01-14-2016, 03:06 AM | #1 |
Rep 1,201
Code out TPMS
Well, winter has finally hit the UK and I've gone over to my winter wheels on my 2015 LCI. However, the new wheels do not have the TPMS sensors on. I tried coding out the TPMS and bring back the old RPA with the following code:
In HU_NBT > 3001, code RDC to nicht_activ In HU_NBT > 3001, code RDC_SAFETY to nicht_activ In HU_NBT > 3001, code RPA to active This still leaves the nag triangle and I get the chimes when I start up. So looking further into this I've found this for an F10: Removed 2VB from FA and VO code HU_NBT and KOMBI. (there was also some fuse pulling mentioned on the F10 but I'm not sure where the fuses are on F30 or if it needs to be done?) Will this work for a LCI F30 or are there further steps? And when summer finally arrives in Scotland, is it just a case of reversing this? *** SOLVED See this Post ****
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 02-02-2016 at 02:44 AM.. |
01-15-2016, 10:45 AM | #2 | |
Rep 128
Hopefully that helps! |
01-15-2016, 11:24 AM | #3 | |
Rep 1,201
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
01-15-2016, 02:06 PM | #4 |
Rep 1,201
I've found another setting in addition to these:
HU_NBT_EVO > 3001, code RDC to nicht_activ HU_NBT_EVO > 3001, code RDC_SAFETY to nicht_activ HU_NBT_EVO > 3001, code RPA to active There is also: HU_NBT_EVO > 3001 > REFEINUEBERWACHUNG_RDC_RPA which can be rdc, rpa or nicht_activ I'm going to try setting this to rpa to see if that activates the greyed out reset
01-15-2016, 11:12 PM | #5 |
Rep 5,316
Drives: G80 M3 6MT
I've heard that TPMS is hard to code out (at least on the E90) because its a safety feature.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
01-16-2016, 05:49 AM | #6 |
Rep 1,201
Right - here's an update -
This is what I've coded so far- HU_NBT_EVO > 3001, code RDC to nicht_activ HU_NBT_EVO > 3001, code RDC_SAFETY to nicht_activ HU_NBT_EVO > 3001, code RPA to active HU_NBT_EVO > 3001 > REFEINUEBERWACHUNG_RDC_RPA Code to rpa This has go rid of the tyre pressure failure nag and activates the RPA reset. However, when you reset you get he message that the pressures will be reset when the car is moving but that seems to never happen. You are left with the small triangle and at startup it nags you to reset the RPA but no bongs during driving and no tyre failure nags either.
01-16-2016, 10:39 PM | #7 | |
Rep 1,527
01-17-2016, 03:39 AM | #8 | |
Rep 1,201
How many of us remember do this every time we had a flat?
01-17-2016, 04:04 AM | #9 |
Coding ECU's remotely
445
Rep 1,172
I've got this exact same problem on my LCI F20. Did you try removing 2VB and coding NBT & KOMBI?
I'm wondering if there is another setting required in the ICM for RPA?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
01-17-2016, 05:53 AM | #10 | |
Rep 1,201
I did have a look in KOMBI and found some settings associated with the RPA but they also have DSC in the setting, so I thought it best not to touch in case it affected the stability programme. I'll have a look at the ICM too
01-17-2016, 05:56 AM | #11 | ||
445
Rep 1,172
01-17-2016, 06:37 AM | #12 | |
Rep 1,201
HU_NBT_EVO > 3001 > Code REFEINUEBERWACHUNG_RDC_RPA to rpa And i've driven for more than 20mins. It just nags to reset the RPA monitor. When I do reset the RPA monitor is where it differs. In my old F30 it said you must be stationary to reset the RPA whereas the RDC needs to be in motion to reset the pressures. Now there is another setting which I've not changed: HU_NBT_EVO > 3001 > RDC_FORTSHRITTSANZEIGE (currently set to active) now FORTSCHRITTSANZEIGE means progress indicator. Maybe if I code that to nicht_activ and see what happens.
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 01-20-2016 at 03:04 AM.. |
01-17-2016, 07:37 AM | #13 | ||
445
Rep 1,172
01-17-2016, 08:08 AM | #14 |
Rep 1,201
Me too.
I found this: in ICM ICM > Daten 3000 > IcmKod_B_SA2VB and set it to nicht_verbaut (not installed) but this upset the DSC and I coded it back
01-17-2016, 10:12 AM | #15 | |
445
Rep 1,172
01-17-2016, 12:31 PM | #16 |
Rep 1,201
Which ECU? I've just updated my PSDZData as I could not access all ECU's
01-17-2016, 12:32 PM | #17 |
445
Rep 1,172
the DSC ecu. are you using the TokenMaster launcher?
01-17-2016, 02:14 PM | #18 |
Rep 1,201
Yes, Version 2.4.3 Build 98
01-20-2016, 02:58 AM | #20 |
Rep 1,201
No more progress yet but I've not given up!
01-20-2016, 07:12 AM | #21 |
445
Rep 1,172
try removing 2VB from the VO and then code the ICM, DSC, NBT and KOMBI
01-21-2016, 01:56 AM | #22 | |
Rep 1,201
I take it you mean remove 2VB from the FA and VO code the ECU's you mention? (Just for clarity)
