11-16-2017, 03:56 PM | #23 |
Rep 5,776
I always leave it on Map 5 even on non e85 weeks. I've ran logs on all the maps and they are pretty similiar.
Last car: 2011 335i Msport. JB4. Vrsf CP |
FSociety3812.50 |
11-16-2017, 04:19 PM | #24 | |
Rep 693
FSociety3812.50 |
11-16-2017, 04:25 PM | #25 | ||
Rep 469
FSociety3812.50 |
11-16-2017, 04:28 PM | #26 |
Rep 1,499
I pump into portable fuel tanks and test in the garage. If I plan to run E30 mix then I just make sure to keep 4 gals of E85, which has already been tested, in the trunk and strapped down. That way I can mix even if I need gas when there is no corn around.
F30Beast335i114.00 FSociety3812.50 |
11-16-2017, 09:54 PM | #27 | |
Rep 5,776
If it is less than e85 no big deal--just an increase in ethanol makes a difference and it's not like I get lots of races or go to the track. But, I do respect those that want to get things exactly specific and push their cars.
FSociety3812.50 |
01-08-2018, 04:26 AM | #28 |
Rep 310
Alrite.. so I got my supporting mods done..
Jb4 installed, currently running map 2 Afe momentum cold air intake Catless Downpipe MPE axleback ER Charge Pipe vRSF intercooler.. Do I need anything else? Can I just throw in 2-3gallons of e85 mixed with my 91 and work my way up? Do I need any additional sensors or hardware to install (aftermarket flex fuel kit?) I already have the JB4 flex fuel wires plugged in.. How can I get an ethanol content reading out of my JB4? So I know what mixture i should or am running . |
01-08-2018, 10:58 AM | #30 | ||
not good, but bad
333
Rep 361
Thanks!
They are spelled BRAKES not breaks!!!! Oh FFS, not another spark plug thread!
BreadsBMW on Youtube |
01-08-2018, 11:13 AM | #31 |
Rep 5,776
Interesting..I have a 13 pwg as well and I put 4.5 or more in and have not had any issues. What does your car do if you put in more than 4 gal?
01-08-2018, 11:21 AM | #32 |
not good, but bad
333
Rep 361
Freeway speeds at high RPM's it was stuttering and losing power. I read over at n54tech this was a symptom of too much e85. I just got my fuel pump replaced via the recall, I wonder if I can run more now...?
01-08-2018, 11:47 AM | #33 |
Rep 2,083
3.8g and how many for pump? I put 5gl of E and 10gl 93 and not issues at all.
01-08-2018, 12:09 PM | #34 | |
not good, but bad
333
Rep 361
I'm on the MHD beta program so I'll try as soon as they release an e85 map.
yoandry692.50 |
01-11-2018, 03:25 PM | #35 | |
Rep 1,499
http://www.fuel-it.biz/ethanol-content-tester/
badbread332.50 |
01-29-2018, 07:31 PM | #37 |
Rep 310
havnt done any Ethanol content testing but i did throw in 3 gals of E85... ran fine... no hiccups... might go with a bit more next time.
2008 E90 M3 6-Speed - Sold
2013 F30 335i MSport 6-Speed - Current |
02-02-2018, 04:22 PM | #38 | |
Rep 469
04-02-2018, 10:55 PM | #39 |
Rep 310
would it be safe to run map2 with a E30 mix?... from what ive been noticing, ive only been hitting 10-12psi with Map5 both 100% 91oct as well as E30 mix, however with Map2 on 100% 91, ive been able to peak 14-16psi, at one point, i hit 18-19psi
04-03-2018, 12:33 PM | #40 |
Rep 469
Yeah that's not a problem at all but you'll be better off running map 5 tho .
07-08-2018, 11:52 PM | #41 | |
Rep 808
Anyways I'm on bootmod3 stage 2 and ran the E30 map with a little over 5 gallons of E85 mixed with Costco 91 (ethanol free) to fill the tank. I referred to the calculator provided earlier in this thread to formulate the ratio. I was only able to take one log due to traffic, but aside from a brief overboost/throttle closure the log looked solid to me. I see that nobody here recommends starting with that much, so what should I keep an eye out for on my logs? HPFP seems strong at over 2000 psi, timing looks good. I'm on PWG w/ fuel pump recall. Thanks in advance. http://www.bootmod3.net/log?id=5b429adbd10b43793494a39e |
07-19-2018, 01:57 PM | #42 | |
Rep 72
Have you ran E85 in your car since? Im getting ready to switch to the E30 map and start running E85 as well, once I get my stage 2 LPFP installed.
13' F30 335i
F80 M3 Front End, VRSF Catless Downpipe, BootMod3 Stage 2 E30 OTS, ER Chargepipe, VRSF 5" FMIC, BMS Intake H&R Super Sport Springs, Fuel-it Stage 2 LPFP |
07-19-2018, 02:15 PM | #43 | |
Rep 808
Car ran f'in awesome, not only more powerful but felt smoother and cleaner. Probably sounds crazy but it didn't feel like the engine was working as hard, more effortless torque I guess... If you can, get a tester if you plan to run it often, and do the calculation as per the link earlier in this thread. Definitely a lot of fun and also a cost-effective way to increase octane safely. |
ChillVibeF3016.50 |
07-20-2018, 07:58 AM | #44 |
Rep 1,499
I've been running the bm3 E30 OTS map with about 2.5 gals of E85 per tank for the last 3 months. Car runs great and the smell with catless DP is less noticeable. I'm about to bump up to 3 gals on next fill-up.
