07-10-2018, 08:20 AM | #1 |
TH320i
23
Rep 41
Vanos failing...
So i got the typical Vanos symptoms, no power below 3000 rpm for quite sometime... haven't noticed any noises yet but i will check again in the morning during cold start.
but my question is.. is it dangerous to be driving a car with a failing vanos system? Cheers in advance !!!
2012 BMW 320i - Catless DP - Full 3" exhaust system - Cold Air Intake - S55plugs - GFB DV+ - ProjectA Stage 2 Remap (270 hp on E20).
07-10-2018, 09:16 AM | #2 | |
Rep 14
Check your timing chain and guides
07-10-2018, 08:21 PM | #3 | |
TH320i
23
Rep 41
Thing is i have already replaced out my timing chain guides .. ones was cracked ... now i still have a faulty Vanos system sometimes it gets stuck ... sometimes it works fine ...
07-10-2018, 10:18 PM | #4 | ||
Rep 5,456
Drives: F30
07-11-2018, 06:45 AM | #5 | ||
Rep 5,456
Drives: F30
07-11-2018, 12:44 PM | #6 |
Rep 14
New engine needed for me
Mine failed at 89,500. While tearing things apart to replace chains and guides, local indy shop called today that they found a broken bolt head from chain guide that had worn into block, and now engine is total loss, $9500 to replace.
07-11-2018, 12:54 PM | #7 | |
Rep 5,456
Drives: F30
Id want to see proof of that. Not saying they are BS'ing you. Just the first Ive heard of that and Id genuinely want to see it. What are your plans? You can get a brand new engine from Germany for $6k or even a race engine from Steve Dinan for $8k or so. |
07-12-2018, 12:24 PM | #8 | |
Rep 14
sspade2464.50 |
07-15-2018, 06:42 AM | #9 |
TH320i
23
Rep 41
I cant seem to find the solenoid part# on Realoem or anywhere else for that matter... can anyone help out?
07-16-2018, 09:16 AM | #10 | |
Rep 2,382
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
failing, n20, vanos |
