BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > A/C Stops Blowing at Idle
proTUNING Freaks
      07-21-2018, 05:38 PM   #1
sickF30
Drives: F30 335i
I tried searching but didn't find my exact issue.
I've noticed lately, as we've reached 100*+ here in TX, that my A/C stops blowing air whenever I'm off the throttle (like exiting a highway and breaking) or when I'm stopped at a light/stop sign.
It's not that the air is still blowing but the air is warm, the airflow stops entirely. If I have it set to Max A/C, the airflow slows to the speed as if I had it set to the first notch.
As soon as I start moving again, the airflow ramps up and shortly after, the air gets cold again.
I'm assuming that at the very least, I'm low on refrigerant. But what's concerning is how the air stops blowing. I thought that maybe there's a sensor that detects that something in the system is getting too hot or is working too hard and that's what's killing the airflow.
Like I said, I've only noticed this over the past few weeks. I didn't have these problems last summer.
Thoughts?
      07-21-2018, 09:16 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
How old is the car? A weak battery may cause the car to divert power from the AC when the engine is at an idle.
      07-22-2018, 12:22 AM   #3
sickF30
Drives: F30 335i
It doesn't do it at night though when the temps drop to 95*. lol
      07-22-2018, 09:39 AM   #4
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Vacuum leak? Does it happen when you manually set the a/c to blow through dash vents only and the temp wheel is centered?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      07-22-2018, 04:19 PM   #5
sickF30
Drives: F30 335i
Yeah, happens anytime you're trying to not die in this heat.
I'm going to get the ac recharged tomorrow and see if that's the issue.
      07-25-2018, 08:40 PM   #6
chhappy7
chhappy7's Avatar
Drives: TBD
I know this sounds stupid, but do you have auto start/stop on? For me, when my engine is off, compressor is off so no cold air.
