12-24-2018, 11:24 AM | #112 | |
Rep 2,302
But you mean you can't see it in E-Sys? Then change the VO to 6WB an first code the HU with it. Then the 6WB (DKombi) should be visible. |
12-24-2018, 11:40 AM | #113 | |
Rep 6
Yes i cant see it using Esys, i changed the VO adding 6WB but didn't do the HU coding.. Could you tell me what to do to code it? |
12-24-2018, 11:43 AM | #114 |
Rep 2,302
12-25-2018, 06:05 AM | #116 |
Rep 2,302
12-25-2018, 10:11 AM | #117 |
New BMW owner
139
Rep 621
Try changing the built year to 11/16.
01-18-2019, 08:33 AM | #118 |
Rep 66
I’ve been running with my 6WB retrofit for a few months now and all is well, mostly. I have the navigation info clipping in the center with certain directions (round abouts or complicated intersections mostly) and an error code for “MOST node: the default registry is outdated” which doesn’t seem to affect anything but would be nice to fix if anyone knows how to update that.
Also is it possible to code the fuel range graph so it shows static numbers (like 0 and 200 in the middle) rather than showing the range following the end of the bar graph? |
01-18-2019, 02:03 PM | #119 |
Rep 3,876
You already have the fuel gauge in the circle to the left.
The scale right of it is range. Or am I misunderstanding your thought?
01-18-2019, 06:50 PM | #120 |
Rep 66
Correct. The scale on the speedometer side shows the range as a graph with the miles as a number which follows the end of the graph. I wondered if it could be changes so that the numbers are shown in a fixed location on the graph, sort of like how the mpg graph is displayed on the right side of the cluster.
01-18-2019, 07:22 PM | #121 |
Rep 3,876
Still don't understand why you would want that, but either way it is not possible through coding.
01-22-2019, 05:13 PM | #122 | |
Rep 6
-------------------------------------------------------------------------------- hello, I made kombi retrofit for 6WB I added 6WB to FA and coded HU_nbt evo and kombi everything works fine but oil temperature and diesel do not work well. when I turn off the ignition the diesel does not come to zero is a 1/3 and the temperature seems to be the opposite wronf side pointer. will it be some coding or do I have to also add the FEM ICM etc … i filling full up the pointer marks out the scale, analyzing well the pointer always points to 1/3 higher what should mark with the car off should point to zero points to wrong to 1/3 above when full fil points 1/3 off range The oil temperatura pointer are on wrong direction (like a mirror) see pictures https://f30.bimmerpost.com/forums/sh....php?t=1553764 |
01-22-2019, 05:14 PM | #123 | |
Rep 6
01-23-2019, 01:20 PM | #124 |
Rep 4
01-23-2019, 05:19 PM | #125 |
Rep 83
01-23-2019, 10:06 PM | #126 |
Rep 47
does anyone know the code to make the 6wb stay in sports display mode. while even in comfort or eco.... I really just wanted it for the big digital read out.. dont want to always drive in sport.. mines is a retro fit
01-24-2019, 01:38 AM | #127 |
Rep 3,876
No such code as far as I am aware.
01-24-2019, 02:39 AM | #128 |
Rep 4
01-24-2019, 04:59 AM | #129 |
Rep 2
Have been searching everywhere for the same. I think the duration of the startup logo is fixed and cannot be changed.
It sucks, if I want to see the M550D logo i need to rush into the car before it dissapears.. |
01-24-2019, 03:22 PM | #130 |
Rep 83
Yes, i don t have hud too, and worked for me
