03-07-2019, 07:44 AM | #23 |
Rep 16,079
Fuel filters remove particulates from the fuel, not the hydrocarbons that eventually clog injectors. Injector cleaners remove those deposits, not particulates.
bavarianride1509.00 |
03-07-2019, 12:55 PM | #24 |
Curmudgeon and Pedant
690
Rep 3,489
03-07-2019, 10:41 PM | #25 |
Rep 387
This would have bothered me in the past, but my last car, a 2004 Jeep Wrangler, also did not come from the factory with an in line fuel filter. Just the pick up screen that is part of the fuel pump assembly. I put nearly 260,000 miles on that thing; I never had to replace the fuel pump, or any components of the fuel injection system. All I did was run top-tier gas like Shell or Chevron ( mostly Chevron) and the occasional bottle of Techron. As long as you are using a good quality gasoline, they do a pretty good job of filtering out the crud before it gets to the pump. If we are talking Arco or Sinclair gas, I would be more concerned because they should be paying you to put their gas in your car. Although, technically speaking, they are also rated as top-tier gasolines, so I suspect it doesn’t take too much to be awarded that status. But I digress.
03-08-2019, 07:24 AM | #26 | |
Rep 16,079
I suspect that the lack of an inline filter has to do with the high pressure delivery fuel pump required with direct injection engines. |
03-08-2019, 08:21 AM | #27 |
Rep 5,456
Drives: F30
Personally running 1 bottle of Techron during the last fuel up before oil change (every 5k miles).
That and always top tier fuel. Hopefully that will keep the system clean and running optimally well into 200k miles. 71k and counting... |
03-15-2019, 02:35 PM | #28 |
Rep 61
I have heared alot before oil change but why?
03-15-2019, 03:11 PM | #29 | |
Rep 5,456
Drives: F30
03-15-2019, 03:13 PM | #30 | ||
Rep 61
03-16-2019, 12:44 PM | #31 | |
Rep 417
But then there is oil filter and chevron gas already has techron in there (although I only use shell ). So it is more of a precaution and making sure the fresh oil is free from any possible contamination. |
sspade2464.50 |
03-16-2019, 01:12 PM | #32 |
Rep 764
is this the techron cleaner you guys are talking about? looks like its half off on amazon, I might just stock up on a few bottles Chevron Techron Concentrate Plus Fuel System Cleaner - 20 oz. https://www.amazon.com/dp/B00092893E..._wXtJCb58ERKQZ
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
03-16-2019, 02:15 PM | #33 |
Rep 16,079
The deposits are removed from the fuel injectors. There's no direct route between them and the crankcase. The only reason I can think of for adding injector cleaner at the same time as an oil change is that there's no light on the dash to remind you that you're due to clean the injectors.
03-16-2019, 04:14 PM | #34 | |
Rep 417
Correct me if I am wrong, since N55 uses direction injection, the injectors are unlikely to spray the fuel onto the intake valves. That may defeat another benefit of Techron, cleaning the top of the intake valves. And for this reason, we do walnut blasting to clean them? |
03-16-2019, 04:40 PM | #35 |
Rep 16,079
Correct. You can also use this to clean intake valves:
https://www.amazon.com/CRC-05319-Int.../dp/B00PHNQKR2 It uses the same active ingredient as Techron (and most injector cleaners) in a much higher concentration. If you use this yearly your valves may never get bad enough to need blasting. Another option is to add an oil catch can, which prevents oil from the crankcase from getting to the intake manifold and valves via the PCV, so they don't get carbon crusted to begin with. |
03-16-2019, 05:42 PM | #36 | |
Rep 417
I may actually look into the oil catch can. I will be changing my charge pipe next week; if there is too much oil in the tube, I should probably order one... |
04-09-2019, 08:20 AM | #37 |
Rep 67
every 10 thousand kilos is enough i
I would on;y use it every 10,000 kilos or so ,, also used STP Ultra Fuel System Cleaner , which is so good, however since last time I've used it i have a small hesitance in idle,, want to hook it up to a diagnostic tool to see if actualy there is sth or I am dreaming
04-13-2019, 11:50 AM | #38 |
Rep 7,484
You can do way better than the BMW Additive. Try some of the Liqui Moly additives.
https://egypt.souq.com/eg-en/%D9%84%...n=2&page=1 The Benzin one is good for poor quality fuel. Use it whenever you want. One can to treat 60 litres of fuel. You use one can for a tank. It will wear off after the second or third tank. Don't let the tank run below 1/4 to keep the additive going. Ceratec is good for protecting the engine. |
04-23-2019, 09:46 AM | #39 |
Learning
62
Rep 121
I wouldn't buy this simply because the add is misleading. It shows a picture of the valves dirty as hell then basically the back of the valve being brand new. Btw if I'm wrong most if not all the bmw engines over the last how many years have been direct injection and the fuel spray never hits the back of the valves......
