05-16-2019, 02:52 PM | #23 | |
Rep 387
https://f30.bimmerpost.com/forums/sh...ghlight=mildew |
07-02-2019, 08:15 PM | #24 |
Rep 355
The only thing that would get rid of the smell is the Air Con Bomb spray. Buy a spray can and place it under the passenger foot well, close all windows, select the air recycle button on the climate control so air is sucked only from inside the cabin, turn the ac on and put the fan on max and then release the spray can lock on the nozzle. Get out of the car and leave it running for 15 minutes, then get inside and open all windows and leave the ac running on max for another 10 mins. Park the car overnight, start the ac the next day and enjoy the fresh smell!
I’ve used this method many times before and works a treat eveytime! I’d also advise to fit a brand new cabin filter straight after the treatment. Cheers |
07-23-2019, 03:15 PM | #26 |
Rep 740
Alright, after all this, it ended up being the filter. Replaced the filter, no smell. I'm on week 5 or so and its been hot and humid here. I did get a filter that doesn't contain activated charcoal to see if thats the culprit but its gonna be awhile before I report back on that.
I'd say guys, if it smells, just replace the filter and watch it go away.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
07-23-2019, 04:54 PM | #27 |
BMW CCA Member
488
Rep 808
[ laughing ] ... jkwhar, you beat me to it. I was going to ask the question "Before you all take apart your dash and AC units, have you replaced the cabin filter yet?"
08-18-2019, 08:38 AM | #29 |
Rep 1,907
Bought some air-conditioning foam cleaner, Managed to get the tube around the bend and hopefully sprayed the evaporator also inserted the tube in all vents inside cabin, Will report back in due course if it works.
Happy Motoring
Evdok |
08-19-2019, 11:52 AM | #30 |
Rep 62
You can also use a portable garden pressure sprayer with the nozzle bent into a hook.
You remove the air filter and insert the nozzle into the air inlet behind the air filter. The hook will "go around the corner" and empty out on the top of the evap. The fluid will drain through and out the AC outlet under the car. I have done this several times in my car - unfortunately. |
evdok818.00 |
06-18-2021, 05:40 PM | #31 |
Rep 44
I came across this post while searching for a possible solution. My wife’s F30 had a weird smell whenever I would turn the AC on. So I thought it might be the cabin air filter. Today, I changed it. However, when I opened the area of the passenger footwell to access the filter, I noticed a yellow ring on the foamy-pad. I also noticed some yellow liquid on the blower motor right where the parts sticker is. Any help would be greatly appreciated. I have uploaded the picture here:
View post on imgur.com |
06-18-2021, 09:45 PM | #32 |
Rep 16,054
The yellow liquid could be electrolyte that leaked from a capacitor that's used on the motor power supply. I can't say for sure, but it's one possibility. I'd have it looked at.
03-01-2024, 03:09 AM | #35 |
Rep 2
F25 AC smell as well
Any chance the imgur picks from 2018 can be hosted again? I'm trying to do this to my X3, but I don't know where the AC drain hole is. Would be great if I could see the original images again. @jkwhar
03-01-2024, 07:16 AM | #36 |
Rep 16,054
I doubt many F30 owners will know where the X3 drain is, unless they happen to own an X3 as well. The best way to find it is to run the AC on a humid day, then trace where the water under the car is coming from.
03-04-2024, 12:33 PM | #37 |
Rep 740
I tried reuploading but somethings failing. Might need to create a new account. I'll work on this a little later.
