BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Learned my lesson about tracking without camber
      10-12-2020, 09:58 AM   #1
FIDDYgg
Drives: 2018 340i X-Drive
A last minute track event came up and I've been really wanting to see what the 340i can do in a controlled setting, first time tracking the 340i, basically stock. The car drives really great in stock form honestly and the Bridgestone Potenza S001 run flats were actually surprisingly decent but they really didn't stand a chance with no negative camber. I've been looking for an excuse to get on some Michelin's anyway
View post on imgur.com
No incidents, just some destroyed rubber shoulders.
2018 340i X-Drive | M-Sport | MPPSK | Dinan Intake
Last edited by FIDDYgg; 10-12-2020 at 10:03 AM.. Reason: images aren't embedding...
      10-13-2020, 04:22 AM   #2
drdino
drdino's Avatar
135
Drives: BMW 330i
2019 BMW 330i  [0.00]
Stock pressures?
      10-13-2020, 12:22 PM   #3
340iGUY
Drives: 340i manual
Since this happened after one event, I say you were too aggressive on the corners.
      10-13-2020, 02:28 PM   #4
FIDDYgg
Originally Posted by drdino View Post
Stock pressures?
I did a little research for starting cold pressures 30F/36R and made adjustments each session but it was to no avail... I'm very familiar with this track as I've raced superbike there for years, so I was hustling at a pretty good clip. I think without negative camber or just driving slower (boring?) it's probably unavoidable.
Too aggressive? What's the point, if not going all out?
This is a very tight technical track, with very abrasive track surface (loads of grip), so again without optimized alignment for track use I think it's inevitable when the pace is up there.
      10-14-2020, 10:25 AM   #5
jsouth
jsouth's Avatar
Drives: 2013 328i
I had a similar experience with track days in a Datsun 510 several years ago. My pressures were too low, AND I was drifting too much. Fun as could be, but I got some lessons and changed the amount of rubber loss in corners while going faster. I have no idea if that was an issue for you - with bike experience on that track probably not.
But I sure miss track days!
      10-16-2020, 03:03 AM   #6
jmg
jmg's Avatar
18704
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Too aggressive for the setup. With proper camber he can be this aggressive or more.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      10-17-2020, 11:20 PM   #7
RMachuca3d
RMachuca3d's Avatar
724
Drives: F30 328i Msport
More air pressure, tire rolling over on sidewall is a clear sign that its too low. Camber will help, but the clear issue here is the lack of air.
sspade2464.50
      10-18-2020, 09:46 AM   #8
FIDDYgg
I had the same thought, I added about 8 psi after I noticed the sidewall rolling over and was coming off the track hot around 46psi, it was a cold day as well.
All of my tire pressure experience has been with motorcycle slicks running 25-36lbs hot so I was a bit lost on pressures for the F30.
What are you guys running for cold pressures? Target hot pressure?
      10-18-2020, 09:21 PM   #9
RMachuca3d
RMachuca3d's Avatar
724
I ran mine (throw away cheap track tires to beat on, achiles ATR sport 2's) typically around 40psi hot, so in the ballpark, BUT different tires with different sidewall strengths can differ in what an optimal pressure would be, plus the grip the tires offer can also affect how much sidewall rolling there may be, as grippier tires have higher peak lateral grip which will increase sidewall deflection under load.
      10-20-2020, 06:04 AM   #10
drdino
drdino's Avatar
135
Drives: BMW 330i
This, hence my question about pressures. Had the same issue the first time I tracked one of my previous cars (loads of shoulder/profile wear) which was fixed by using higher pressures. Just look at how much of the sidewall writing has been lost, camber will help a bit but it can't do miracles...
Jvac432.00
      10-20-2020, 11:25 AM   #11
MacklinUSOB
Drives: f30 328i 6MT Sport
This wear is exactly what you should expect pushing harder than the street tires and camber can keep up with. Running higher pressures is a huge trade off as just 1 or 2 psi can really shift the handling balance as the tires warm.
