09-04-2020, 06:52 PM | #1 |
Rep 548
Update - 12/29/2020
Seems solved. Haven seen the issue after reverting to stock, resetting adaptations then retuning and again resetting adaptations. Updated - bm3 log 11.30.2020 https://www.bootmod3.net/log?id=5fbf...0b434a0a882a4a _________________________________________________ 2015 335i A8, rwd, mp lsd, 45,500 miles. The car has been fantastic, but I haven't been driving it as much due to working from home since March. My cold starts seem like it struggles or strange when it kicks over. the rpms bounce low then catch them self after half a second or it take a bit longer to kick over then rpm bounce weird. Just doesn't sound right. I'll turn it off and try it again and less issues or no issues. It's like it hates cold starts sometimes. Wondering if anyone has seen a rough cold start in mornings but then the rest of the day no issue, starts like a champ. No misfires or issues. Coils and plugs replaced in July of this year. Original battery as I purchased the car in 2017 Always running 93 Cleaned the MAF and no change. Still weird starts when the car sits for a days. No codes in Cody or BM3
2020 - M340i RWD | Executive
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) Last edited by TheJungatron; 11-30-2020 at 10:10 AM.. |
09-04-2020, 07:37 PM | #2 |
Rep 7,613
If you just mean the car needs a little more time from the time you press the button to the time the engine is actually running and/or the cold start seems a little more difficult after the car has been sitting for an extended period of time (say, 1 week or more), i would say that's normal, especially if the next cold start say a day later is normal again.
I'm in the same boat about infrequent driving and i thought i observed that last time. I havent started my car in about a week in a half and will be either tonight or tomorrow morning and will pay careful attention and report back. |
09-05-2020, 08:25 AM | #3 | |
Rep 548
(Retired 2015 - 335i RWD A8 | MP LSD, BM3, MP Exhaust, M Sport Conversion, 245/35/18 square, VRSF Chargepipe, Rear Brembo upgrade) (Retired - 2010 328i) (Retired - 1987 325i Vert) |
09-05-2020, 12:04 PM | #4 |
Rep 7,613
My cold start is definitely a little different after the car has been sitting for over a week. Its just not as 'smooth' when it first starts idling. Sometimes it takes a second longer to fire, sometimes it doesnt. Goes away quickly and doesn't do it again until the car sits a while. It still cranks over completely fine FYI; if you have weird cranking that could be something else.
09-05-2020, 12:09 PM | #5 | |
Rep 548
Today I recorded the start up and it was smooth. No issues, however I did drive more this week. It only sat for about 24 hours. Ill leave it sit and try and get a recording in the next couple days.
09-05-2020, 01:58 PM | #6 |
Rep 1,115
Mine does the same, it's sat a lot during the last 6 months and for a while it did that almost every time. I ended up turning GTS roar on because with cold start off it didn't like idling when first started.
09-08-2020, 05:33 PM | #7 |
Rep 548
Short clip of the start up, of course it didn't stutter that much. I'll see if I can get a better one at some point
09-09-2020, 10:01 AM | #8 |
Rep 548
Still did it a bit today. I'm really leaning towards battery replacement as my starting point if it keeps up.
09-09-2020, 11:19 AM | #9 | |
Rep 7,613
In the video you posted previously i only saw a fraction of a second of hesitation on the first start and then it idles just fine, and the cranking did not sound like there was any battery issue... Just saying that battery issue usually shows up in other ways besides what you are describing. |
09-09-2020, 01:32 PM | #10 | |
Rep 548
The car is a 2015 which puts the battery at over 5 years and we live in florida so the heat tends to kill them quicker... I will try and let it sit for a couple days and try it again. I'm running out of ideas as it doesn't throw any codes and it just doesn't sound right sometime when I let it sit.
09-09-2020, 01:49 PM | #11 | |
Rep 7,613
There's another thread on potential cold start issues now too. The question is really how much variation is 'normal'. As i mentioned there you can also give everything underhood a good visual/physical inspection. It's quite possible that cars are just sitting more/longer now and the decrease in driving frequency is affecting the cold starts, so people are noticing things are different sometimes and are seeking answers/explanation. The average person would probably not notice or just completely disregard many of these small things but of course here on the forums we all pursue perfection Last edited by thejeremyman9; 09-09-2020 at 11:41 PM.. |
09-09-2020, 10:25 PM | #12 | ||
Rep 548
Super confused :-/ it's almost like a long crank that's why I keep going battery... Thanks for the idea of the tender Jeremy. I'll take a deep look this weekend. Might just do coils and plugs again as I use fcp euros warrenty program if I run out of ideas.
09-09-2020, 11:52 PM | #13 |
Rep 605
I heard somewhere if you turn the car on first with out stepping on brake then starting engine helps reduce that cranking from your video on cold start. I guess it primes the fuel through the injectors or gets the injectors ready. Reason why you don't get the issue on second engine start. But don't know if that's true, but worth a try to see if anything changes.
09-10-2020, 12:29 AM | #14 | |
Rep 7,613
09-10-2020, 07:41 AM | #15 |
Rep 1,572
It doesn't sound battery-related. If concerned about the battery, go to Batteries Plus or an Auto parts store and have them test the battery, including a load test. Normally free and will give some insight it the health of the battery.
09-10-2020, 08:52 AM | #16 | |
Rep 548
I'll have to try that tomorrow. Might run over to and autopart store to test the load of the battery just to be sure.
09-17-2020, 09:40 AM | #17 |
Rep 548
Here's another take on it. Running out of ideas. Battery came back fine with volts never dropping below 10.50 on crank.
09-17-2020, 10:26 AM | #18 |
Respect My Authoritah
368
Rep 873
Did you delete cold start with BM3?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
09-17-2020, 10:35 AM | #19 |
Rep 548
No, Cold start is still on and so is the GTS roar from BM3. I turned off BM3 GTS and it did nothing a week ago.
I might try cold start off and report back
09-17-2020, 05:33 PM | #20 |
Rep 7,613
09-17-2020, 06:42 PM | #21 |
BMW CCA Member
488
Rep 808
So here's what I get from time to time....
1. Start car (generally if it's been sitting for a couple days or more) OR there's been a drastic weather change (like crazy heat or cold). 2. Car will rev higher when started, then drop for a second, like it wants to die... then catch itself. 3. Then after about 10 seconds... the idle will drop to normal and it's good to drive. Yes? |
09-17-2020, 10:35 PM | #22 | |
368
Rep 873
Worth the $4!
