11-28-2020, 12:21 PM | #1 |
Rep 5,101
WIFI booster
Any recommendations?
It was all fine until a couple of weeks back until our street went off along with a few others, turns out it was an issue in the village, openreach came out and it took them a couple of days to sort it. Anyway it was still intermittent for a short while and whilst it’s on now it struggling in the far wing of the chateau which in an issue considering that’s where our en-suite is and LFC’s bedroom so it’s causing obvious frustrations Any recommendations for a booster? Do you just plug it in to the back of the router and play? Or is it a non starter? |
11-28-2020, 12:32 PM | #3 |
Rep 1,189
Who provides your internet? most providers have modern mesh devices that extend the existing network. Better a device doing that. Eg If Sky and using sky tV depending on the contract you may be entitled to extenders for free until signal throughout the property
11-28-2020, 12:36 PM | #4 | |
Rep 5,101
11-28-2020, 12:41 PM | #5 |
Rep 3,664
I don't understand why you think your wi-if has gone crap after the issue in the village? Your broadband being off would not affect your wi-fi.
Are you saying your broadband is dropping at the router or your wi-if signal is dropping at the end device? The two are different things.
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
agentorange1504.50 Wills28647.00 |
11-28-2020, 12:43 PM | #6 |
Rep 2,157
Drives: X3M Competition
I would go with Eero if you can get stock quickly.
Previously used Orbi, but with one repeater it wouldn't cover the whole house. Had Eero for a while and had no issues at all. Introducing Amazon eero mesh Wi-Fi system | 3-pack https://www.amazon.co.uk/dp/B07WHMJ6..._HNPWFbPB56FJW
CURRENT
X3M Competition- Toronto Red [url=https://www.deutschespeed.com/threads/the-bimmerpost-refugee-thread.561/]Car[/url] |
11-28-2020, 01:03 PM | #7 |
Rep 967
I went with a nighthawk X6 to go with my nighthawk xr500 router and it was rubbish, kept dropping connection then not allowing device's to reconnect.
Ended up with a tp link re450, plugs in on the third floor stairs and all good now. Full WiFi in dead spots around the house and garden. |
11-28-2020, 01:57 PM | #8 | |
Rep 1,189
looking at their remaining black Friday weekend offers this looked best value https://www.amazon.co.uk/Linksys-WHW.../dp/B07CZ3YB51 |
11-28-2020, 02:09 PM | #9 | |
Rep 5,101
11-28-2020, 02:29 PM | #10 |
Rep 4,574
We have a firewall (from bricks) so WiFi doesn't work in half of house.
I find TP link power extenders work great. Highly recommend.... https://www.amazon.co.uk/TL-WPA4220K.../dp/B01LXOZ4EN |
11-28-2020, 02:30 PM | #11 |
Rep 4,932
If its signal in the house then a mesh network is king. We have an Orbi mesh with two devices and it floods the house and garage. loads of stuff you can do on it as well if needs be, guest WiFi, disable devices etc. Bit pricey but so much better than boosters all round the place and devices just switch between the two units without hanging on to a naff signal as with routers and boosters.
11-28-2020, 03:44 PM | #13 |
Rep 1,375
That means the issue is before the Internet gets to your house. No amount of messing with the home wifi can fix that.
11-28-2020, 03:49 PM | #14 | ||
Rep 3,664
You can have the best wi-fi going but if your wired connection from the router to the provider is crap then you will still have issues. If your wi-fi - and I mean your in house wireless network - was working fine before and nothing has physically changed on it then buying more "stuff" won't help. Log into your router and look at your line connection stats. That will also show you any drops in the log files. If that is rubbish then take it up with your provider. Just trying to save you some money
Current: M4 G82
11-28-2020, 03:50 PM | #15 | |
Rep 3,664
Current: M4 G82
11-28-2020, 04:21 PM | #16 | |
Rep 5,101
It’s been about 85% of what it was so not that good, I struggled the other night with the football but today was good Like I said openreach had a couple of vans in the village fettling with it, we have a WhatsApp group for our immediate area and all had it go on and off for a couple of days. I can just jump on 4G but LFC is on his PS5 and thinks a booster will help. |
11-28-2020, 04:35 PM | #17 | ||
Rep 3,664
Current: M4 G82
11-28-2020, 04:41 PM | #18 | |||
Rep 5,101
Rukka2647.00 |
11-28-2020, 04:46 PM | #19 |
Rep 1,189
11-28-2020, 05:07 PM | #20 | |
Rep 5,101
11-29-2020, 02:08 AM | #21 |
Rep 7,484
Had BT discs on our wifi 900Mb. Promising a boost of up to 20% in speed. Actually didn't help. So if one disc doesn't work you get another two free. Dot those around and the speed dropped across the whole house. Wifi complete will give you stable wifi on the third floor if you have thick walls but it's not worth it otherwise for speed. I'd look to upgrading router and as mentioned the TP link is very good. Router location is key first off if you are tied into a contract. Not on the floor or under the stairs behind old coats and a vacuum. Then the router itself and it's settings. Auto channel selection or not? Find a less crowded band if you can. 5GHz will give you a bit of speed but in a bigger house less stability on the top floor when router is on the ground floor. Lastly, check device compatibility. Older devices will lack the ability to benefit from higher bands e.g. a wifi adapter on the a/b/g protocols will not be as fast as one on an n rating or higher. Disc positioning or booster is also important. The booster works best closer to the router. Too far and it can drop signal too. In summary, a booster is not like a remap turning a 100mb connection into something more but can give you more stable connection in dead spots.
11-29-2020, 02:45 AM | #22 | |
Rep 5,101
