07-08-2016, 05:06 PM | #23 | |
391
Rep 449
07-08-2016, 05:33 PM | #24 | ||
Rep 943
Drives: 2012 328i Modern Line
:wave:
07-08-2016, 05:41 PM | #25 | |||
391
Rep 449
07-08-2016, 09:01 PM | #27 | |
391
Rep 449
07-09-2016, 08:40 AM | #28 |
Rep 9
So I can confirm that all the tools he recommends are the ones you will need. Especially the 1inch extension for the last one. I can also confirm that it will drive to Autozone with 3 new plugs and 1 old one just fine when you go to buy that extension you thought you could do without. lol
That being said, did/does anyone else have two vacuum lines running to the underside of your engine cover to a small box there? Mine is a 2012 so maybe its an early model design? I had to also disconnect those hoses in order to get the plastic cover off just to get started as an FYI. |
07-20-2016, 08:25 PM | #29 | |
Rep 98
Thanks for the video. I am tackling this in the next few weeks. I already got my plugs, but your video saved me from a trip to O'Reilly Auto Parts for the 1" extension.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic 2014 Porsche 991- Sapphire Blue Metallic |
07-21-2016, 02:25 PM | #30 |
Rep 42
Where are people here sourcing their spark plugs? My dealer just quoted me $130 for a set of 4
On the net I see the following: World OEM Parts at $18.66 Pelican Parts at $16 Hua Orton via AliExpress at $69 shipped for 10 (!!) plugs The AliExpress seller states these are genuine NGK plugs made in Japan. I'm wondering if I should just order a lot. There'd be enough plugs for my 328i AND my wife's X3 (in about 30k miles) and I'd still have 2 left over! I've never ordered these parts online. I'm not sure those first 2 websites are any more trustworthy than the AliExpress seller. |
08-04-2016, 09:11 PM | #31 |
Rep 20
I know a thin wall socket is needed for this service. Does anyone have a recommended socket?
Burger socket with magnet http://www.burgertuning.com/N54_BMW_...t_adapter.html Amazon socket without magnet https://www.amazon.com/CTA-Tools-237...rk+plug+socket |
08-04-2016, 11:52 PM | #32 | |
391
Rep 449
08-14-2016, 07:49 PM | #33 | |
Rep 98
2016 BMW F15 xDrive 35i - Imperial Blue Metallic 2014 Porsche 991- Sapphire Blue Metallic Last edited by Class5Kayaker; 08-14-2016 at 08:46 PM.. |
08-14-2016, 08:41 PM | #34 |
Rep 98
Finally got around to replacing my plugs.
First off, big thanks to bkkeys for posting the video. VERY helpful and made my install a breeze. I did a couple things differently which I'll mention here in a minute. First thing that was different for me was removing the engine cover. I bought my car used, CPO, and I never thought it was an N26. The vin decoder says it's an N20, but my the underside of my cover has a molded box of sorts with two vacuum hoses running to it. My build date was June 2012, so I'm not sure if it's just an early model function or if I have an N26 (California Emissions). The Bentley manual didn't mention this part either, but there are two hoses on the front left (below the oil cap) that I had to disconnect before removing the cover. So check yours first to see if you have them before you try and pull it off. Just squeeze the notched tabs and pull them off. After pulling my first plug and replacing it and torquing down to proper specs I ran into an issue. My extension kept separating from my spark plug socket and the socket was stuck to the plug in the spark plug well because of the inner rubber of the socket holding to the plug so tightly. So I used the universal repair tool (duct tape) and didn't have any separation issues during the rest of the job. The other big difference I did compared to the video was remove the bulkhead cowl cover. It takes just a couple minutes and gives you complete access to the pug closest to the firewall. Here are the steps: 1) Remove the left (over the fuse box) and right (over the brake fluid reservoir) covers. It takes a 10mm socket and a 90 degree turn on each of the three plastic "bolts". I didn't take a pic of the locations since this is something I'm sure everyone has already done. If not, it's self-explanatory and no picture is required.That's about it. My last pic is of the new plug next to the old plug. Part number is NGK: SILZBR8D8S
manghong84.00 |
08-14-2016, 09:10 PM | #35 |
Rep 943
That's similar to how techs change plugs by removing cowl pieces and seals.
:wave:
08-15-2016, 01:32 AM | #36 | |
Luke Wright
166
Rep 252
08-21-2016, 12:39 PM | #37 |
Rep 20
08-25-2016, 09:13 PM | #38 | |
Rep 98
NGK (that's who makes our plugs) Technical Bulletin #NGKSP-0907-1 says that all their plugs are manufactured with a special metal shell (trivalent) plating to prevent damage to the cylinder head. For plugs with this special metal plating, anti-seize is not recommended during installation. Applying anti-seize to these plugs will cause the installer to mistakenly over-torque the plug in the cylinder head stretching the metal between the last thread and the seal between the cylinder head and plug. This increases the probability that the spark plug will either break during installation or upon removal. Even the other major manufacturers (Autolite, AC Delco, Champion, etc.) all say to not use anti-seize. These days, their plugs are all manufactured to not seize through various special metal processing techniques I'm not smart enough to fully understand and adding anti-seize could actually make things worse.
etinifni203.00 |
08-29-2016, 08:44 PM | #39 |
not good, but bad
333
Rep 361
I had a hell of a time getting the spark plug socket out when I changed out my 335's plugs. What I did was buy a locking socket extension. After I was done torque'ing the plug in I used the locking extension in combination with a dental pick (to lift the locking mechanism while in the coil channel)
Worked great, I can take a picture if that helps. |
09-03-2016, 09:59 PM | #40 | |
Rep 98
badbread332.50 |
09-18-2016, 06:42 PM | #41 | |
Rep 20
Thanks for all your help! I changed my plugs in no time last weekend. I opted to not follow your duct tape hack and purchased locking extensions they worked perfect.
Class5Kayaker52.00 |
09-21-2016, 05:19 AM | #42 |
Rep 265
Will any of these spark plug sockets work?
Are they thin walled enough? http://www.ebay.co.uk/itm/14mm-Spark...8AAOSwaB5Xm62H http://www.ebay.co.uk/itm/TRIDENT-MA...EAAOSwqfNXoh4q http://www.ebay.co.uk/itm/BGS-2446-L...MAAOxyA9dSZ8mK EDIT: Or this one: http://images.biltema.com/PAXToImage...0-045_xl_1.jpg I can buy that in a store where I live. |
09-22-2016, 08:48 PM | #43 | |
Rep 98
10-25-2016, 06:44 PM | #44 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
