BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Updating idrive history with HU-ServiceManager
Studio RSR
      07-17-2018, 09:24 AM   #23
AbzzMonsur
Abzz
AbzzMonsur's Avatar
Drives: 435D XDrive Convertible
Originally Posted by BimmerSI View Post
Hi,
i just done it yesterday! It works great and it is simple to use.
1. Click on "Connect to HU" button. On bottom left it shoud say "Job Status OK".
2. Select date. You should change ";" with "/" and use european date format like DD/MM/YYYY. Then put in your milage.
Select dealer number. I entered 00000, becasue service has been done by independent dealer and still selected "BMW Dealer" because he works with BMW exclusivly.
3. Then select number of tasks that were performed. This will unlock service task selection.
4. After that, just click to "Write to HU" button and check that the "Job Status OK" is present.
5. Now check on your iDrive. Service listing should be on the bottom. If you want "proper" listing, you should delete all entries and write them one by one backwards.
I hope it helps!
Cheers,
BimmerSI
Hi,
Does anyonr have the HU-Service Manager zip files? Can't locate it on original website anymore
      07-17-2018, 09:43 AM   #24
Sasquartch
Drives: 520i G30
Originally Posted by Joshd63 View Post
Hi
Is there any chance you could end me the file also if I give you a onedrive link?
Cheers
Send me a link
      07-17-2018, 09:44 AM   #25
Sasquartch
Drives: 520i G30
Originally Posted by producerlawson View Post
I used this early last year - works a treat if you know how to setup the serial com ports.
I personally found my E-Sys OBD cable didn't work - I had to get a DCAN serial to usb cable which enabled me to work. As others have said, it's all about editing the EDIABAS.INI file to match your pc serial port - sharing the file may not necessarily work as not everyone has the same hardware plugged in/ports in use.
Make sure you take a photo of your edits, as at the next service the dealer will wipe all entries and enter what they're given from the BMW server logs.
No serial ports involved as it's a TCP/IP connection over an ethernet interface
As long as your esys cable works this should too
      07-17-2018, 11:48 AM   #26
fortythirtyfive
Drives: 435i MS
Yeah my ICOM cable for coding in applications such as E-Sys is functional, but when using apps such as edibas and toolset32 I faced errors and problems.
To my knowledge I thought ediabas applications required a K DCAN cable? I'm sure it's in the requirement section of the manual due to the nature of them containing the FT232RL chips.
Whenever I tried via an ICOM connection I would hit errors whilst trying to apply the new service information. This stopped the second I switched to a KDCAN cable which uses a serial port to allow the transfer of more data.
https://www.ebay.co.uk/itm/For-BMW-I...MAAOSw~7ZbNtqP
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      07-18-2018, 09:47 AM   #27
Sasquartch
Drives: 520i G30
As far as I know all F series cars use an ethernet interface, the older cables like you linked to were used on the older E series cars and needed serial port emulation and connected to the computer using USB.
An ethernet cable goes directly between the OBD port on the car and the ethernet port on the computer with no electronics in between
The fact that I have it working with my EDIABAS.INI file containing the line :
Interface =ENET
seems to confirm this
Not entirely sure what an ICOM interface although I've heard it's used on E90 and similar generation cars
I have had this working on several different cars (F30 and F34)
      07-19-2018, 05:34 AM   #28
mashaw
Drives: F31 320d Msport
Hi Guys
Im new to the forum, just about to start a retro fit on my F31 and wanted to update the service history, from what i've read I need to HU Service Manager. Can anyone point me in the direction on where I can download this
      07-20-2018, 04:34 AM   #29
HFW003
HFW003's Avatar
Australia
5685
Drives: 2024 M340i xdrive
I have a zipped up copy of the Service Manager and EDIABAS files that I used
It's 80 MB or so
If you can provide a FTP site or Google Drive /Dropbox or something I'm sure I can send the files to you
Would you mind sharing with me also?
Thanks
      07-20-2018, 10:08 AM   #30
dy63
Drives: F30
is there a link to the HU Service Manager?
      07-20-2018, 09:48 PM   #31
jkwhar
Drives: F30 328i Xdrive | F15 x35i
When was service history introduced? I've seen this menu in the idrive (MY 4/13).
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD)
      07-21-2018, 10:48 AM   #32
Sasquartch
Drives: 520i G30
Originally Posted by IK6SPEED View Post
Then why bother
So you can enter everyone back in again
      07-23-2018, 02:31 AM   #33
ThEdOvEz
Drives: F30
hi please could someone give me a link to these files? thankyou
it ok now i managed to find them and worked a treat thanks
      08-26-2018, 02:55 PM   #34
jjan
Drives: 535D 2011
Hello, can anyone please sent a link to download?
Thanks in advance )
      08-26-2018, 04:36 PM   #35
atzebmw
Drives: Tesla Model 3
Thanks in advance )
At google search for "hu service manager".
For me it is the 3rd search result (drive2.ru).
      09-15-2018, 12:14 PM   #36
pcp1234
Drives: G03
mine wont even connect to unit. any tips how to get it to work please?
      09-18-2018, 03:08 AM   #37
Sasquartch
Drives: 520i G30
Firstly you need to check you have basic connectivity. Do you have esys or ISTA or anything else that connects to the car OK ?
Have you worked through all the posts in this thread ?
Is your ediabas.ini file correct, ie is the connection type set correctly ?
      09-18-2018, 07:03 PM   #38
pcp1234
Drives: G03
- my ediabas, esys, ista d, ista p works ok + flashing ECUs works fine too
- INTERFACE = ENET
- #INTERFACE = REMOTE
- I have downloaded version with java and without java.
- my machine runs java 8 update181 x86 and x64
- i placed program in random folder and ediabas too
- batch file with download doesnt seem to be doing anything
please help me
      09-19-2018, 09:21 AM   #39
Sasquartch
Drives: 520i G30
You need to provide more information
What does happen ?
      09-21-2018, 05:12 PM   #40
pcp1234
Drives: G03
this happens absolutely nothing
al203 compound name
      09-21-2018, 07:55 PM   #41
pcp1234
Drives: G03
ok, i got to work and since no one was willing to assist i will write up how to make it work!
1. download hu service manager
2. unpack content like this -> C:\EC-APPS\BMW-HU-ServiceManager
3. in folder "BMW-HU-ServiceManager" should be four items: folder "jre", HU-ServiceManager, HU-ServiceManager ico, HU-ServiceManager jar
4. make a shortcut from HU-ServiceManager.bat to your desktop
5. right click on created shortcut and go into properties
6. change icon and select HU-ServiceManager.ico (cosmetic job)
7. connect cable to car, then to laptop and run HU-ServiceManager from the shortcut on your desktop
8. click connect to hu
9. wait for "famous" screen with confirmation "job status complete"
10. enjoy your changes from now on
kind note
i had to restart my nbt in order to see change
oli342.00
F20_M135i100.50
      09-22-2018, 01:58 AM   #42
Sasquartch
Drives: 520i G30
Not really true, if you provided the relevant information you may well have had an answer
      10-31-2018, 03:13 AM   #43
ir655
Sweden
Drives: F31 320d and F11 530d
Hello guys, I finally got this up and running but when I press "Connect to HU" I get the following message in the box below: "13 IFH-0003 Datatransmission to interface disturbed".
I have ISTA-D installed and it connects to the car without remark. I can even connect to ESYS with the ENET cable I have.
Any ideas? :-/
      10-31-2018, 05:31 AM   #44
Sasquartch
Drives: 520i G30
Any ideas? :-/
Is your ediabas.ini file definitely correct, ie set to ethernet (ENET) ?
