03-21-2019, 10:01 AM | #1 |
Rep 309
Need help finding a plastic piece in engine bay
Hi every one,
So I've been trying to figure out what the part number for a plastic piece in the engine bay was. It's been driving me crazy. Countless diagrams from different parts site and still can't find it. Maybe someone has replace theirs too, as mine has broken. Looking at the diagram its right under where #9 is. It looks like a hood stopper but I don't think its used that way. Someone please help get the part number. Even though it will not affect the cars performance it bugs me when pieces are missing or broken. Kudos to someone that finds it. https://www.realoem.com/bmw/enUS/sho...diagId=51_8380 |
03-21-2019, 11:39 AM | #2 |
No 55mph
1621
Rep 8,476
If you mean the hole shown directly under the (9) balloon on the front upper crossmember - could be the stud, that goes into the crossmember, that accepts the grommet from the air intake - #6 in following diagram link:
https://www.realoem.com/bmw/enUS/sho...diagId=13_1499 Only thing I can think of that could not be there that would leave a hole Of course, if you're still running the factory intake system - it should be there... I have mine removed because I'm running the Dinan CAI which doesn't use that attachment point
03-21-2019, 11:41 AM | #3 |
Rep 309
Not the mount for the intake that's number 26. It's slightly to the front of that. The bigger hole that is center I guess if you look at the front of the car and see the engine bay it looks like a stopper in the center when the hood goes down and it's forward of the intake mount.
03-21-2019, 02:12 PM | #4 |
Modder of everything I own
147
Rep 491
if it goes in that hole below the 9 in the diagram is it this?
There are hood stoppers aside from this https://www.getbmwparts.com/oem-part...MtMGwtbDYtZ2Fz
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
03-21-2019, 08:43 PM | #5 |
Rep 1,572
That hole is where parts 4 & 6 go to hold the air intake tube. See http://www.realoem.com/bmw/enUS/show...diagId=13_1499
03-22-2019, 11:41 AM | #6 | |
Rep 309
