car handles now. Incredibly flat around curves, yet smooth and not teeth rattling on a regular commute or long drive. A couple different BMW employees who drive a lot of them were amazed after driving my car. The Eibach springs, Koni Special Active shocks and H&R sway combination really works together. Hope this helps! |
03-19-2019, 08:18 AM | #35 |
Rep 1,062
You were smart to also install new dampers with the Eibach Pro Kit springs.
Despite what Eibach says (how Pro Kit is designed to work with OEM dampers), the truth is that Eibach Pro Kit is designed to work with dampers like the Bilstein B8, and if you run OEM dampers in conjunction, you are basically underdamped. The car is drive-able, and it's an improvement, in some areas over OEM springs, but it's worse in other ways. |
03-19-2019, 02:26 PM | #36 | |
Rep 122
03-19-2019, 05:35 PM | #37 | |
Rep 1,062
Bilstein B8 are good - but apparently in perpetual backorder. They don’t require bump stops. Koni Sport yellow are good - require bump stops, though some have gone with the OEM bump stops (which doesn’t seem like a good idea to me). Honestly I haven’t found a third option. Coilovers? A bit more money. I hope I don’t regret not getting coilovers. I’m having Dinan springs, bump stops + Koni yellows installed this week. |
03-19-2019, 05:50 PM | #38 |
Rep 81
I have M4 springs which are about 20% stiffer than my stock F32 springs, and the Koni Special Active shocks I paired them with are working very well. I would suggest those on Eibach's since B8's are on backorder and Koni Yellows are about 40% more expensive. Yellows are probably necessary on Dinan or H&R springs though.
03-20-2019, 09:42 AM | #39 | |
Rep 122
03-20-2019, 03:57 PM | #40 | |
Rep 552
03-20-2019, 04:03 PM | #41 | |
Rep 1,062
Dinan even told me their recommended Koni settings their springs, Front: 1.5 turns from full soft, Rear: 0.25 turns from full hard. (I don't know if this is specific for my car or general to all cars, '17 340xi) |
03-20-2019, 05:30 PM | #42 | |
Rep 552
03-20-2019, 07:00 PM | #43 |
Rep 1,062
https://www.dinancars.com/products/?...bodytype=Sedan
This is all Dinan products for a ‘17 340i xDrive The Koni Sport yellow on the Dinan page are almost 2x the price. They have been pre-adjusted by Dinan, though. You (or your installer) can also make this adjustment. |
mlev370.00 |
04-14-2019, 04:46 AM | #44 |
Rep 35
Reporting in after 1 month of use of eibach prokit on stock shocks. Feels really good and I would never go back to original springs.
I am currently satisfied with this setting, but if shocks wear out anytime soon i will replace them with better ones, to test out even stiffer ride. But at the moment I have no complaints. To all considering installing eibach prokit springs on stock shocks - do it. It might not be optimal, but it is a hell of an improvement. It doesn't cost much, either. |
Stevro7.00 |