Camber on these cars DOES do miracles.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines |
Past: E36 328is & E38 740i
      10-26-2020, 04:42 AM   #12
nickf30
Drives: 2014 335i xDrive
Your tire is clearly rolled over:
1) Keep PSI high until it is up to temperature. Coded the tire temp/psi display and watch that closely.
2) Our car is heavy for its tires especially the front tires. Drive as smooth as possible and try to shift weight to the rear of the car.
3) Get more seat time: more track days / autocross / karting. In my personal 0.02, track is not the safest place to test the limit at the beginning. Spend some time in autocross helps a lot in understanding the limit of the car and how to process the feedback. It is much safer to push the limit in autocross environment when you spin at 40-50 mph instead of 120 mph.
4) Get extreme summer tire 200tw: these tires have much higher heat tolerance (wider operating window) will allow you to push the car longer / more consistently.
Appreciate 6
jmg18703.50
340iGUY15.00
      11-08-2020, 04:51 PM   #13
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
I run about 36 PSI hot on RE-71R. Depending on the day I shoot for 28-30 psi cold.
      11-10-2020, 05:28 PM   #14
AmuroRay
AmuroRay's Avatar
2271
Drives: M235i
I did a track day on my DSW 06's and they held up ok - Trash at anything resembling grip though.
Mods: Yes.
      11-10-2020, 11:24 PM   #15
Polo08816
Drives: 2014 335i M Sport
I'm at -2.25 degrees on the front with:
- M Performance Suspension Kit
- OEM Wheel hubs with an additional -.50 of camber
- M3 LCA and TS
Even that is not enough negative camber for heavy track use, it's more than sufficient for street use.
I think for tight tracks you may want to be in the neighborhood of -2.50 to -3.25 degrees of camber.
      11-12-2020, 11:46 AM   #16
brigade24
brigade24's Avatar
Drives: 2013 335 X-dive
so many factors...someone mentioned that these cars come with too little tire. I 100% agree. I ran 265 wide all round with -2.9 degrees of camber and at the limit would still notice the outside half of the tires wear out more quickly than the inside half...i usually run about 34psi hot on my re71r.
camber plates and bushings are the two things i have done that have had the most significant impact on tire preservation. the bridgestones you were using are decent tires, they just a bit narrow for the load under transfer.
      06-15-2021, 08:42 AM   #17
Logicoeur
Logicoeur's Avatar
991
Drives: F30 335i xDrive
Are you xdrive?
      06-21-2021, 04:22 PM   #18
brigade24
brigade24's Avatar
Originally Posted by Logicoeur View Post
Are you xdrive?
I am xdrive.
at 275 wide now, it's no longer an issue.
      06-22-2021, 06:43 AM   #19
Logicoeur
Logicoeur's Avatar
991
Blank
Are you xdrive?
I am xdrive.
Oh damn really wide. I'm on 255 square. Is -2.9 really noticeable or daily driveable?
      06-22-2021, 11:49 PM   #20
brigade24
brigade24's Avatar
yea i need all the tire i can get in there. I took tire temps this weekend at an autox event and I can still dial back a bit on the front camber. 245-255 is perfect for the street i find...supports the weight of the vehicle much more adequately, protects the rims from cracking when you hit a pothole or something and fills in the fender gap a bit.
I ran -2.9 for awhile on the street and it is driveable but it was hard on the inside of the tires. it wasn't very good in the rain either. i was doing a ton of freeway driving to and from events so the aggressive camber setting didn't help. I change my front camber and toe before and after every event. I usually dial it back to about -1.9 for street driving and that for me seems to be the sweet spot for wear.
      06-23-2021, 06:38 AM   #21
Polo08816
I would agree on the -1.9 for street driving. I'm around -2.0 without camber plates for street driving and it seems the wear is pretty even.
How are you able to get 275 width tires all around?
      06-23-2021, 08:48 AM   #22
johnung
You may find this camber plate comparison interesting. FaRKle! does excellent videos
AmuroRay2270.50
