03-20-2013, 12:02 PM | #23 | |
Rep 802
F30 335i Reaches 0-60 in 4.7sec (Motor Trend Video Review): http://speeddistrict.com/item/3833/ Did I win the pissing match?
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
03-20-2013, 12:06 PM | #24 |
Seismoguy
Rep 180
Just one detail - I buy (1), but (2) seems misleading. If a tire loses grip and locks up, doesn't the x-drive quickly release it, so that it can regain traction? So (2) only applied momentarily when grip is lost, and partially applies when the direction the car is traveling differs from the direction the tire is pointed.
03-20-2013, 12:12 PM | #25 | ||
Rep 3,619
I am trying to water down these comments of rwd superiority over awd. Not trashing rwd at all.
EBII 2014 335i xDrive
335HP, Sport AT, 19" Wheels, MPE, Prem, Tech, Cold, HK, Driver Assist & DH pkgs Deep Sea Blue Metallic 2013 X5 35d Sport Prem, Convenience, Cold and Premium Sound packages |
03-20-2013, 12:14 PM | #26 | ||
Rep 3,619
03-20-2013, 12:15 PM | #27 | |
Rep 802
Summer tires in below freezing termperatures are like hockey pucks. Ice gets logged in the grooves and the tire becomes one rock-hard solid piece of rubber (as there's no where for the snow, water and ice to go). You essentially have zero traction.
03-20-2013, 12:17 PM | #28 | |
Rep 9,709
On wet roads the AWD leaves the line cleanly, but other than that it doesn't offer any real advantage. |
03-20-2013, 12:24 PM | #29 | ||
Rep 3,619
The issue we need to decide here with facts is given the same track, which will be faster and by how much. Here I think (start pissing contest here) the result will be close (end pissing contest).
03-20-2013, 12:29 PM | #30 |
Rep 3,619
[QUOTE=martinf
Summer tires in below freezing termperatures are like hockey pucks. Ice gets logged in the grooves and the tire becomes one rock-hard solid piece of rubber (as there's no where for the snow, water and ice to go). You essentially have zero traction.[/QUOTE] Exactly why in my original post I said above freezing with no snow on road. That's why I parked the car for 2 days this winter. If you are trying to tell me to change my set up so I can drive 2 more days a year, I am sorry, it's not going to happen
03-20-2013, 12:29 PM | #31 | |
Seismoguy
Rep 180
I want a tenacious grip on the road, others weigh more heavily agile performance in good road conditions - I'll prefer x-drive, they won't. I think these conflicting advantages hold in a broader range of road conditions than the worst blizzards, but that's just my opinion. |
03-20-2013, 12:34 PM | #32 | ||
Rep 3,619
03-20-2013, 12:39 PM | #33 | |
Rep 802
Which begs the question... RWD w/ winters is less than expensive, more fun, better fuel effificency, less maintaneance... when compared to Xdrive. If you're going to go AWD and not drive it when it snows... ummm... am I the only one trying to figure out what the point is then?? Why get it to begin with?
03-20-2013, 01:04 PM | #34 | ||
Rep 3,619
After driving the AH3, the tq monster, I realized unless I am in an M3, I would rather have the 3er that makes the most of its available power, there is no doubt that's the x drive model. Agreed this is at the expense of gas mileage but come on, 2mpg? After spending 335i money 2mpg is something to consider? If my calculations are right that's less than $100/yr in gas costs. FYI, parking the car is a choice, I can still drive it and I have, but I prefer being at home now. Alternatives: 1) rwd with winter tire set up. Overkill in my view given said 2 days. 2)rwd with summer set up. Could prove dangerous in the winter, having awd helps with traction in the snow but both set ups will be dangerous when stopping in the snow. 3) awd with all seasons. All seasons suck. Period.
03-20-2013, 01:49 PM | #35 | |
Seismoguy
Rep 180
These arguments of zero benefits except in icy blizzards near the North Pole seem ill-posed. I'm not claiming x-drive is supreme, but just that it provides better traction in acceleration more than 1% of the time. |
03-20-2013, 01:53 PM | #36 |
Rep 102
Drives: 2011 Toyota 4Runner Ltd
comparo
It would be great if a reputable comparo would be done treating the 2 vehicles as if they are what they are, different cars.
I suppose there is no money in it like there is in comparing between manufacturers, but as we have found AGAIN, there certainly is interest. |
03-20-2013, 02:03 PM | #37 | |
Rep 9,709
....but.............roll ons from 10mph and the RWD will not lose. Not saying there will be a big difference but the xDrive is heavier and has more drag so will struggle. On track the xDrive will suffer from more under steer (unavoidable consequence of extra drag on front wheels), it is heavier, so on the brakes earlier, lower apex speed (weight again and under steer), more grip out the corners, but come on we are talking 300hp here, hardly a tyre burner. I'd be faster in the RWD than I would in xDrive |
03-20-2013, 02:12 PM | #38 | |
Rep 3,619
I am not going to pretend I know more than you in this respect, however at least you can acknowledge we need the side by side comparison of track times for both. Its unfortunate we cannot find any, this is not the first time I have asked for this but nothing has really been presented.
03-20-2013, 02:16 PM | #39 | |
Rep 3,619
03-20-2013, 02:22 PM | #40 | |
Rep 9,709
One thing for sure about the RWD though........................it is 100x more fun *FACT* |
03-20-2013, 02:31 PM | #41 | |
Rep 3,780
Physics and numbers do not lie. This is not something that can only be proven by BMW, plenty of cars are offered in awd and RWD and the physics and numbers are clear. Fact 1, same drivetrains but one with awd, the awd car will put less power down to the wheels due to higher paracydic losses. So your 300hp is 255wp but the RWD is more like 270whp. Fact 2, the awd car carries more weight. That weight combined with fact 1 worsens the power to rate ratio even worse. In some cases the weight can worsen the balance of the car, or make it better, It depends. That weight also makes things like the brakes and tires work harder. Those two facts are not opinions. You can grasp at whatever joke claim BMW makes To 0-60 on its website to make you feel better but it does not make the awd car truly faster. Fast and quick are two different things. Awd will have a 0-15mph advantage, but after that the more power to the ground, the better power to weight of rwd takes over, that is why the RWD car will have a higher trap speed, often lower 1/4 mile et and better top gear acceleration.
'98 Dinan/RMS stage 2+(VAC cams, CES Cutring etc) '15 Buick Regal "T"(wife) '06 Saab 9-5 Combi 5mt (full suspension, LSD, clipped turbo etc) Last edited by Jamesons Viggen; 03-20-2013 at 03:13 PM.. |
03-20-2013, 02:45 PM | #42 | ||
Rep 3,619
What we all want to see is the 2 racing on the track and let's tally the result, nothing wrong with that. Take out the period from your quote of my statement, it's misleading.
03-20-2013, 02:49 PM | #43 | |
Rep 141
Conventional AWD setup often leads to understeer. However with modern computer controlled center diff, this is no longer the case. The latest xDrive proactively shifts power distribution to the rear during cornering. So, the xDrive is a far cry from the old Audi Torsen setup. The xDrive might be a little heavier, but it can also start accelerating out of a corner sooner. This is especially true when the RWD F30 is without a mechanical LSD. When it rains, it's game over on the circuit for the RWD. I take everything that Top Gear says with a grind of salt, but here is a comparison between the AWD and RWD Porsche 911. With its rear engine setup, it's known to have superb traction in even RWD configuration, but still the AWD is faster, however slightly so. If their time is to be believed that is. |
03-20-2013, 02:54 PM | #44 | |
Rep 3,619
