03-21-2019, 12:04 PM | #1 |
Rep 98
alternative transmission fluid 8HP45
I have located a few transmission fluid that has viscosity very close to lifeguard fluid and does not cost $22 a liter. my understanding is that if the viscosity is too high it will cause more drag and lower you mpg.
I found 2 transmission fluid from big brand where there viscosity levels are very close to lifeguard 8 fluid Lifeguard 8 - $22 per liter Viscosity, 26 mm2/s (40°C) Viscosity 5,6 mm2/s (100°C) Pour point <= -42 °C Flash point >= 206 °C https://www.amsoil.com/shop/by-produ...?code=OTLQT-EA Amsoil OE line about $10 per qt Viscosity, 28.3 mm2/s (40°C) Viscosity 5.8 mm2/s (100°C) Pour point <= -48 °C Flash point >= 210 °C Valvoline about $5 per liter https://sharena21.springcm.com/Publi...ment/18452/9e4 Maxlife ATF Viscosity @ 40°C, cSt 28.82 Viscosity @ 100°C, cSt 5.91 Viscosity Index 156 Specific Gravity @ 60°F 0.843 Pour Point, °C, -48 Brookfield Viscosity @ -40°C, cP 10200 Flash Point, COC, °C 202 I have personally used Valvoline maxlife in all my other cars-very good fluid. my highest mileage car- a mazda with 260k with perfect shifting still. i think it was better then the OEM fluid- it did not turn black as quick. i also see a lot a Ram owners using it in the ZF8HP70 tranny. I have looked at bunch of other Euro fluid. Motul, revenol 8hp and a few other, none of them have viscosity level closer then these 2. beside the price is about the same as lifeguard. i keep my car for long time and to keep them shifting nicely we need to change the fluid! but at $22 per liter. seem kind of high. anyone else have tried these 2 fluid? |
03-24-2019, 11:42 PM | #2 |
Rep 387
As long as it meets ZF’s specs, you should be fine. Just make sure it meets those specs. I used to be a mechanic for a large dealership. I saw the tranny guys (not what you’re thinking) rebuild or replace many transmissions because the incorrect fluid was used. It’s that important.
03-27-2019, 04:36 AM | #4 | |
Rep 3,946
FCP Euro sells the LiquidMoly Top Tec 1800 ATF which they claim meets the specifications. https://www.fcpeuro.com/products/top...i-moly-lm20032 |
03-27-2019, 11:32 AM | #5 |
Rep 62
FCP Euro also sells the lifeguard fluid so you can get free fluid after the first flush.
Also, ZF says you need 7 bottles but you only need 6. I used barely more than 5 quarts in mine.
2011 M3 ZCP 6MT
