12-13-2018, 12:41 PM | #67 |
Rep 289
Well would you believe it, (I'm sure Alice Coupe will), took the motor to BMW Yeovil today expecting an argument and they agreed to replace three of my wheels as they show signs of corrosion, albeit quite small. So booked in for January and have cancelled the wheel repairs as they are being replaced. Jeez hope this isn't the first of many wheel replacements!
Alice Coupe156.50 |
12-15-2018, 08:42 AM | #68 |
Rep 32,881
I just did a very quick job on a badly kerbed wheel (damage went around about 1/3 of the rim).
Car's going back in a few weeks so really wasn't bothered about it looking perfect, just medium grade sand paper, didn't bother with wet & dry paper or metal polish, just cleaned with IPA and did 3 coats of lacquer. Before: |
12-16-2018, 09:12 AM | #70 |
Rep 289
Looks really good, just shows what you can do with some sanding and a bit of patience. How long did it take to do each wheel?
12-17-2018, 10:43 AM | #72 |
Rep 32,881
Depends how much of a perfectionist you are. If you lay the wheel flat you can get quite thick coats of lacquer on without it running which will leaves a glossy finish. Thinner coats end up being more matte due to the thousands of tiny blobs of lacquer, which would then need wet sanding and compounding to get a high gloss finish.
12-17-2018, 11:31 AM | #73 | |
Rep 68
12-17-2018, 02:57 PM | #74 |
Rep 351
It was only a matter of time... around 1/4 of the wheel coming down a multi storey car park!
I take it doesn’t matter if I wait it out till more warmer days in the summer then give this a shot? I have some Halfords body shop lacquer and some sanding paper somewhere around the loft.. |
12-17-2018, 04:15 PM | #75 | |
Rep 32,881
12-17-2018, 04:20 PM | #76 | |
Rep 429
12-17-2018, 04:31 PM | #77 |
Rep 32,881
Or repair the kerb damage and then when the centre corrodes pay nothing towards a replacement wheel under warranty!
12-17-2018, 04:44 PM | #78 | ||
Rep 351
Jesting aside, is this across all 442 style alloys? I believe mine are ferric grey if that even counts for anything. I’ll need to inspect centre of the alloys too to see if anything already exists. |
12-17-2018, 05:49 PM | #79 |
Rep 289
Need to be careful there, some threads on this forum have found that dealers say your wheel warranty is invalidated if they find you have had a wheel repaired and deliberately check the wheel over to looks for any tell tale signs. I imagine that must vary from dealer to dealer.
12-17-2018, 05:50 PM | #80 | ||
Rep 429
In addition, you don’t get warranty on warranty so if you car is 2 years and 360 days old, a replaced wheel will get 4 days warranty. However, if you contributed to it, you’ll get 1 year. Quote:
12-17-2018, 05:52 PM | #81 | |
Rep 32,881
12-18-2018, 03:42 AM | #82 |
Rep 289
Yes this one is being replaced because of the small mark on the left of centre.
12-18-2018, 04:14 AM | #83 |
Rep 351
The old mantra of ‘you learn something new everyday’
I recall checking up the alloys at the time of purchase because 18”+ alloys weren’t new to me, diamond cut however were. Ran my fingers across the edges to check for any poor repairs etc. Didn’t find anything to suggest this. I did notice small particles around the centre but assumed those were just from a recent drive after it had been washed. Anyway, here’s the wheel in its current state. Centre of both rear wheels, the worse being the ‘kerbed’ wheel which is annoying as they may use that as an excuse, despite it only happening yesterday. Unfortunately a snap of the wheel I have from a day after handover only covers a front wheel. Rear OS Kerbed wheel, rear NS. NB: Reading into similar situations, the vehicle is 4 years old. Seemed to think it was older for some reason.. however it’s beyond the 3 years/50k warranty, so this may be another factor. |
12-18-2018, 06:36 AM | #84 |
Rep 68
Ok. I’m at the stage where I have done all the sanding including 3000 grit wet and it’s looking pretty good. The only damage you can see now is right round the edge between the wheel and the tire and it’s not really that noticeable so a vast improvement! I do however have the issue where the sanded parts of the wheel are a very different colour to the non sanded parts, especially where I have only part sanded through the lacquer (a milky colour). Does this problem disappear once you apply metal polish and lacquer? Or should I do more at this stage to fix this?
12-18-2018, 07:09 AM | #85 | |
Rep 32,881
12-18-2018, 09:42 AM | #86 | |
Rep 68
12-18-2018, 10:46 AM | #87 |
Rep 944
Multiple thin coats, starting with a misting coat, finishing with a final somewhat heavier coat to form a glossy surface usually works well when spray painting.
