11-26-2020, 10:03 PM | #23 |
Rep 473
11-27-2020, 04:23 PM | #24 |
Car Hypochondriac
335
Rep 901
The shop put it up on the lift and spun the car up to 60, 80, 100 and checked various spots for vibration. The diff was the culprit.
Still hasn't been replaced yet because I've been busy driving for work. But the dealer the shop purchased it from refunded the purchase price - so it's all covered.
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
11-28-2020, 02:11 AM | #25 | |
Rep 473
11-28-2020, 09:50 AM | #26 |
Car Hypochondriac
335
Rep 901
Personally I was thinking when I get the diff replaced, I'm going to have my mounts replaced as well. The excess vibration from the bad diff will probably have worn the bushings faster than usual, I assume.
11-28-2020, 09:39 PM | #27 | |
Rep 320
jbiswurm68.00 |
11-29-2020, 06:08 AM | #28 | ||
Rep 241
Also the solid diff mounts seem to even transmit noise from the exhaust and transmission (rev dependent, not speed dependent) which, while loud, i enjoy quite a bit |
11-29-2020, 10:03 AM | #29 | |
Rep 320
I contemplated going with the aluminium bushings but the class i compete in does not allow them. |
11-29-2020, 12:08 PM | #30 | ||
Rep 241
11-30-2020, 11:53 AM | #31 | |
Rep 320
11-30-2020, 03:21 PM | #32 | ||
Rep 241
I am 6mt so i always leave the car in comfort but i need a consistent throttle to rev match effectively. |
12-01-2020, 11:35 AM | #33 | |
Rep 320
12-02-2020, 04:24 AM | #34 | ||
Rep 241
12-03-2020, 02:18 PM | #35 |
Rep 8,488
My car is going to my suspension shop in a couple of weeks time for new SuperPro front arms/bushes and rear subframe bushes. Bearing in mind that the rear subframe has to be lowered so that the bushes can be accessed, how much extra work/time is involved with replacing the diff bushes ?
The front bushes are easy access but I'd appreciate someone letting me know the process for replacing the rear bush, i.e. does the diff housing need to be completely removed from the subframe and the vehicle (disconnect driveshafts) etc. Thanks.
02-09-2021, 04:30 PM | #36 | |
Rep 3,940
https://www.millway.se/pub/media/wys...19-web-eng.pdf |
Watsey6399.00 |
02-09-2021, 04:50 PM | #37 | ||
Rep 8,488
02-15-2021, 11:24 AM | #38 |
Car Hypochondriac
335
Rep 901
I forgot to update this thread. Nexus313 my diff/diff mounts were fine. My vibration ended up being an axle.
05-06-2021, 06:29 AM | #39 |
Rep 3,940
Who sells the softest polyurethane rear differential bushing? I'm having a shop replace my rear subframe bushings with solid subframe bushings and I'm planning on replacing the rear differential bushings at the same time.
Either with BMW rear differential bushings or the softest aftermarket polyurethane bushing out there. |
05-06-2021, 11:46 AM | #40 | |
Rep 320
